ID
Im going to be picking one of these up in the spring and am curious what would be a good setup as far as pipes and carb setup. Im leaning towards doing a FMF Factory Fatty pipe with the Powercore exhaust, is there something else that works better on the Austrian 125s though?
Im also thinking about doing a Lectron carb, has anyone run one on a 125? Mainly would be riding around 5000 feet, but if I ride in mountains at all would be around 8000, that why I'm kinda leaning towards a Lectron.
Any advice or tips on these bikes would be appreciated.
A lot of the aftermarket parts are no better, or don't fit right or both.
It's amazing how great they are dialed jetting stock, two ring piston thats nice and reliable and goes a long way on a top end. And it's amazing how many trick parts that make it less reliable but marginal gains if not make it worse.
Free shipping: VITALMX
I also have the pc shorty and pipe. Stock vs pc pipe i can’t tell a difference. Shorty vs stock the shorty has better throttle connectivity at low rpm. Top end felt the same but that was with the lectron. I need to try it again with the stock carb since the lectron falls off on top a lot worse than the mikuni.
On the carbs, I'd guess everyone recommending a Keihin never rode an Austrian 125 with a Mikuni using the Digger/AJ jetting from the other thread. The myths of the Mikuni being hard to jet or temperamental requiring constant changes for conditions are not true. But the key is you have to change the slide and the needle jet tube. You will never get there using the chart in the manual because the slide is just too rich.
Post a reply to: GASGAS MC 125 Questions
