Engine rebuild cost
I’m not looking for exact numbers, but do you guys know a ballpark number to rebuild the top and bottom end with new crank for a 2025 KTM 250F
uncledaddy69
Huntington Beach, CA, USA
7/26/2026 11:37am
Are you asking so you can bid it lower than everyone else?
7/26/2026 11:38am
Make a parts list. Go on RMATV and add to cart. Look at cart total.
TooOld4WFO
Fresno, CA, USA
7/26/2026 11:38am
I literally just copied and pasted your question into the oracle.
AI Overview
A ballpark number for parts alone to do a full top and bottom end rebuild—including a new crank assembly, piston, gaskets, and main bearings—typically ranges from $800 to $1,500+, while paying a shop for full labor pushes total costs between $1,500 and $2,500+. [1, 2, 3]
Parts Breakdown (Estimated Costs)
  • Crankshaft assembly / Hot Rods kit: $350 – $700 (OEM KTM crankshaft assemblies run higher, around $700–$950; aftermarket options like Hot Rods or Wiseco are more budget-friendly).
  • Piston kit (piston, rings, pin, clips): $150 – $300.
  • Gaskets, oil seals, and main bearings: $150 – $350.
  • Additional wear items (timing chain, valve check/shims if needed): $50 – $150. [1, 2, 3, 4, 5]
Labor and Extra Costs
  • DIY (Do It Yourself): Free labor, but requires specialty tools like a case splitter, crank puller, and flywheel puller.
  • Shop Labor: $500 – $1,000+ depending on hourly shop rates and whether you bring them just the loose engine cases or the entire bike.
  • Hidden/Contingent Costs: If metal from a failing bottom end or top end has scored your cylinder bore, re-plating or replacing the cylinder adds $250 – $500. Four-stroke head work (valves, springs, seats) can also add significant cost if the top end is heavily worn. [1, 2, 3, 4, 5]
14
7/26/2026 12:08pm
Bottom end complete ,and top end complete incl all head work. Don’t miss anything . Even timing chain, and adjuster. Oil pump.water pump kits.valve guides, seats ,valves etc
If you want to do it again later , miss some items to save a few bucks.
Do it the one time ….order everything that is used to make the engine run properly.just remember.when you bought the bike the engine had all new parts and it lasted xxxx number of hours.
7/26/2026 1:00pm
Ha, I don’t do engines. Just trying to figure out what this will cost to get someone to rebuild it. Thanks for replies
cloud41
Chicago, IL, USA
7/26/2026 4:22pm
3k+
NicNak
Palm Desert, CA, USA
7/26/2026 5:26pm
For a KTM the costs of parts are much more than jap bikes. $2500-3k for a KTM rebuild for sure.
A Kawi 450 you got about $800-$1000 in bottom end parts - excluding transmission. $450 in top ends parts.
Crank is $470 or so for a KX 450.
KTM 250f is $980 just for the crank.
7/26/2026 7:13pm
Exactly what I was looking for, thank you guys.
NeedMoto
Penn Valley, CA, USA
7/26/2026 7:17pm
cloud41 wrote:
3k+
This is correct ^^^
EAmato88
Egg Harbor City, NJ, USA
7/27/2026 4:05am
you dont replace the crankshaft on a KTM, you send it out to be rebuilt by a professional. You will save about $300 doing it this way.
lumpy790
York, SC, USA
7/27/2026 6:30am
EAmato88 wrote:
you dont replace the crankshaft on a KTM, you send it out to be rebuilt by a professional. You will save about $300 doing it this...
You dont have to send a crank out your local shop can do it.
EAmato88
7/27/2026 7:33am Edited Date/Time 7/27/2026 7:33am
Any time you "sub" something out, IE not doing it yourself, would be considered "sending it out", That being said, there are A LOT of people that no longer have local competent motorcycle mechanics close to home. Ive been in the business for 20 years now, Ive had guys drive from as far as West Virginia for stuff because they dont have a trusted mechanic anywhere close.
captmoto
Rancho Cucamonga, CA, USA
7/27/2026 9:04am
Maybe. Should probably ask. They might give you the bullshot that it's cheaper to replace.
Broseph
Stevenson, WA, USA
7/27/2026 10:41am
TooOld4WFO wrote:
I literally just copied and pasted your question into the oracle.AI Overview A ballpark number for parts alone to do a full top and bottom end rebuild—including...
AI Overview
Why pollute the forum with garbage AI info?
7/27/2026 11:38am
How is it 3k for an engine rebuild? Is that price including labor or DIY?
Phillip_Lamb
ORANGEVALE, CA, USA
7/27/2026 2:21pm
call for a local engine builder, last time i  paid a guy for a complete topend i wanna say it was around 800 labor not counting parts. but that was like 8 years ago? YMMV
walent215
Ridgecrest, CA, USA
7/27/2026 5:54pm
https://www.instagram.com/parapros
Contact Brad
I believe you’ll be hard pressed to find a better option
He is next level and craftsmanship /pricing won’t be beat
btroxler
Saltillo, MS, USA
7/29/2026 2:34pm
Labor and Parts ~$3500, if you can actually buy a new engine from KTM for $3750 that's what I would do, keep the other as a spare or sell parts cases head etc.
bosswool2800
Jackson, TX, USA
7/29/2026 3:28pm Edited Date/Time 7/29/2026 4:07pm
AI Overview
The down votes came from the “case splitter”
Timo
Wichita, KS, USA
7/29/2026 3:44pm
Did it blow-up or is this preventative maintenance? That makes a big difference. How many hours are on it? I routinely put 120-150 hours on 250f top ends, never had to replace a 4-stroke crank. Don't let online people who change oil every 30 minutes, clean air filters every lap, and rebuild their engines every 12 hours scare you into over maintaining your bike.
I would do piston, rings, wrist pen, cam chain, and gaskets. There are people out there with 1,000 hours on ktm cranks.
Post a reply to: Engine rebuild cost
