2018 KTM Bar Mounts
UPSman334
Rock Creek, OH, USA
Edited Date/Time 4/17/2018 4:01pm
I am replacing my bar mounts on my bike due to that they are bent. I don’t want the stock ones they don’t seem to be very strong seeing as they bent from a tip over in a corner, any good aftermarket recommendations??
exbmxmx
Houston, TX, USA
3/28/2018 2:19pm
2016 KTM OEM lower bar mount. It is a one piece design.
UPSman334
Rock Creek, OH, USA
3/28/2018 2:23pm
it will fit??
exbmxmx
Houston, TX, USA
3/28/2018 3:01pm
My son has bent the stock 2016 bar mounts during a pretty good crash last year but you know what else bent? Nothing. The relatively cheap bar mounts absorbed most of the crash energy and saved the expensive forks, wheels, triple clamps or frame from any damage. So replacing weak parts with strong parts is not always the best option as long as the weak part is not failing during normal use.
Luxon MX
San Diego, CA, USA
4/11/2018 5:02pm
May be a little late for you, but our stock bar mount replacements just became available. Check them out on our triple clamp page here:
Luxon MX Bar Mounts
aedwards07
st cloud, FL, USA
4/11/2018 6:23pm
Luxon MX wrote:
May be a little late for you, but our stock bar mount replacements just became available. Check them out on our triple clamp page here: [url=https://luxonmx.com/products-triple-clamps.html]Luxon...
Luxon MX Bar Mounts
Those look very nice.
Slosh 112
Mackay QLD, AU
4/13/2018 6:34am
My mate and I both have 2018 model Husqvarna MX bikes and we have both bent bout bar mounts. My mate has the Ride engineering bar mount, to me it sets the standard that all else are judged off, next would be the Fastway Bar mount, it looks solid as a rock and then theres the Luxon bar mount, new on the scene so haven't heard much but looks really nice, for sure if the new husky's didn't have billet Neken clamps already i would be thinking hard about their triple clamps.
I think I'm going to go the Fastway mount tho,it looks tough as.
Moto520
Schaumburg, IL, USA
4/13/2018 8:09am
Those Luxon mounts look impressive!
Luxon MX
San Diego, CA, USA
4/13/2018 12:30pm
Anything is better than 2016 stock mounts, they bend if you look at them funny! 2017-18 are better, but not that great. The concept of the 2016 mounts, a solid lower mount, is very good but poorly executed. It just needs to be strong enough to handle the loads. A solid top mount is the next best thing to a solid bottom, but not ideal.
When things twist from a tip over with a standard mount, everything contributes to twisting. The rubber cones allow movement (as they should) and the whole assembly twists through the bolted interface with the bars on a long lever arm. This is why a solid top mount is not ideal - it allows that long stack up of parts to twist. With a (strong enough) solid lower mount, the only portion that can twist is the bolted interface at the bars so it is much more resistant to twisting. This is why we went with a solid lower, not a solid upper. You can always go with both as solid, but it's a bit overkill. A solid lower also makes it much easier to install as both mounts are already aligned when you tighten everything down.
We've done a lot of analysis and testing of different bar mount designs to arrive at the design we have now. The biggest issue with the Fastway and the Fly mounts linked here is that they're just a rectangular box structure. That's about as weak as it gets when it comes to structural shapes! Our design is indeed a box structure, but adds a truss-like support under the bars resulting in a much stiffer/stronger structure. Here's a finite element comparison to 2016 stock, ours is nearly 7x stronger. Pink/grey areas in the plots are failure spots (high stress, e.g. bent/twisted):
We've actually reduced the strength slightly since that analysis was run as the goal was to arrive at a design that is strong enough to not twist under normal use and tip-overs, but will bend in a major crash. And by major crash, I mean something that's ending your day, not something that you can pick the bike up and keep riding. In that event, something has to give. If you're going to sacrifice something, it's much cheaper to replace one part of the bar mounts than a triple clamp or forks!
The Ride engineering mount isn't bad, but they're using a solid upper mount rather than a solid lower as I mentioned above. They're using 4 M6 bolts rather than the 2 M8 bolts most use, which will help reduce twisting slightly that gives ~10% more clamping force on the bars. But now you have twice as many bolts to tighten for only a 10% increase that would have come much easier with a solid lower mount.
Regardless, whichever one you choose is almost certainly going to be better than stock!
Digger29
Oxford, MA, USA
4/13/2018 12:49pm
I twisted the mounts very easily on my first 2 450FEs and to solve that problem I went with Xtrig PHDS mounts on last yrs and this yrs. Much beefier and have more movement with the elastomers.
Luxon MX
San Diego, CA, USA
4/13/2018 1:21pm
We did some back to back testing with our mount design (rubber mounted same as stock, just different mounts), the Xtrig mounts, and solid mounts. The rider feedback and vibration data didn't really show any clear advantage to the Xtrig, plus the Xtrig mounts are twice the weight of our design. One thing to note is that while the Xtrig mounts have large elastomers which allow good movement under impact, vibration damping and movement in other directions is rather limited by tiny rubber cones internally. Here's a cross section compared to stock style mounts (the small rubber cones I mention are red, under the green piece):
Being the the rubber is much closer to the bars on the Xtrig, it takes a lot more of it to get the same movement as the stock mounts with the rubber further away. Not trying to bash the Xtrig stuff as they're good mounts, but we found the stock style offers the same performance at half the weight, so we stuck with that for our products.
4/15/2018 4:28pm
I’ve been running the Ride Eng mounts on my bikes and really like them. Definitely the standard for all others to be judged to.
CarlinoJoeVideo
Portland/Los Angeles, CA, USA
4/15/2018 5:51pm
Digger29 wrote:
I twisted the mounts very easily on my first 2 450FEs and to solve that problem I went with Xtrig PHDS mounts on last yrs and...
+1 for the PHDS
Lynch
SE
4/15/2018 11:23pm
Do these fit in stock 2018 clamps? And if you know do they fit the newer factory edition/19 models?
Digger29
Oxford, MA, USA
4/17/2018 6:36am
Yes, they the Xtrigs fit the 16-18s and this is my new 18.5 factory edition so they'll definitely fit the 19 models as well.
Lynch
SE
4/17/2018 1:14pm
Thank you Digger, now just gotta play the waiting game until the 19' models come to Sweden.
Digger29
Oxford, MA, USA
4/17/2018 4:01pm
No problem. It was just like the rumors good and bad and then the waiting game for my new factory edition.
yz763
Altamonte Springs, FL, USA
12/28/2021 3:47pm
I just got my new Luxon bar mounts and these things are trick! Titanium hardware….sick!! How the hell do I get the stock KTM mounts out of the stock clamps?
willbilly
Corpus Christi, TX, USA
12/28/2021 4:57pm
After you remove the bars loosen the large bolt on the bottom while holding the top bolt with an Allen.
Luxon MX
San Diego, CA, USA
12/28/2021 5:11pm
yz763 wrote:
I just got my new Luxon bar mounts and these things are trick! Titanium hardware….sick!! How the hell do I get the stock KTM mounts out...
To remove the bottom half of the stock bar mount, hold the bottom stud (looks like a nut underneath the clamps) with a wrench and loosen the bolts from the top. Do not turn the stud on the bottom, it's just there to be held so it doesn't twist while you loosen the top bolts.
Then you'll have the aluminum stud still in the clamps with the rubber cones around it. It will likely be stuck there and not fall out too easily. Thread the bar mount bolt (that you just removed) in to the stud a few turns and push down on it while you turn the stud back and forth with a wrench. It should work its way out doing that.
Then install our mounts the same as stock, but use anti-seize on the titanium bolts and the correct torque. Instructions are here:
https://www.luxonmx.com/product-luxon-ktm-husqvarna-bar-mounts.html
(scroll to the bottom of the description for pdf link)
yz763
12/28/2021 6:08pm
I should have just bought the whole clamp set. I’ll give these a shot and go from there. Here’s the damage to the stock mounts from a high speed get off.
lumpy790
York, SC, USA
12/30/2021 3:33pm
The bolts are what typically bends. On MXBonz clamps they come with larger OD 8.8 bolts that do not bend
Luxon MX
San Diego, CA, USA
12/30/2021 3:46pm
That's true on the Japanese style bar mounts. But for the Austrian bikes, it's the solid bar mount piece (the lower on 2016 and the upper on 2017+) 99% of the time. It's rare to break a bolt on KTM/Husky, but it can happen in a big crash. And when it does, it bends/breaks across the threads as shown above post due to KTM's design flaw. Lots more details in our blog post:
https://www.luxonmx.com/blog-luxon-bar-mount-fix-ktm-husqvarna-twisting…
sandman768
Saratoga Springs, NY, USA
8/6/2023 7:25am Edited Date/Time 8/6/2023 7:25am
Luxon MX wrote:
That's true on the Japanese style bar mounts. But for the Austrian bikes, it's the solid bar mount piece (the lower on 2016 and the upper...
Reviving old thread, I bent my upper 2022 ktm350 clamp in a high speed crash, does Luxon offer a Vital discount code? Thanks.
Luxon MX
San Diego, CA, USA
8/6/2023 8:03am
VITALMX
sandman768
8/6/2023 8:05am Edited Date/Time 8/6/2023 9:34am
Luxon MX wrote:
VITALMX
Awesome…thank you ..just placed my order, free shipping also👍…
Bruce372
8/6/2023 4:28pm
Luxon MX wrote:
VITALMX
Awesome you are supporting Luxon, they are top shelf stuff.... Apologies for not replying to your post on my xtrig for sale, I forgot to reply they are no longer available.
Hope you are doing ok from crash!
sandman768
8/6/2023 4:49pm Edited Date/Time 8/7/2023 11:27am
Bruce372 wrote:
Awesome you are supporting Luxon, they are top shelf stuff.... Apologies for not replying to your post on my xtrig for sale, I forgot to reply...
All good…I did see they were sold… Luxon on here all time interacting with us goons, worth a purchase 👍 also heard it’s free Ti week😜
jrmy_1
Sanford, MI, USA
8/21/2023 1:37pm
How much stronger are the Luxon design over the Fastway or Fly design?
Post a reply to: 2018 KTM Bar Mounts
