2013 YZ 250 ( 2 Stroke) Head Questions
So I know that throughout the years or the yz’s they have changed he heads multiple times. So I’m just curious if there is a stock yz 250 head that will fit on my 13, that will give me a little more bottom end?
cwtoyota
Tacoma, WA, USA
8/21/2019 11:56am
Duece90Six wrote:
So I know that throughout the years or the yz’s they have changed he heads multiple times. So I’m just curious if there is a stock...
The 2003 to 2010 USA model head will have more compression than all the others.
You are better off sending a head to a good engine builder to have it machined for tighter clearance.
If you run race fuel, you can bump the compression a bit beyond the 2003 - 2010 USA spec.
I start with the 1999 - 2002 heads and machine them to my own spec.
8/21/2019 6:05pm
cwtoyota wrote:
The 2003 to 2010 USA model head will have more compression than all the others. You are better off sending a head to a good engine...
Yeah I knew all that but just wanted to make sure there wasn’t a stock head out there that would do the job, before I start send mine off to get it milled! Thanks for the reply 👍🏼👍🏼
Hcallz5
8/21/2019 8:12pm
RK Tek did a good job on my Husky, You can send your head in or buy one of his trick anodized heads.
8/22/2019 10:51am
Yeah I know the RK Tek guys personally and that’s what I’m probably going to be doing 🤘🏼👍🏼
Rick_Art
Oklahoma City, OK, USA
8/24/2019 8:45am
I have 2002. Yz250, can I get more compression with machine work, or is it not worth it?
soggy
8/25/2019 8:52am
depends what your goals for the engine are. if you really bump it up you will need to run race gas
cclay47
Roseville, CA, USA
8/25/2019 4:00pm
RB Designs in Oregon did my YZ250, best $100 I’ve spent on the bike.
funkj62
Monett, MO, USA
9/3/2019 9:11pm
Cutting the head reducing the cc will raise compression and will deliver more power/response. If your goal is to change the powerband and add more bottom end, reducing the cc isn't they way to accomplish it. The shape of the cumbustion chamber and the squish band width and break area will have some effect on the powerband. Port timing and expansion chamber will directly effect where the power is delivered.
Hudd_421
9/4/2019 10:05am
I've heard of people using the YZX head to reduce compression and give a more useable power. My biggest issue with the YZ is the detonation but I want to be able to run pump gas. I've heard that getting the squish set properly is the best fix.
cwtoyota
Tacoma, WA, USA
9/4/2019 2:01pm
Hudd_421 wrote:
I've heard of people using the YZX head to reduce compression and give a more useable power. My biggest issue with the YZ is the detonation...
You're on the right track and that's what I was hinting at with my post above. The squish is around 0.072" to 0.075" on a stock bike. I cut them right down to 0.044" - 0.045" with a standard height OEM or Wiseco piston (not a GP or other weirdo stuff).
I also open the dome up just a bit on the 2003 - 2010 head so the compression doesn't go too high.
Even if you run race fuel, you may not want to go below 20cc of total head volume as it begins to be very barky on part throttle which can mess up your corners on harder packed tracks. Retarding the timing can tame some of the bark.
With pump fuel, just get the squish cut and stick with stock head volume of around 21.5cc (which means you have to enlarge the dome after removing material to set the squish).
I'm a machinist, so I just cut my own heads and have had excellent results.
cwtoyota
Tacoma, WA, USA
9/4/2019 2:02pm
funkj62 wrote:
Cutting the head reducing the cc will raise compression and will deliver more power/response. If your goal is to change the powerband and add more bottom...
On that note, the Bill's pipe adds a lot of mid-range torque to this bike and doesn't really kill the top end pull. The smoothest pipe (least mid range and longest pull) is the FMF Factory Fatty.
slipdog
Nor Cal, CA, USA
9/4/2019 6:12pm
cwtoyota wrote:
You're on the right track and that's what I was hinting at with my post above. The squish is around 0.072" to 0.075" on a stock...
.045" @ 21.5cc is where I always set them for pump gas as well.
funkj62
Monett, MO, USA
9/4/2019 6:13pm
Bottom line is you need around a 9.5:1 compression ratio with about a 60% squish band and ext port timing around 180° with a 28-30° blowdown phase and a good low_mid range pipe with two stage reeds. You put that combo together and you will have the bottom end your looking for.
funkj62
Monett, MO, USA
9/4/2019 8:32pm
Hudd_421
9/19/2019 8:35am
Thanks Slip!
Can you please explain real quick the difference between squish and dome volume? For some reason I thought it was one in the same. Do I have to do the solder test and send in to a engine builder? Or can I just say, .045" at 21.5 cc?
slipdog
Nor Cal, CA, USA
9/19/2019 1:48pm
Hudd_421 wrote:
Thanks Slip! Can you please explain real quick the difference between squish and dome volume? For some reason I thought it was one in the same...
Thanks Slip!
The squish "clearance" is how close the piston gets to the squish band of the head at top dead center. That area is part of the total volume of the head along with the dome. Decking the head brings the piston closer and decreases the amount of clearance but the total head volume is now smaller so the compression ratio goes up.
Ideally, you want to always take a measurement with solder to know for sure where you sit stock but like CW said, most I've seen seem to be .074"-.078" so some builders may have just a general cut of .030" if there is no measurement to go from. I have seen as high as .081" so the solder test would tell the tuner they could go a little more than normal.
mx617
Kamloops, BC, CA
2/5/2026 9:22am
Resurrecting this thread, sounds like there's smart guys in here😆
Ive got an 06 yz250, and need a new head.  Stock for that year is the 5up, but I've found one from a 2000 that's the 5cu.
From what I can tell that will bolt on just fine, but does anyone know if there's a meaningful difference between them?
At this point the bike is just trails and cruisy mx as I'm old and fat now. Not super worried about max performance, more so worried if it would cause reliability issues.
Thanks!
cwtoyota
Tacoma, WA, USA
2/5/2026 9:41pm
mx617 wrote:
Resurrecting this thread, sounds like there's smart guys in here😆Ive got an 06 yz250, and need a new head.  Stock for that year is the 5up...
Thanks!
Strictly motocross model (not the X model)
1999 - 2002 had larger chamber volumes.
2003 - 2010 USA heads have a smaller chamber volume.
2011 USA models were updated to the world wide spec with the larger chamber volume, neutral sensor, I think the jetting changed, etc.
The 2000 head is a good starting point.  I'm not staring at my notebook, but I believe they are 21.5cc volume.
The larger volume spreads out the power and mellows the hit when compared to your USA model 2006.
That spec I posted previously is pretty damn good if you can do the work, or have a local shop that can do it for you.
digger
Upstate, NY, USA
2/6/2026 1:53am
Thanks!
I believe the 5CU head has a combustion chamber volume of   22.0cc
The 5UP is 21.0cc, and the 5WM 21.5cc. Note: the 5WM head off a 250x is 23.5cc
I use a 5UP head on my 24' 250YZx. I mix a little of 110 race fuel, 1-gal to 4 gal of 93, just for insurance against detonation,
mx617
Kamloops, BC, CA
2/6/2026 9:10am
cwtoyota wrote:
Strictly motocross model (not the X model)1999 - 2002 had larger chamber volumes.2003 - 2010 USA heads have a smaller chamber volume.2011 USA models were updated...
That's great, thanks for the info - exactly what I needed.
mx617
Kamloops, BC, CA
2/6/2026 9:11am
digger wrote:
I believe the 5CU head has a combustion chamber volume of   22.0ccThe 5UP is 21.0cc, and the 5WM 21.5cc. Note: the 5WM head off a...
Awesome thanks!  I might go the race fuel route as well, I definitely had some pinging. Check out the bottom edge. 1000062949
skypig
Caloundra, AU
2/8/2026 4:33pm
I’m a super basic machinist.
Would be interested in cutting some head inserts. RZ500 x 4. Potentially volume to suit unleaded fuel.
Is it normally done on a lathe? Any tips on getting the curved shape?
Probably the mill for setting the final squish?
Thanks for any info
And thanks for not saying “if you have to ask….”
cwtoyota
Tacoma, WA, USA
2/8/2026 6:18pm
skypig wrote:
I’m a super basic machinist. Would be interested in cutting some head inserts. RZ500 x 4. Potentially volume to suit unleaded fuel. Is it normally done on a...
Thanks for any info
Most heads have a centered spark plug hole, so you can do them on a lathe with zero problems.
Basic machinist... You need to know how to "dial in" on the gasket surface or risk making a crooked cut.
You also need to have good judgement on how to securely hold a part and create a reasonably good surface finish for the gasket.
Take small cuts and frequent measurements... It's hard to put material back on the part after you cut off too much.
A threaded "mandrel" can be a decent way to hold a head with a centered spark plug hole.
Cutting a flat gasket surface is pretty easy with a face tool and the cross-slide.
You can cut a squish band by setting the "compound" on your lathe to the angle you want.
Cutting a nice dome is a bit more complicated.
If it was a big deal to get an exact, repeatable dome, I would put them in the CNC machine.
Since I just do my own heads and occasionally help friends or local kids, I do them in a 1960s Clausing manual machine.
I have a bunch of different pieces of high-speed steel tooling that have various curves ground into them and I just do the domes by eye.
After cutting, I lap the gasket surface up to 600 or 800 paper, then check the volume using a cheap syringe and plexi-glass with two small holes drilled in it.
Squish band width matters.  I'm not the expert on two stroke porting and head design, so I'm not going to try to explain that side of things.
There are some resources (books, videos, software) out there that can help inform squish band width and calculate squish velocity should you decide to play with that stuff.
The YZs are perfect bikes to learn on because the parts aren't super rare and expensive.
Be prepared to run quality fuel and tweak your jetting.
Get a notebook and write down each thing you try, what you change and the riding conditions that day.
You can take a cast of a chamber using wax, epoxy (use mold release), or foam to get a better visual of the shape.
Search the internet for the bold keywords above if you need to.
Vet57
BRO Town, MA, USA
2/10/2026 12:16am
cwtoyota wrote:
On that note, the Bill's pipe adds a lot of mid-range torque to this bike and doesn't really kill the top end pull. The smoothest pipe...
DEP for the win
cwtoyota
Tacoma, WA, USA
2/10/2026 11:08am
Vet57 wrote:
DEP for the win
I have a couple of DEP pipes for the YZ250 and they're great!
The Bill's makes a little more torque and I seem to get better starts.
Post a reply to: 2013 YZ 250 ( 2 Stroke) Head Questions
