MOTO, IL, USA
5/4/2020 6:04am
So what's everyone's opinions on what's the best coolant out there? I've used both Engine Ice and ZipTy stuff in the past without any issues....just curious if there's something even better out there I'm not aware of.
Thanks1
Thanks1
If your bike is in IL and you aren't completely draining the fluids each winter before freezing temperatures set in, you'll need an antifreeze, so choose wisely.
Free shipping: VITALMX
Also, a propylene glycol coolant like Engine Ice will work a little better at the extreme end of the liquid phase (it takes a little longer to boil) than ethylene glycol.
Oh yeah, I run Rotella T too....
If you live in an area with freezing winter temps, just be conscious of the weather and convert back to an anti-freeze coolant before wintering.
For the guy who just likes to play ride and maybe not by-the-book in terms of maintenance, just run Auto store coolant 50:50 that is safe for Alum. components.
Good article: https://www.redlineoil.com/content/files/tech/WaterWetter%20Tech%20Info…
Another: https://www.thumpertalk.com/blogs/entry/210-three-easy-ways-to-improve-…
Water boils at 212 so raising the boiling temp 40 degrees is more than just a little difference
EI has been in the Moto Hose bikes since EI began.
Why not support those that support the sport....or at least the Vital message board.
EI just went on my parts list for the week. Your welcome Dave - sorry it took so long.
Did you see the Penn & Teller video where they were getting college students to sign a petition to ban Dihydrogen Oxide?
"It's in our lakes & streams already!!!"
Some of my favorites:
I suggest you go back to junior high and re-take chemistry 101 !
"dihydrogen monoxide", i.e H2O is just distilled water !
pH 0 is the most acidic you can find (except in the case of superacids, which can actually have negative pH), and ph 14 is the most basic ! So a pH of 7 is absolutely neutral... xD
Now, in the case of most ion-exchanged de-ionized water, most of the time they're slightly acidic, i.e 6-6.5.
So just to be sure, you should add a little pH 7 buffer (found in most aquariophile stores) as to avoid corroding aluminium.
If you really wanna be bulletproof, mix 1/10 coolant (to have the wetting capability) with 9/10ths deionized water, and adjust pH to 9 by mixing in the right amount of pH7 and pH10 buffers...
(why 9 ? Because basic solutions do not corrode metals like steel or aluminium. People like me who've had to run industrial boilers know that their feedwater is always adjusted to a pH of 9 to 11 for this very purpose, since the higher the temperature and pressure, the faster it corrodes at neutral pH)
I'm reelin em in even 3 years later!
Post a reply to: Best Coolant?
