Dead Engine Start Tips (In Gear)
ThePizzaCobra
The Garden State, NJ, USA
Anyone have any tricks to quickly starting a bike in gear on a dead engine start? I raced a TOR event last weekend, and got absolute peppered with roost at the start of moto 1 because my 2024 FX 350 did not want to turn over in 2nd gear. Needless to say, I was buried in the back by the time I got going, and I did myself no favors by spazzing out to catch up and repeatedly eating shit. Moto 2 I started in neutral. The bike started right up, but by the time I clicked into 2nd and started moving, I was already behind the line. I’ve owned (4) 350s, and frankly, none of them were easy to start in gear, but it seems to be a necessity if I want any chance at starting in the front. Any tricks?
Here’s me pushing that button, just wearing it:
IMG 0073 6
Bri577
contento, CA, USA
11/25/2025 12:10pm
I remember we used to pull in the clutch, put the bike in gear, rev it up a few times, and then let the engine die without letting go of the clutch.
You have to hold the clutch in until they drop the banner.  This is supposed to hold the clutch plates a little more open, (so I was told).
Seemed like it worked when we did it back in the day,...
19
ThePizzaCobra
11/25/2025 12:12pm
Bri577 wrote:
I remember we used to pull in the clutch, put the bike in gear, rev it up a few times, and then let the engine die...
Makes perfect sense. I’ll give this a shot. Thanks!
3strokemx
11/25/2025 12:13pm Edited Date/Time 11/25/2025 12:15pm
1. swap your buttons, put the start on the left and the kill on the right. Makes it easier to get on the gas.
2. Hold the clutch lever all the way to the bar, don't let it out after you kill the engine (keeps clutch plates from sticking)
3. Practice to find how much throttle your bike likes to fire, some like none, some like a little, some like a lot (mostly 2 strokes)
4. Practice to find which gear works best
5. Practice body position to eliminate wheelie or spinning, weight over the bars vs. weight over the rear.
6. Bike specific strategies you might pursue: upgrade the battery, valve clearances in the middle of specs, roll the bike around to find TDC, temperature, mapping, priming the fuel pump, etc.
Marty1028
Lafayette, IN, USA
11/25/2025 12:13pm
Never had a 4 stroke that started well in gear. Only bikes that do were 2 strokes. Try starting 1 foot up, neutral, ready to shift to 2nd when the flag drops.
11/25/2025 12:14pm
Make sure your bike and clutch are warmed up really good before you get to the line. Also maybe a higher amp battery to get that thing turning over while it’s in gear.
TAUTOG
Mohrsville, PA, USA
11/25/2025 12:18pm
This 100%
Titan1
Lehi, UT, USA
11/25/2025 1:12pm
Make sure the bike/Clutch is warm!
Rev the bike, with the clutch in, and hit the kill switch while the RPMs are high...do NOT let go of the clutch until the banner drops, when you do this make sure the bike isn't trying to roll forward or backward (while sitting there should be no tension on the chain) so the motor is completely free.
I'd always be in 2nd gear as well (but I've always raced 450's but depending on the start you could probably get away with that on a 350?)
While pushing the button, start rolling the bike forward with your feet...so the bike is in gear, starting to roll forward with your feet, while you simultaneously push the start button...
Practice starts a lot...every bike has its little quirks...some like a tiny bit of throttle, some like none...learn what works consistently for your bike.
motojoel1
Warren, OH, USA
11/25/2025 1:33pm
This plus, back in the day with carbureted 2 strokes at least, full throttle when the kill switch was pushed.
Extra fuel in the cylinder? No idea. A faster guy than me told me to do it and I did.
Zzips
South Side, IL, USA
11/25/2025 1:34pm
Antigravity 801 battery. It requires a slight mod to the battery box, but it’ll get that motor spinning quick.
Spergen
11/25/2025 2:56pm
Raced dead engine starts for years, only 2 stroke though. Thankfully I have natural quick reactions but my routine was.....
Charge the battery fully the night before, always start the bike on Kickstarter until the flag drops,
Fresh oil makes a huge difference to clutch drag, always noticed that it doesn't turn over as quickly with used gearbox oil.
Start button on left, kill on right, as people say warm engine up thoroughly before your start, and kill engine with it in gear leaving clutch pulled fully in.
Imagine and believe you are going to be the first into the corner.
thsts my routine anyway...... Oh and don't forget to check your fuel tap at least 10 times 😂
Hammer 663s
Forest Grove, OR, USA
11/25/2025 3:00pm
Cheat like I did and run a Rekluse. I was off the gate before some guys even got their bike started. Smile
wrc777
Greenwood, IN, USA
11/25/2025 3:14pm
A better battery helps. The stock one can’t turn over a 250f fast enough. Start with the throttle cracked. That tip came from Stu Baylor I think. I also roll the throttle on as it is cranking but that is on a tbi bike. I never tried it on a four stroke. I put the start button on the right for two reasons. First that is what I learned on and two I like having my clutch hand free to work the clutch without worrying about the button.
11/25/2025 3:26pm
I found the best thing for dead engine starts.  Do what this guy did, bought a Stark.  Big Bear grand Prix, this guy made it look easy.
IMG 1470
Ryno23
Manhattan, MT, USA
11/25/2025 3:41pm
Best battery you can get is always helpful.  I know some teams running a second battery to give 24v straight to the starter for a faster hit.  I run Super B batteries in my race bikes which DOES make a difference in cranking speed.  Kinda hard to get and very expensive but worth it.  Off Road Champions in Colorado are the only US dealer last time I checked.  ALSO, make sure your grounded with a good cable right from the starter bolt straight to the battery.  Star washers also help get a good consistent contact though the metal to the cable.  This eliminates any resistance the starter could see through any other chassis grounding.
ThePizzaCobra
11/26/2025 3:49am
I found the best thing for dead engine starts.  Do what this guy did, bought a Stark.  Big Bear grand Prix, this guy made it look...
IMG 1470
There were a couple Starks on the line… didn’t even see them after the flag dropped. The craziest Stark clip of the day was this:
https://www.instagram.com/reel/DRazb1TjcJn/?igsh=MTI5YzdreGdsN3Fidw==
Most riders were struggling just to make it through this section, but the Stark had enough juice to make a double out of two obstacles. What was more impressive is that the bike had enough power to haul that rider’s huge balls 😂
TAUTOG
Mohrsville, PA, USA
11/26/2025 4:24am
IMG 1470
This is why they need there own class. The Stark isn't dead unless the battery is dead. Comparable to ICE the motor might as well be running and in gear.
EAmato88
Egg Harbor City, NJ, USA
11/26/2025 4:52am
sell it and buy a yz125 or yz250. your dead engine troubles will be a thing of the past, youll be stuck trying to figure out what to do with 30 bikes chasing you after you get the hole shot
AMetts
Lincolnton, NC, USA
11/26/2025 5:54am
I raced my 2021 FX350 a lot, it would usually start up decently quick but not the fastest off the line ever, make sure bike is warmed up and then keep clutch pulled in and then give the button a short press right before the 10 second call. DO NOT GIVE IT ANY GAS, if I gave it gas before it was fully fired up it would flame out and take me 30 seconds for it to fire back up.
I race a 300XC TBI now and holeshotted most of the races this year, rolling on the throttle while starting then its just a matter of keeping the front wheel somewhat close to the ground.
Gworm
Monett, MO, USA
11/26/2025 5:54am
All dead engine starts should include straddling the front fender… and a kickstarter.
zippytech
Bethesda, OH, USA
11/26/2025 6:33am
I seen where some guys replace the battery cables with thicker wires or even double them up. Don't personally know if that worked but the couple I did talked to said it did make it turn over faster.
BoxcarWilly
Thunder Bay, ON, CA
11/26/2025 7:36am
Another thing that will help is to push the bike forward with your legs as you are starting it.
3strokemx
11/26/2025 8:05am
Flintstones Car GIFs - Find & Share on GIPHY
BoxcarWilly
Thunder Bay, ON, CA
11/26/2025 8:15am
It does add extra embarrassment if it doesn't start though 😂
captmoto
Rancho Cucamonga, CA, USA
11/26/2025 9:20am
Same, it was almost hilarious. Bunch of kids got me by the second corner though.
yzrider53
Walnut Creek, CA, USA
12/13/2025 8:02am Edited Date/Time 12/13/2025 8:05am
Set your idle above 2250. Up to 2350.
You're welcome.
Unless you have an auto clutch that is idle rpm sensitive.
FWYT
San Diego, CA, USA
12/13/2025 10:53am
OG KX500 method for novelty sake.
Warm up bike, clean it out, clutch in, put it in 2nd gear. Rev it some more. Hit the kill button, keep clutch in and as the motor is dying, open the throttle wide to charge the cylinder. Carefully push the kickstarter till you feel compression. Do not push beyond that. Kickstarter back up to the top to get max swing. If you do it right, and it will take some practice, you can literally push the kickstarter through as you simultaneously slowly let out the clutch.
Kawboy14!
Georgetown, TX, USA
12/13/2025 12:04pm
Don’t forget a buddy to use ribbon tape to hold the kickstarter out and engaged 😂
Man the push button made life so much easier
Post a reply to: Dead Engine Start Tips (In Gear)
