Which Tire Spoons
captmoto
Rancho Cucamonga, CA, USA
Edited Date/Time 1/19/2018 9:15pm
Will not mar my rims? Or do I need to improve my technique. I use this type of iron now and got some small nicks in the rim.
https://www.rockymountainatvmc.com/p/726/19196/Tusk-15%22-Curved-Tire-I…
Acidreamer
Mansfield, OH, USA
1/11/2018 8:06am
They make plastic rim protectors that you stick under the tire iron. I use the same spoons with the protectors and have zero issues.
captmoto
1/11/2018 8:15am Edited Date/Time 1/11/2018 8:16am
Motion Pro? I have some generics that tore. They seemed to be like soft plastic or hard rubber.
Acidreamer
Mansfield, OH, USA
1/11/2018 8:27am
Yea the motion pro ones are like what i have. Im not sure what brand they are.. they were given to me. Mine are a hard plastic.
zeikei
FI
1/11/2018 9:17am
I use these kind of spoons and the part where I tend to leave marks is the very last bit of putting the tire back on. The solution for that is more spoons as you can place them all in there before it gets tight.
FWYT
San Diego, CA, USA
1/11/2018 10:49am
zeikei wrote:
I use these kind of spoons and the part where I tend to leave marks is the very last bit of putting the tire back on...
I like these as well. And yes, you gotta be a little careful. Good tire mounting lube helps immensely.
dirtmike86
Grand Terrace, CA, USA
1/11/2018 5:36pm
3 aluminum motion pro spoons, A bead buddy,a bowl of weed and some Slow ride by Foghat.
reded
1/11/2018 6:15pm
These work well, no scratches.
Stubby
1/11/2018 6:29pm
really warm tires and lube helped me a ton. I sucked. now I just barely suck at itTongue
swtwtwtw
Apple Valley, CA, USA
1/11/2018 7:51pm Edited Date/Time 1/11/2018 7:51pm
BAJA No pinch ...awesome
Hotwhls
Carson City, NV, USA
1/12/2018 2:32pm
I just did my wheels brand new with the spoon above. I put two layers of electrical tape on the wheels lip to prevent scratches that worked perfect.
nch209
NoVa, VA, USA
1/12/2018 3:14pm
I have had good luck with motion pros, and have even chopped two up to weld one big long one.... More leverage+Less times biting= Less damage. Oh yea, tire past- or Windex at a minimum, works well to help 'em slide on.
casper
San Diego, CA, USA
1/12/2018 4:01pm
I use the same, buy 3 and it will make moving them around the rim allot easier. I was constantly pinching tubed with the spoons in the first post. Also I got a Bead Buddy to help.
https://www.rockymountainatvmc.com/p/1511/26055/Motion-Pro-Bead-Buddy-I…
I've also used the Motion Pro plastic rim protectors, but they are kind of a pain in the ass to use. I used them when my rim was new, but now don't really touch them.
jvail134
Ocala, FL, USA
1/12/2018 4:07pm Edited Date/Time 1/12/2018 4:07pm
I second this! Easiest I have ever changed a tire. Even the extra ply ones are no problem.
mwssquad827
Twin Falls, ID, USA
1/12/2018 8:15pm
Moose spoons are awesome
Hondas4Life3
Spring Hill, KS, USA
1/13/2018 7:43pm
I have scratched rims with this.. Probably being in a hurry and carelessness but it seems too easy with the sharp edges of the tool. Motion Pro tire spoons get my vote.
KDXGarage
1/19/2018 9:15pm
Zip-TY Racing Huge ones.
some sort of rim protector
as mentioned, warm tires and proper lube
Keep that bead down in the other side as best one can.
Post a reply to: Which Tire Spoons
