Grapevine, TX, USA
5/7/2022 10:52pm
After a lot deliberation, research and thinking I finally decided on what I wanted to do for my next two stroke build. I decided on a couple of TM's because I feel they have the most advanced two stroke engines in the world right now. They dominate the kart racing circuit and have won a lot of world championships over the last 10 years.
I decided to buy a 250 and a 144 and build both of them at the same time. One of the main reasons I decided to buy both bikes now is because I have heard rumors that TM Racing is going to EFI on all of the two strokes in 2019 and I really prefer the carbureted version. If 2018 was going to be the last year of the carbureted bikes, I definitely wanted to grab one of each size while I still could.
After going over these bikes with a fine tooth comb and trying to figure out what I want to change and modify, I have a newfound appreciation for the attention to detail that TM puts into their machines. The design, craftsmanship and attention to detail of these bikes is second to none and simply amazing.
Below are a few of the preliminary pics and a few of the details that make the TM Racing machines special.
Check out how the intake looks in this pic and the angle of the reed cage:
Looking forward to your build.
They have to be fairly strong, I have watched them pull a LOT of holeshots at Glen Helen and that doesn't happen without HP at that track.
This is the area behind the footpeg bracket. It is CNC machined to remove all of the excess material.
The footpeg brackets are really light as well.
One thing you could try and find - a hub that doesn't use half of the worlds supply of sprocket bolts like the stiocker - i.e a 6 bolt hub instead. Should be able to save some weight with that.
Any chance of a picture to show how the fuel tank allows the ram air system to work?
You can see the bolt placement in this picture:
I don't know what the pricing is in US but TMs are actually cheaper than the KTM/Husqvarna and the Yamaha in Europe(at least in Finland) the 250 2-stroke starts at 8000€. The KTM is 8700€ and Yamaha 8600€. You would think that there would be lots of TMs at the tracks but unfortunately there aren't for some reason.
Anyway subscribed!
Post a reply to: Full Tilt TM Racing Two Stroke Build(s) Update: Dirt Magazine "Two Stroke Tuesday"
