Somerset, NJ
Just curious to see what everyone here does to change tires without marring up their rims. I usually do a set of tires a year so i never get a lot of practice. When i first started doing my own tires i used those crappy plastic rims savers, but have recently started to just just a set of electrical taped tire irons and the seem to yield the best results
Have a pair of gold rims that look brand new!
Motion pro ones were too thick for my liking.
This, and 3 “spoons” changed my life.
If you're old enough to remember the "Breezer" tire tool you can actually flip the Stubby's over and use them like a Breezer once you get the bead broke over the rim. Just hammer it around the rim and peal it off, or just use them like regular irons and pry it off. I do each bead to it's respective side and pull the wheel out of the tire once both beads are off.
With the tube in the tire and a slight amount of air to keep it's form, I use the Stubby's to get the bead started then finish with the No-pinch for installation.
Lube is your friend coming off and going on.
https://youtu.be/8WRLymbFBCg
Motion Pro Rim Savers
3 Tire spoons (I've found the spoon shaped ones work best for removal)
Break the bead on both sides, then bring the tire over the rim on both sides. Then pull the rim straight out (up). Cameron Niemela has a great video of it.
Install:
Motion Pro Bead Buddy
Baja No Pinch Tool (one of the best tools I've ever bought)
Using this method/tools, the rims don't get scratched and you don't have to worry about pinching a tube. Time wise not the most efficient, but I'm going for quality.
Post a reply to: Cleanest Tire Changing Method
