San Diego, CA, USA
Picking up a new 2020 YZ125 from Langston Motorsports tomorrow. What are some must have mods and common issues to be addressed on these bikes? I'm 5'11", 200 lbs (currently) so I am thinking about changing the shock and fork springs BUT I'm slow too so maybe not? At some point I plan to install a complete HGS exhaust system but beyond that I don't think I'll mess with it.
The stock jetting is pretty good if you run 32:1. If you run less oil like 40:1 or 50:1 it will richen the jetting and you might need to lean the jetting accordingly.
I have in stock
Email - nialdarragh176@gmail.com
X2 on the suspension; you may want to go with heavier springs.
BUD Head
BUD Piston
Vortex IGN
Did this set up on my '06 build and its THEE best setup I've tested between all the popular brands.
38mm Keihin Airstryker carb
STIC Metering Block
This will blow your mind. I have tested a stock bike with STIC against a full blown $3k mod engine bike. No comparison. Bolt on and enjoy 250f like power........
http://www.sticsupertorque.com/
It's tough to make people believe util you have tried one. We have done a bunch of testing back to back plus did "blind" tests with my boys and every time they were blown away by what it did to the power curve of every 125 I put one on. I've had a few friends try them also with the same results.........
2) go one size fatter on the main
3) Moto Tasinari V-force reeds
4) FMF or Pro Circuit pipe and silencer
5) after riding stock...decide if you want to go stiffer on the suspension. i'm 190lbs and i just ride it with the stock soft shit since it's not my race bike. Soft but good enough
none of these changes are critical except maybe going a little fatter on the main....
A shorty silencer is a good move. But for the price of an exhaust and silencer id suggest having it ported 10/10 times. Same price and actually legitamate gains not a tenth of a hp, taking several horsepower gains with porting.
49T Sprocket- Big bang for the buck. Makes the bike feel a bit more torquey and helps the rider stay on the pipe.
Bill's Pipes Expansion Chamber and MX2 silencer - I didn't feel a loss of low end but I do feel a little bit more in the middle and even more so up top. The bikes sounds MUCH better and I haven't even sorted the jetting out yet. I'm really happy with the purchase and it's really going to shine with proper jetting. The stock global spec is crap.
Race Tech Fork and Shock Springs - Getting the bike sprung for my fat azz was huge for how the bike handled. I feel much more confident now. I didn't alter the oil volume or clicker settings from stock. Feels awesome as is. It only took me a few hours to swap the springs and they cost about $275 with shipping and tax. A must do.
Next step is getting the head cut to run 50/50 fuel and getting the jetting sorted out. This YZ125 kicks azz. Best bike I've ever owned.
I girl that I race with gets even worse, probably 6 to 8 hours, she known as captain clutch
I’m probably going full Hinson next season, any suggestions on oil? I use Motul trans oil
Post a reply to: Must have YZ125 Mods and Common Issues
