Boulder, CO
10/28/2020 9:17am
I have a 2007 cr125 that I just blew the piston up on. I had been riding it pretty consistently for a couple months without any problems and it seemed to go out of nowhere. And when I took it apart i found that the piston was installed the wrong direction, so the ring caught on the exhaust port and ripped it up pretty good. What I'm wondering is if I need to do the bottom end on my bike. The piston is pretty thrashed, but only on the top 1/4. There was a good amount of piston bits in my expansion chamber. There are some small specks of aluminum in the crankcase, and a couple small pieces on my drain plug magnet, after running some more transmission oil through it no more metal shows up on the magnet. My crankarm doesn't have any up/down play and the side to side is in spec and everything moves smoothly. I am getting the cylinder bored out and a new head. Am I going to be alright throwing a new top end on, or do I need to split the cases and clean out and redo the bottom?
This is not a job for someone new to motorcycle engine work, as the transmission/shift/clutch assemblies are full of little parts and pieces that must go together in a very precise way. If you do try it, be sure to get a factory service manual and do a lot of research (e.g., You tube videos, etc.)
I'm just curious, how long did the bike run with the piston in backwards?
Good luck.
Big end side play is within spec and there is no debris in the bottom end.
Run it.
I’m one of those that would rather be safe than sorry.
I have never used a case splitter just some flat bar and drill holes.
To the OP, you are correct that you cannot properly inspect the bottom end for debris without splitting the cases. The crank may be spinning fine now but there could very easily be an unseen debris that will move and lodge itself in a main bearing or migrate to the top end upon startup or running. If you're trying to be cheap, at the very least, remove the bottom end from the frame, fill the crankcase with kerosene or pre-mixed gas, shake and dump. Repeat this a few times. This might remove any small debris that's down in there. Also run a pen magnet around down in there in case there are any small bits of steel.
Post a reply to: Blown up cr125 bottom end question
