Tips to remove Shock Resevoir (Bladder Kit)
mitch199
Hi team, wondering if anyone has tips to help in removal of a stuck resevoir from an upper shock housing. Shock is a ZF/Sachs from a late model Beta RR. The resevoir is a spin on/threaded type on these Sachs shocks. Bladder kit is K-tech. Upper shock housing is cracked and requires replacement (have new Sachs part).
Shock is completely disassembled, but for the life of me (without scratching or denting the resevoir) I can't seem to unthread this. How hot do I need to cook this, for the loctite to let go?
The usual oil filter wrenches i've used previously won't seem to budge this one. Any tips or methods used by others that I can try?
Trying not to damage or scratch the resevoir...
mitch199
7/5/2026 4:27pm
image 640
Stuck
7/5/2026 6:47pm
"How hot do I need to cook this, for the loctite to let go?"
That depends how much force you use, the higher the temperature the lower the force required...
image 3358
FGR01
7/5/2026 8:08pm
Since the upper body is already damaged, can you clamp on this area in the vice to minimize the twisting when you are cranking on it?
Other than that, make sure the reservoir is as clean and oil free as possible.  I would use 2 strap wrenches.  Get bigger ones.  Make sure the rubber inside the straps is as clean and tacky as possible.  Might even help to hit it with a shot of contact cleaner just prior to get it tacky.
You want to heat it enough that it it's almost too hot to touch for more than an instant,  If you do this and get 2 big strap wrenches to have good grip it should move.  You want to keep the straps as close down to the threads as possible to minimize twisting of the can itself.   But it's a delicate balance not to get them on the area you heated up.  I've had a few KTM cans where the can almost twisted and crumpled before the loctite let loose, especially when twisting them with a tool that is all the way at the end.
image 3360.png?VersionId=AnYNilH2RNTUm diFvhr3KAk4i
mitch199
7/5/2026 8:58pm
FGR01 wrote:
Since the upper body is already damaged, can you clamp on this area in the vice to minimize the twisting when you are cranking on it?Other...
Thanks mate. All good tips. I'll get another strap wrench today and try it with two. Funny how that didn't even occur to me. 🤪
I actually spoke with the local K-Tech Aust team, who confirmed 'they are a prick to get off'... recommended throwing in the oven at 250'C to for a while to get the loctite to let go.
Will report back (one way or another)...
FGR01
7/5/2026 9:08pm
250C ??  Holy hell.  What kinda loctite are they using?  haha
erik_94COBRA
Houston-ish, TX, USA
7/6/2026 9:20am
Since the upper body is damaged, I would heat the shit out of that area.  The slight expansion of the bare aluminum should help break the thread locking compound and avoid having to heat up the reservoir.  Would also recommend letting it cool down before using strap wrench.  I melted one of mine trying to loosen while too hot.
Side note: would be really curious to see the piston on that shock if you have the shaft disassembled also.
Bearuno
7/6/2026 6:40pm
With using double straps ( good idea)  :
If you can, position one at the body eye end, Over the section going over the thread, and, the other at the valve end - With The End Cap Inserted.
I've seen reservoirs collapsed / distorted, by Not having internal support - some of them are very Thin.
aees
7/7/2026 2:08pm
If the reservoir is toast already, drill a hole straight through reservor and put a long screwdriver or metal rod in there. Twist.
Heat of course.
YZed250
Costa Mesa, CA, USA
7/7/2026 4:49pm
"How hot do I need to cook this, for the loctite to let go?"That depends how much force you use, the higher the temperature the...
image 3358
That's pretty low for it to soften!!
I know a few shops have had trouble with OEM shocks coming apart by unthreading on the 23+ gen WP shocks under heavy use.
You'll see a variety of clamps and stoppers to help hold them together.
7/7/2026 6:32pm
image 3358
YZed250 wrote:
That's pretty low for it to soften!!I know a few shops have had trouble with OEM shocks coming apart by unthreading on the 23+ gen WP...
The temperatures are in Celsius...
70% strength at 100°C (212°F)
0% strength at 230°C (446°F)
K-Tech Aust team's advice of throwing it in the oven at 250°C (482°F) would work.
FGR01
7/7/2026 7:13pm
I'm trying to imagine handling a 250C shock body, getting it in the vice, and throwing a few strap wrenches on it.  Doesn't sound fun.. LOL
7/7/2026 7:19pm
That would be a challenge!
It should have lost it's strength after heating to 250°C, let it cool down first.
mitch199
7/8/2026 2:51am
Well, success!
A quick session in the oven as per doctors orders, followed by a two-strap-wrench attack after about 10min of cooling time, did the trick. Almost couldn’t believe it actually let go. That loctite stank.
Cheers all.
Ps. Pic of the shock assy/piston as removed from the main tube, for reference.
Now to finish this swap over and onto the next job… (try to weld up this DRZ sump bolt that someone sent to the moon)
IMG 1883 4
Freedom!
IMG 1884 1
IMG 1870 4
Sachs Shock
mitch199
7/8/2026 2:53am
Also taking tips for this job 😳🤣
IMG 1878 4IMG 1879 1.jpeg?VersionId=dKJe4lv.F1c28ngRdvhp4IMG 1876 3.jpeg?VersionId=sTI4952LUGXXyhu9CxMCvbe0M
Luxon MX
San Diego, CA, USA
7/8/2026 11:44am
Heating above 150C (300F) will cause the aluminum to lose its temper. At 250C it will lose significant amount of strength.
The reservoir isn't structural, and it's anodized, but losing hardness of the substrate certainly isn't a good thing.
Post a reply to: Tips to remove Shock Resevoir (Bladder Kit)
