Opp, AL, USA
I have been struggling with front end tuck on my 2018 ktm 350sxf. Will too little sag cause this? I have been running 103 but recently moved the rear axle forward to run my 52 tooth rear sprocket. I know wheelbase might have an effect on it too. I like the gearing so the wheelbase is going to stay. What is the best adjustment for this? More sag, more compression on fork, more air in fork, more rebound in shock? I have been running 160psi in the forks. I'm 220 without gear. The front tuck occurs before "turn in" mainly during braking or as I have finished breaking. I also tried rear brake only it didnt help
Sounds like since you shorten your wheel base, you moved the weight forward on the bike and it’s make the fork too soft. Try 2-4 clicks stiffer on compression.
103 sag is plenty, maybe go to 105 to take some weight off the front also.
Free shipping: VITALMX
To answer OP. It's either your forks are diving too much under braking or you have too much rebound damping and it's packing up. Try going like 6 clicks out on your rebound adjuster and see how that feels. If it doesn't make a difference, try going 2-4 clicks stiffer on comp.
160psi should be pretty close for your weight. Remember not to get too caught up chasing air pressures and don't forget that you have comp and rebound clickers.
You said your sag was 103, but what is your static sag? You, like me, are a bigger guy riding, you said you are 220 pounds without gear. I was about that when i bought my KX450 and I had to go to a stiffer spring right away. You have to start with the correct spring rate. Then you begin testing air pressures and clickers.
Personally id start with the factory stock settings after having the correct spring installed. Ride the bike for a couple hours and break in that new spring. It will ride high at first. Then recheck the sag, you will probably have to adjust. I would then make sure the forks are at the recommended height in the triple clamps. Ride again with still stock settings. If I was still getting serious tuck in the corners Id lengthen the forks a mm or 2, but this will alter the sag again so recheck and adjust if needed. Then air pressure to get the front end to hold up and not bottom. From there, fine tune with the clickers.
I had the opposite problem with my Kawasaki. My front end wanted to climb out of the ruts. I shortened the forks to 6mm, set sag at 104, set air pressure to where is was pretty good, then dialed it in with clickers.
Good luck
Post a reply to: Front end tuck
