Costa Mesa, CA
Friend of mine had his 2019 KTM 250SXF lock up the other day and he has since split the motor and identified a bad rod bearing.
He bought the bike used with about 50hrs on it after a recent engine rebuild due to being submerged/flooded/dropped in a river crossing. The bike ran for about 30 hrs before seizing on the big end. The guy that split the motor seems to think that the crank was pressed incorrectly/too tight.
My friend that owns the bike is probably going to sub the crank rebuild, so who does this type of work and what does it cost?
MSRP is $956 for the OEM part.
If interested you can text or call 760-608-1688
Or Chris Blaise. https://blaisracingservices.com/
100.00 labor for crank rebuilds 1-2 day turn around
pro x rod kits are 150.00 ish for the rod kit
I used Ken Oconner Racing for a Prox rod rebuild on a YZ250 2 stroke crank. Very reasonable pricing. Some of the others mentioned I'm sure do good work too. But go to someone that does a TON of them. That's the key. They do them every day. Ken and Crankworks do just that.
Post a reply to: KTM 250 350 Crank Rebuild
