9/18/2018 4:35pm
As you can see in this pic the drain hole was helicoiled at a bad angle. Its also american threads. Any suggestions other than taking it to a local machinist?
Your expert advice and experience is appreciated. Trying to save this beat 96' CR125.
-Thanks
Bob
-Thanks
Bob
https://www.ebay.com/itm/Oil-Drain-Plug-Sump-Bolt-Thread-Repair-Kit-24p…
Dix is on my way home from work! I didn't know that shop was there. Perfect!
“Thickserts” if more material removal is required to repair.
Even if it isn’t the soloution for this issue - handy to know about if you have an interest in VMX. Saved a welding job on my ‘81 RM125 fork leg. A perfect soloution. (Better than new - the axle screws into steel now!)
I’d try a (cheaper) normal helicoil first.
Depending on how oversized the hole is - Helicoil, Timesert, Thicksert. In that order.
You can probably find the drill size required for each option, and compare that to the situation.
Post a reply to: Drain Bolt Dilema
