Understanding base and mid valve function
swatdoc
Temecula, CA, USA
Hey guys
im trying to understand front suspension a little better. I find all kinds of info out there on what a base vale is and what a mid valve is. A lot of info on how they work.
what I can’t find is how changing them affects the damping.
what is the difference between going softer or stiffer on the base valve vs the mid valve? In what way does the mid valve affect the suspension vs the base valve? Obviously they both affect compression damping, but in what way? How are they different?
And it seems like the compression clicker only affects the base valve, correct? The only way to change the mid valve is changing the shim stack, right?
thanks for any help with me understanding this
skyrebel88
New Fairfield, CT, USA
12/20/2022 8:08am
I recently did some of this research and messing around with my shim stack myself on my bike, This is what i found.
Removing shims from the mid valve makes the base valve have to work "harder" if you want to think of it that way. You can feel a rubbery kind of feel. I think this is because of the spring effect in the base valve. When you remove shims from the base valve the mid valve will have to do more of the work. The effect is a crisper feel. I believe they have to be valved to be "equal" in how much work they each do. It shouldn't be one or the other doing most of the work.  Thats all I know.
If you were looking for valving advice, remove one face shim on each and give that a try if you want to go softer.
swatdoc
Temecula, CA, USA
12/20/2022 12:05pm
https://youtube.com/playlist?list=PLHSgGy8X-DgWVWBw-yR10u0tFgi8qQAG8
Check this guy at YouTube out. Great content how suspension works. The link is his tech-playlist.
Yes I’ve seen his videos. Again they kind of explain what each do, but not really what changes when you modify them
the issue I’m having is that my forks are a little too plush right now. It seems they blow thru the stroke too easily. I am gradually turning in my compression clickers, but at some point it’s gonna better to modify the shim stacks. And the clicker just changes the base valve. What am I missing by not addressing the mid valve? If you change one is it best to change the other as well?
wrc777
Greenwood, IN, USA
12/20/2022 12:55pm
A lot more oil moves through the midvalve so it should be a bigger lever to change. If midvalve is too stiff and base too soft you can get cavitation.
Kidkawie
ქუთაისი, GE
12/22/2022 4:36pm
Your springs need to be correct before any valving.  Also, you cant stiffen what you have without shims, so buy some and add 2 face shims to your base valve.  Start from there.
swatdoc
Temecula, CA, USA
12/22/2022 4:42pm
Kidkawie wrote:
Your springs need to be correct before any valving.  Also, you cant stiffen what you have without shims, so buy some and add 2 face shims...
Good advice. I just stopped by today and talked with JB - he recommended going with slightly stiffer springs too, so that’s where I’m starting
m21racing
Reno, NV, USA
12/22/2022 6:20pm
What forks and what bike is it?
swatdoc
Temecula, CA, USA
12/22/2022 8:10pm Edited Date/Time 12/22/2022 8:11pm
‘22 KTM SXF 250
Raven cartridges
SWMX
Murrieta, CA, USA
12/23/2022 12:15am
Stop by AEO//REP and try to bend an ear…
UGOTBIT
Upstate, NY, USA
12/23/2022 6:58am
Mid valve is where the magic is.
Broseph
Stevenson, WA, USA
12/23/2022 7:56am
swatdoc wrote:
‘22 KTM SXF 250
Raven cartridges
I just did a set if those. Had to stiffen both the base and the mid before they worked well.
Do you know what the valving looks like right now? Are you able to post it?
Kidkawie
ქუთაისი, GE
12/23/2022 7:55pm
Personally, I go a bit heavier on the springs and lighter with valving.  Guys bikes setup for 30# heavier than me seemed to work better.
bvm111
Las Vegas, NV, USA
12/24/2022 3:41pm
You can make a fork work with no midvalve stack and just a pop off valve… but it will be very one dimensional. Once I learned to think of the base valve as just that the base that works for low suspension velocity situations. The midvalve is the speed sensitive or HSC for the fork during high suspension velocity situations such as whoops and consecutive jumps or rhythm sections. Two much midvalve damping and you get the dreaded mid stroke harshness too little and it will wallow down into the stroke and things get ugly that way too because there is only so much the base can do. It isn’t rocket science and as others have suggested pull your valve stacks apart and measure, take pictures, then order some additional “base shims” make sure they are the correct thickness as the rest and make some changes. Now the fun part, test, take notes, think about the direction you went and what changes you feel or can’t. Now guess what … do it all over again and welcome to the rabbit hole of working on your own suspension 😂
swatdoc
Temecula, CA, USA
12/24/2022 5:42pm Edited Date/Time 12/24/2022 5:44pm
swatdoc wrote:
‘22 KTM SXF 250
Raven cartridges
Broseph wrote:
I just did a set if those. Had to stiffen both the base and the mid before they worked well. Do you know what the valving...
Here's the sheets from MXT showing the base setup for MX, and then the setup they did for me.
I didn't note before, but I'm about 250 with gear, and race in the 60 Novice class
Broseph
Stevenson, WA, USA
12/24/2022 6:00pm
swatdoc wrote:
‘22 KTM SXF 250
Raven cartridges
swatdoc wrote:
Here's the sheets from MXT showing the base setup for MX, and then the setup they did for me. I didn't note before, but I'm about...
I’m running the same mid-valve stack as you and had to reduce the float to .05mm before the wallowy feel went away. That last little bit made a big difference. Went from bottoming everywhere to having 2” left with just that small change.
Adding an 8.10.10 shim between the pair of 8.10.20s would get you there.
swatdoc
Temecula, CA, USA
12/24/2022 7:07pm Edited Date/Time 12/24/2022 7:09pm
Broseph wrote:
I’m running the same mid-valve stack as you and had to reduce the float to .05mm before the wallowy feel went away. That last little bit...
Excellent thanks!!
what base valve stack are you running?
Broseph
Stevenson, WA, USA
12/24/2022 10:04pm
swatdoc wrote:
Excellent thanks!!
My base valve stack is just Mx Tech’s 6-face shim offroad setting. So quite a bit softer than yours. This is a desert setup, so needed the small bump compliance of the offroad base but also g-out and whoop holdup of the stiffer mid.
swatdoc
Temecula, CA, USA
12/25/2022 4:54pm
Ah ok. Thanks again. I will definitely try that on the mid valve
FWYT
San Diego, CA, USA
12/26/2022 8:15am
Love these knowledge-sharing tech discussions. Taking notes. Carry on.
12/27/2022 11:10pm Edited Date/Time 12/27/2022 11:24pm
The base valve and mid valve work together to create a net damping force. The base valve only provides damping when oil is moved through it via the damping rod displacing volume as it slides into the damping chamber. The midvalve provides damping immediately as the fork begins to move because the mid valve is pushing "through" the oil. An important function of the base valve is to provide significant resistance to the oil flow so that it remains under positive pressure and doesnt cavitate as the midvalve is pushing through it. Base valve must create more positive pressure on the oil flow than any negative pressure behind the moving midvalve to avoid oil cavitation.
Most of the "control" is tuned in the mid valve on modern forks because it provides roughly 2.5x-3x the damping force vs the base valve. The base valve stack  is often spec'd against the mid valve stack so that it produces enough resistance to prevent cavitation. A stiffer midvalve requires a stiffer base valve to prevent cavitation.
Because your damping force = base + mid, your clicker adjustments are really just adjusting that resistance on the base valve by allowing more or less oil to flow through, and this effects the entire damping force. Your fully soft compression clicker setting still should provide enough oil resistance to prevent cavitation (which would mean drastic loss of damping force and could be very dangerous).
There are some kits out there like the Kreft RC valve that allows adjustable mid valve settings, as well.
swatdoc
Temecula, CA, USA
12/28/2022 9:38am
Good explanation thank you
Broseph
Stevenson, WA, USA
4/9/2023 6:53am
Did you ever get these Ravens working better? Are they still blowing through the stroke?
swatdoc
Temecula, CA, USA
4/9/2023 10:05am
Finally sent them back to MXT for revalve. I was gonna get them done locally but discovered that Ravens and Blackjacks require a special made tool to disassemble the cartridges. No MXT dealer near me has the tool, and they don’t plan on getting it because it’s a $500 tool only from MXT.
so I sent them out and just got them back about 10 days ago. Had a race scheduled with OTMX in NV, but the race got canceled because the track was flooded. So haven’t tried them yet, but they do feel more firm just pushing on them. Anxious to try them out.
I do wish I’d have known about the special tool requirement - I probably would have gone with a different setup that everyone can work on. Any time I want them serviced I’m gonna have to send them out with $100 in postage and about 3weeks turnaround
wrc777
Greenwood, IN, USA
4/9/2023 11:13am
swatdoc wrote:
Finally sent them back to MXT for revalve. I was gonna get them done locally but discovered that Ravens and Blackjacks require a special made tool...
So you can’t even change the oil in the cartridge without the special tool?
swatdoc
Temecula, CA, USA
4/9/2023 11:21am
Yep that’s my understanding
again - wish I’d have know that prior to dropping $1500
Broseph
Stevenson, WA, USA
4/9/2023 11:50am
I feel kind of the same way. Ended up making my own tool to service them and it works fine. But it would be nice if they were more normal in that area.
Regarding the valving, the midvalve change I posted above helped a lot, but they still move too much in the mid-stroke. I’ll be curious to hear what you think of the new valving. Did MX Tech include a spec sheet with the new setup?
swatdoc
Temecula, CA, USA
4/9/2023 12:27pm
Yep:
EB611C26-6B6C-4B42-9C37-645DFEB1947C.jpeg?VersionId=J9nvuLlswZyOaXKNSXsKgmFTVV5nfc
swatdoc
Temecula, CA, USA
4/9/2023 12:28pm
Updated
6C8278BE-00E2-486B-96E6-C9D262987C27
swatdoc
Temecula, CA, USA
4/9/2023 12:29pm
How tough was it to make your own tool? That would save me a lot of time and expense
4/9/2023 1:16pm
Jeff at Over the Top Suspension in Visalia, CA has the tools to disassemble the MXT cartridges.  He actually put Blackjacks in my 17 FC350- your old Vintage inspired build.
Post a reply to: Understanding base and mid valve function
