HR
3/20/2022 12:24pm
I have recently purchased this kit and the bike is currently in the building process. Does anyone have experience with it?
I tried contacting CW for a map, but they said they don't have one or should I say they had one, but that bike is no longer with them so. I assume it needs more fuel, but if anyone has some map for it and would share it, I would really appreciate that.
An engine is an air pump. Increasing the volume of air that moves through the engine per cycle, like from increasing the displacement, would require more fuel to match the increased air flow. A carb or open loop fi system would not have the ability to compensate on its own.
Are there other companies like Tokyo Mods that have ready to go tunes?
Tons of products are marketed as lighter, faster, more power, the best! Etc
And have zero info on how much lighter, how much more power, zero details.
Our aftermarket industry in largely a joke in those details. There are exceptions of course but largely that’s how it is in Mx.
The bigger bore allows more air into the cylinder in the same amount of time as the smaller bore did.
The resulting increased speed of the air lowers the depression over the carburettor's main nozzle and with the difference between atmospheric pressure acting on the fuel in the float bowl and the low pressure in the venturi now slightly greater, more fuel is drawn in.
Also, the higher air speed may also improve the mixture quality with better atomisation and less wall wetting, which may also contribute to a leaner setting- or the original jet being retained; which is the same thing.
*An engine pumps air- and so do you. That cliche you used is superficial.
An engine is more a high temperature, high speed and high force chemical reaction chamber.
It's amazing they even make different jet sizes the way you're talking. I guess the engine just takes whatever it needs and the orifices are meaningless.
Hahaha, no, it's just an air pump. Pumping more air volume means you need more fuel to maintain the same air:fuel ratio. You can make it sound like a fission reactor if you want, but I'm afraid it's just not as complicated as you want it to be.
Unfortunately still nothing, no one has the map...
Short of a dyno.. seat in the pants, looking at a spark plugs if you want, and following the same logic I think could get you pretty close. Either way you shouldn't be blowing shit up.
Post a reply to: Cylinder Works 270cc kit for YZ250F '20
