Throttle Tubes
Moto520
Schaumburg, IL US
Edited Date/Time 12/24/2017 11:18am
Guys,
What throttle tubes are you all running? I have the Pro Taper Twister throttle tube on my bikes but it was brought to my attention that this design of throttle tube changes where the throttle is positioned on the handlebar by about 1/2". The throttle is further away from the centerline of the handlebars to accommodate the bearing end. So...i'm probably going to move away from this style. What are you all running and why? How are you lubing the tube to handlebar surface? Any other techniques to lubing the throttle system that is working for you?
Thanks guys
Naanak
NJ US
11/7/2017 2:02pm
I use Odi lock on grips (not emig) which come with the plastic tube and use silicone as lube.
11/7/2017 2:28pm
A little grease in the throttle cam, and a light coating on the inside of the tube.
Moto520
Schaumburg, IL US
11/7/2017 4:43pm
Anyone using the Pro Circuit throttle tubes?
mxb2
Bowie, MD US
11/7/2017 5:51pm
Motion pro, works connection, pro circuit, hammerhead all good stuff.
ktm-5
Ravenna, MI US
11/7/2017 7:09pm
I use the ktm oem odi setup and use no lube on anything, just keep it cleaned. I am more worried about any kind of lube collecting dirt and creating an issue
Bruce372
11/7/2017 11:48pm
Motion pro plastic. No lube needed.
Acidreamer
Mansfield, OH US
11/8/2017 1:19am
The stock one works pretty good on my kx. I suppose if it ever breaks ill switch to an aluminum one.
Squitlege
Jacksonville Beach, FL US
11/8/2017 3:37am
Did you notice the ergo differences on the Pro-Taper throttle before or after you read it on the internet?
Moto520
Schaumburg, IL US
11/8/2017 9:04am
A buddy of mine pointed it out. I never really noticed it but i'm trying to fine tune my race machine so once I saw how off it was....there was no going back. You can hack off a little off the handlebar on the right side or move the handlebars over a little bit to compensate but that's not going to do it for me. It's off a significant enough amount that a correction to the issue is going to happen.
Now....if I would have never known this would it be a problem? Absolutely not
brian352
Midlothian, TX US
11/8/2017 9:22pm Edited Date/Time 11/8/2017 9:23pm
I use the G2 quick turn on my crf 250. I bought mainly because of a range of motion issue in my wrist.
exbmxmx
Houston, TX US
11/10/2017 1:33pm
Try dry graphite as a lube. It's dry and doesn't attract dirt.
Falcon
Menifee, CA US
11/10/2017 5:26pm
X2.
I tried an aluminum throttle tube once and I honestly cannot understand how anybody can use one. It's one of those weird little things that I notice. I could probably ride a bent-frame bike, but don't give me an AL throttle tube!!!
Moto520
Schaumburg, IL US
11/10/2017 10:06pm
Falcon wrote:
X2. I tried an aluminum throttle tube once and I honestly cannot understand how anybody can use one. It's one of those weird little things that...
X2.
Why didnt you like it?
Bruce372
11/10/2017 10:25pm
Alum deforms and drags. The blue motion pro tubes are the best and cheap also
Hiretablets
New York, NY US
12/17/2017 9:12pm
Thanks for the information mate...
Hiretablets
New York, NY US
12/17/2017 9:13pm
Thanks for the info mate.
RussB
12/18/2017 4:11am Edited Date/Time 12/18/2017 4:11am
Apico throttle tubes for me. Not only is the tube well priced but awesome quality. Super smooth and no play at all. I use a little engine oil for lube, gives the best feel I think.
I don't like the slight play that a plastic throttle tube gives, any rattle in my throttle annoys me
12/18/2017 9:29am
Does works connection make as throttle tube ?I love there stuffjust never seen there throttle tubes
Bruce372
12/18/2017 9:46am
Motion pro make one out of a low friction blue plastic, it's the best one I've used and the most inexpensive
Moto520
Schaumburg, IL US
12/18/2017 2:03pm
Yes...just not for the KTM/ husky
Bruce372
12/18/2017 3:08pm
Everett, they actually do make them.
They actually make a new one for the ktm where you can use both the two different oem throttle cams.... Got one on my husky
https://www.motionpro.com/product/01-1298
12/18/2017 3:36pm
Moto520 wrote:
Guys, What throttle tubes are you all running? I have the Pro Taper Twister throttle tube on my bikes but it was brought to my attention...
Guys,
Thanks guys
I recently purchased a G2 quick turn throttle tube and a G2 "Jimmy" Insert. Pricey, but seem to get great reviews.
Moto520
Schaumburg, IL US
12/18/2017 4:11pm Edited Date/Time 12/18/2017 4:11pm
Bruce372 wrote:
Everett, they actually do make them. They actually make a new one for the ktm where you can use both the two different oem throttle cams...
Bruce,
I know. I have the titan and they have the user use the throttle cam that comes stock on the ktm. I was referring to the works connection. Does the titan come with the cam installed with any of their versions of the throttle tube?
Bruce372
12/18/2017 4:27pm
Moto520 wrote:
Bruce, I know. I have the titan and they have the user use the throttle cam that comes stock on the ktm. I was referring to...
Bruce,
yeah, you can get the motion pro titan that can be used with both the interchangeable OEM cams, or you can also buy the titan with the cam already molded in, but its slow pull.
its getting a little confusing, LOL.
jaredkeller96
Huntersville, NC US
12/19/2017 6:15pm
I like the odi throttle tube with the ball bearing insert in the end, and it’s compatible with everything
Moto520
Schaumburg, IL US
12/19/2017 8:40pm
Bruce,
Bruce372 wrote:
yeah, you can get the motion pro titan that can be used with both the interchangeable OEM cams, or you can also buy the titan with...
Good to know.
David934
CZ
12/19/2017 11:58pm
always rode oem plastic tube and always use lube like wd40 or something similar, never problem with this
Tracktor
The RTF/Amboy, WA US
12/20/2017 12:57pm
Triflo Teflon lube & Starbrite teflon grease are what I use for throttles/levers & anything else that needs a light clean grease.
Falcon
Menifee, CA US
12/21/2017 2:53pm
X2.
Sorry, didn't see your post. I felt like the Aluminum tube had too much drag against the bar and/or felt too heavy to turn quickly. It made the entire bike feel slow.
swtwtwtw
Apple Valley, CA US
12/21/2017 4:29pm
I like the protaper twister. I like the zero friction movement. Mine is 5mm longer, negligible.
Post a reply to: Throttle Tubes
