KTM Engine failure....
fullysicmate
Queensland, AU
Edited Date/Time 7/10/2018 3:58pm
Piston and bore pics.....whats your diagnosis?
kb228
Mansfield, OH, USA
7/8/2018 5:06am
My diagnosis is the color orange
piscokid
7/8/2018 5:09am
Debris in the motor, how clean was the filter?
Paw Paw 271
Benton, LA, USA
7/8/2018 5:34am
If there was also damage to the cam journals, then I suspect faulty oil delivery. If journals were not damaged, then dirt as already expressed above.
MX915
Central, NJ, USA
7/8/2018 6:23am
Thats obviously not an OEM piston. All your clearances check out before putting the new one in?
fullysicmate
Queensland, AU
7/8/2018 1:45pm
Thats an aftermarket big bore kit. We triple checked clerances because it was a tight squeeze to get the piston in the bore, they were fine. It ran for 1.1hr then this.
mx317
7/8/2018 2:13pm
Go back stock
809
Paducah, KY, USA
7/8/2018 2:50pm
I see a lot of KTMs with dirt causing issues. Amazing how many people don't install the air filter properly. PawPaw is on the money.
Paw Paw 271
Benton, LA, USA
7/8/2018 6:15pm
What brand aftermarket big bore kit?
Size?
fullysicmate
Queensland, AU
7/9/2018 3:21am
If there was also damage to the cam journals, then I suspect faulty oil delivery. If journals were not damaged, then dirt as already expressed above...
Definitely not dirt, I have checked the intake track and there is no sign. Also it was run in around slashed grass headlands, no dust or other vehivles around. The faulty oil delivery could be it and that would explain the scoring on the piston pin which is a concern, could one of the oil injectors be blocked, and if so how? I am putting it back together with the standard bore and piston this weekend so hopefully I have cleared out whatever it might have been.
fullysicmate
Queensland, AU
7/9/2018 3:24am
Size?
Pm me if you want to know, I dont want to name them here as it may not be their fault. But the piston was tight in the bore, ring gap was fine but I didn't measure the piston clearance. I will this weekend.
fullysicmate
Queensland, AU
7/9/2018 3:28am
Filter was fresh, still spotless. Total time on bbk and filter 1.1hrs.
Paw Paw 271
Benton, LA, USA
7/9/2018 4:26am Edited Date/Time 7/9/2018 4:28am
That tight piston fit could be the issue as it can create excess heat and cause the piston to fail. Was it a forged piston? If so, the expansion rate of the piston would be faster than the cylinder and the tight fit would cause the failure.
Was the engine put through several heat cycles prior to riding it?
I did not see the upper 2 rings in you photos. Were they stuck or just destroyed?
fullysicmate
Queensland, AU
7/9/2018 4:55am Edited Date/Time 7/9/2018 4:57am
That tight piston fit could be the issue as it can create excess heat and cause the piston to fail. Was it a forged piston? If...
It is a forged cp piston, it is a 1 ring piston (+oil ring), which is melted in the groove in the pic. The second groove is not a ring groove, cp call it an accumulator groove, it is not deep enough for a ring to fit. The bike idled for 5 mins after install, then ridden for 25mins slowly the next day, oil then changed, ridden for 30 min a couple of weeks later, then ridden for 5 kilometers the weekend just gone before she stopped.
c0ncEpT
Harrison Twp., MI, USA
7/9/2018 7:07am
Not enough clearance for the conditions. Got hot and stuck the bore.
seth505
SD, CA, USA
7/9/2018 11:54am
Not saying this is the failure mode but I would never idle a race bike for 5 minutes.
lumpy790
York, SC, USA
7/9/2018 3:12pm
What brand coolant are you running?
fullysicmate
Queensland, AU
7/10/2018 1:19pm
Just took the it to a performance shop for assessment, their opinion is that the gudgeon pin was too tight not allowing the piston to pivot freely....
Paw Paw 271
Benton, LA, USA
7/10/2018 3:58pm
Just took the it to a performance shop for assessment, their opinion is that the gudgeon pin was too tight not allowing the piston to pivot...
I just find that hard to believe.
Post a reply to: KTM Engine failure....
