KTM 350SX-F Owners --- Quick Question About Power
Rider 5280
Denver Metro, CO, USA
Edited Date/Time 11/2/2024 4:39pm
KTM 350SX-F owners --- a quick question about power.
I'm in the process of lining up my funds to purchase a late-model KTM 4-stroke motocross bike (thinking 21-22).
I'm sold on the 350 concept, BUT ... I live at 5,000-ft of elevation in Colorado. And given you lose ~ 3% power for every 1,000-ft of elevation, I'll be down ~ 15% right off-the-bat for the majority of the riding I do.
Does high-elevation / power loss change your assessment ---> That is, would you buy a 450F instead in this situation?
I'm still onboard with buying a KTM to try, as I've never owned one and want to try the "orange Kool-Aid." But, suddenly I am second-guessing the 350F approach. I'd like to run the KTM motor 100% stock and just put tons of hours on it without much maintenance. Note that I also have a big-bore YZ270F project for "super nimble" riding, so now I was just trying to decide between 350F and 450F models to round out the herd.
For reference, I'm a Vet B 40-something rider who rides MX tracks and mountain trails for reference.
All inputs are appreciated!
MKMX
Timbuktu, WA, AU
3/24/2022 1:08pm Edited Date/Time 3/24/2022 1:11pm
No comment on the elevation, however - I came off an ’18 KTM 450 to a ‘21 350 and basically kicked myself that I never bought one earlier. Awesome all round bike and I’ve never felt or even considered that it may be underpowered.
soggy
3/24/2022 4:09pm
I ride a 350 in Utah about 5k elevation. Never ridden it at sea level but it’s not lacking for power.
Rider 5280
3/24/2022 5:39pm
This is really helpful guys - much appreciated!
Keep it coming!
This has been stuck in my head for some time and keeps me coming back to the 350.
crc245
Yorba Linda, CA, USA
3/24/2022 6:33pm
https://youtu.be/TI64vVeq2h4
Ask yourself a few simple questions: Do you like to REV? Are you under 200lbs? Do you want to ride the most fun 4T ever made (at least what I've had the experience of riding, to date)...
Trust in corners are the weakest part of my riding, and the 350 is stellar in this aspect. I'm 185lbs bare, so over 200lbs geared up, and really enjoy riding them. REALLY enjoy riding them. If you get one just a little advice: Throw a 2T air filter cage in to lessen backfire screen restriction, and learn to shift less! It revs so much longer than any four stroke I've ridden, you have to reprogram the brain to different shift points and styles. I'm full-throttle, wide open, on this bike more than anything I get to ride, sans 125SX/150SX...And that's a big part of its charm
GD350
Plymouth, MO, USA
3/24/2022 6:37pm
350s absolutely rip but they leave alot on the table Tuning wise. So if you arent satisfied with the power from Map2 you can get a custom ecu flash for whatever fuel you want to run pretty cheap.
stone881
Fruita, CO, USA
3/24/2022 7:04pm
Too similar to the fire breathing 270 you are building. You will likely ride the bikes in a similar manner and they should make similar power , but clearly the 350 will have a bit more torque. I say this as someone who rides a KTM 250 bb that dyno'd at 52 hp at sea level and I owned a 350 at the time that I was building the 270. Sold the 350 because the 270 is just sooooo much fun and as you know OP I live in Colorado so too have the elevation issues.
My $.02, unless you want to have similar bikes, get a 450.
Rider 5280
3/24/2022 8:14pm Edited Date/Time 3/24/2022 8:18pm
crc245 wrote:
https://youtu.be/TI64vVeq2h4 Ask yourself a few simple questions: Do you like to REV? Are you under 200lbs? Do you want to ride the most fun 4T ever...
Love it! My style is very similar to yours (but not quite as fast), so the video was extremely relevant.
You guys talked sense back into me. I get a little schizo when I getting ready to pull the trigger on new-to-me bikes.
Rider 5280
3/24/2022 8:24pm Edited Date/Time 3/24/2022 8:49pm
stone881 wrote:
Too similar to the fire breathing 270 you are building. You will likely ride the bikes in a similar manner and they should make similar power...
The 350 is an experiment (as is the 250F big-bore), so I just need to get it out of my system.
I've ridden 450Fs since 2003, and really like them, but dang the nimbleness of the 250F got me thinking ... and thinking is expensive.
CarlinoJoeVideo
Portland/Los Angeles, CA, USA
3/24/2022 8:47pm
I race my 350 at Mammoth, 9,000 ft and still plenty of power for me. That’s with the Twisted Development map and VP race gas.
2019 SXF
Screenless filter Cage
Yoshimura exhaust
Vortex by Twisted (they give me a Mammoth map)
14/52 gearing
Pump gas or VP T4
I wouldn’t worry about 5,000ft.
Rider 5280
3/24/2022 8:48pm
I race my 350 at Mammoth, 9,000 ft and still plenty of power for me. That’s with the Twisted Development map and VP race gas. 2019...
2019 SXF
Yoshimura exhaust
14/52 gearing
Pump gas or VP T4
Nice.
Can you readily switch back-and-forth between pump gas and VP T4 without remapping?
CarlinoJoeVideo
3/24/2022 9:21pm
2019 SXF
Yoshimura exhaust
14/52 gearing
Pump gas or VP T4
Rider 5280 wrote:
Nice.
The main maps I have from twisted are for pump/T4(both work fine). Maybe T4 is a tad more crisp? But I have other maps for U4.4.
Leeham
Rochester, WA, USA
3/25/2022 12:59pm
I rode an 18 FC350 with a stock remap ECU by Tokyo Mods. Around 500ft elevation. The best way I can describe that machine is what I imagine a really nice modded YZ250F would be like. My bike, but with more power. It was actually really incredible. Sections I would be in 3rd on my YZ, the 350 could run 2nd no problem without running out on top. 3rd gear is amazing. Solid low end power to like the YZ, but you dont need to grab a shift immediately.
All I can say, is get one my dude. Leave the motor stock, get a Vortex if you want to get more out of the stock setup. Ill get one eventually
bvm111
Las Vegas, NV, USA
3/25/2022 2:40pm
51 tooth rear sprocket with a vortex ignition, mine is from XPR but twisted is excellent as well and a total game changer! As stated above you will kick yourself in the ass for not trying one earlier. You have to commit and ride it for like 10 hours and then jump on a 450 and you will wonder how you ever rode one…. It’s that much of a better overall motorcycle in every way you can imagine.
sandman768
Saratoga Springs, NY, USA
3/25/2022 2:53pm
bvm111 wrote:
51 tooth rear sprocket with a vortex ignition, mine is from XPR but twisted is excellent as well and a total game changer! As stated above...
Agree with this 100% and I have a stock remapped ECU…perfect blend of power and handling for 99% of riders…
3/25/2022 8:37pm
I've ridden mine at home (1000ft) and Black Hills, SD (5,000ft) with negligible results. 350 power baby! Stock ECU with Twisted remap, etc.
3/25/2022 9:04pm
In the last 3 years my main MX bike has gone from a CR500, YZ450 with GYTR motor, 125SX, and now to a FC350. The FC is so good I sold the 125SX and the ground-up YZ250 build I did. It's a fantastic machine.
Pirate421
3/26/2022 8:54am
I’ll agree with all these posts the 350 for me as a 30+ Average rider is the best bike made. So fast and nimble, turns great and felt like I could ride it for hours. Only bike I’ve had that I could ride consistent laps from green to checker flag. Hero bike for sure.
MKMX
Timbuktu, WA, AU
3/26/2022 8:48pm Edited Date/Time 3/27/2022 2:37am
2019 SXF
Yoshimura exhaust
14/52 gearing
Pump gas or VP T4
Have you ran the 51 and 52 back to back? I currently have the stock gearing 14/51, but am curious if the 52 is worth trying? Mostly just track riding.
captmoto
Rancho Cucamonga, CA, USA
3/27/2022 7:48am
I am an XXL guy, way over 200 lbs. In 2017 I got a Husky FC450 and a friend got a KTM 350. I rode his bike a couple times and both times I got the feeling I might have made a mistake. It felt way better turning it. I think some easy tuning would have worked out for me since I am not pushing for even a king of the gravel pit title.
CarlinoJoeVideo
3/27/2022 9:17pm
2019 SXF
Yoshimura exhaust
14/52 gearing
Pump gas or VP T4
MKMX wrote:
Have you ran the 51 and 52 back to back? I currently have the stock gearing 14/51, but am curious if the 52 is worth trying...
I went right to 52 because it was recommended from Kris Keefer. It also has an effect on the suspension. Because the gears are physically taller and in return the chain tension doesn’t effect the movement of the swing arm as much.
I believe in 22.5 and 23 bikes they moved the location of the countershaft sprocket to do something similar.
MKMX
Timbuktu, WA, AU
3/28/2022 12:19am
2019 SXF
Yoshimura exhaust
14/52 gearing
Pump gas or VP T4
I went right to 52 because it was recommended from Kris Keefer. It also has an effect on the suspension. Because the gears are physically taller...
I just ordered my 52 👍 thanks Joe.
FGR01
3/28/2022 11:57am
I ride my 350 from sea level to 5,000ft regularly. No concerns.
You stated above the light feel of a 250 is one of you main motivations for considering a 350. In that case, you will not be disappointed. This is easily my favorite thing about my 350, the light, non-tiring feeling that makes you feel like you can just ride the bike hard and move it around and not get worn out. I rode 450's from 2006-2020. When I get on one now it feels like a tank.
Gearing, to me, is going to be track and rider dependent. I stick with the stock 14/51. If I was to put a 52 on, 2nd would be just a little too tight for corners and 3rd would be a bit too tall for the super tight inside ruts. And then straights where I can now use the incredible over-rev in 3rd (and same on long straights in 4th) I'd probably feel compelled to shift to 4th (or 5th) for just a few moments before the corner.
CarlinoJoeVideo
3/28/2022 4:45pm
FGR01 wrote:
I ride my 350 from sea level to 5,000ft regularly. No concerns. You stated above the light feel of a 250 is one of you main...
Totally agree it’s track/location dependent. I’m in So Cal so lost track are very open. I feel like I ride mostly in 3/4th then drop to 2nd in a few turns at some tracks. Glen Helen you hit 5th on Taladega.
jakubglinz
Prague, CZ
6/7/2023 12:06am
Guys, refreshing the topic from another point of view.
I'm back to riding after 13-14yrs brake, used to ride track on a 125 @ 176 pounds of body weight (20 y.o.), was a beginner, maybe slow C rider at a good day back then but didn't have a clue what I'm doing much I'd say.
Now I'm 35 y.o. and 196-200 pounds (190cm = 6'2.8) and quite suddenly decided that I missed MX although mountain biking is my big thing! I like KTM's, period. So I read all the stuff about that the 350 is THE bike, found a good deal on a second hand 2022 and bought it without ever riding it before.
I have logged 10 hrs on it on few different tracks, it is just a perfect machine but I haven't stop thinking that I might have bought a bit too much of a bike. I'm now much more focused on technique and more aware of what I'm doing right and wrong than back then. And the result is I'm slow, feeling like cruising with it quarter gas, not using the power although I figured you can lug this engine quite OK around. Am on 14/52 gearing and riding the map 1.
Have you seen anyone or experienced yourself that the 350 can be too much? Might the 250F way to go for me? I don't fancy going back to 125, I really like the modern four strokes now Smile
Thanks for any opinion or discussion!
crc245
6/7/2023 8:21am
jakubglinz - Try 14/50 or 14/51 gearing and leave TC on a majority of the time, even in Map1 (14/51 was stock here in the states). That should slow things down, smooth it out, and don't forget that these engines like alotta' rev. Your 2022 is a great bike! At your size, I'd just give it some time and acclimate to riding again before pulling the 250F trigger...
Yzf916
6/8/2023 12:05pm
Were you still able to run the stock(I think 116) chain length with the 52T rear?
wrc777
Greenwood, IN, USA
6/8/2023 2:03pm
I am pretty sure it is 118 links, and I have a 14/52 setup on my FC250 right now with the stupid high chain slack (65mm) and still could move the wheel in if I needed to.
Question for you 350 riders. I read some reviews saying it has a lot of vibration. True for '22 and '23 compared to the 250?
Rider 5280
10/29/2024 8:39pm
wrc777 wrote:
I am pretty sure it is 118 links, and I have a 14/52 setup on my FC250 right now with the stupid high chain slack (65mm)...
Question on vibration:
I was worried about this, too, logged a bunch of hours on a 2022 KTM 350SX-F and 450SX-  in the past few months, and I no longer notice any difference. It's a non-issue for me.
Post a reply to: KTM 350SX-F Owners --- Quick Question About Power
