2018 YZ450F Problems Round 2
foreman52
Edited Date/Time 1/4/2019 10:02am
Hey everyone, back again. For those that never saw the problems I've been having in my other fourm here is a quick run down:
- Motor replaced at 6 hours (3rd gear slipping and could never find the issue...5 weeks off the bike before Yamaha replaced the motor).
- Intake valves were completely out of spec and needed to be replaced (had no effect on 3rd gear).
- Starter clutch went at 4 hours on new motor.
- No warrenty/compensation from Yamaha.
- Just shimmed one intake valve that was so tight you couldn't get a 4 in it (roughly 12 hours).
I was just at a race this weekend and the bike completely bogged out before the landing off a jump (4th moto out of 5 for the day). I knew something wasn't right so I pulled off.
When I shut the bike off it wouldn't start again. I changed the filter, but nothing. When I pulled the choke out the bike would start. Without the choke it eventually began to start but backfire immediately.
The issue seems to happen when THE BIKE IS WARMED UP. Once it is warmed up it will not start without the choke/or start like a bastard.
THIS IS NOT AN ISSUE WITH THE STARTER CLUTCH. The bike starts fine after being warned up shortly with/without the choke. After it has been primed it is game over.
Has anyone had this problem yet?!
rollin64caddy
San Diego, CA, USA
8/16/2018 8:26pm
damn man, sorry to hear all the problems with a new bike. I'd be devastated. possibly something fuel related? Pump, fuel flow, bad valve in gas cap? I'm no expert but just throwing out ideas.
swtwtwtw
Apple Valley, CA, USA
8/16/2018 9:16pm
It’s normal. When a thumper is hot, it needs the throttle turned a bit to fire up. Our bikes do not have a choke, the button we push opens the throttle a bit, myself I just open the throttle myself and voila fires up no problem in gear or not hot or cold
Lynch
SE
8/17/2018 3:38am
Ugh that sucks, things like these tend to steer people away from brands. Hoping you'll get it sorted without dumping cash into it as Yamaha really should help you out.
kb228
Mansfield, OH, USA
8/17/2018 6:01am
Id look at your fuel pump and injector.
Also might look for a different color bike. The probs youre having and yamaha being of basically no help is horse shit. Valves out of spec at 12 hours?!? Dude my 250f has 15 on it and the valves are right where they were when i built it. Sounds like a dud of a bike. For real man hate to hear that.
Paw Paw 271
Benton, LA, USA
8/18/2018 12:36pm
So it is electric start, right?
Have you load tested the battery?
The OEM batteries in these bike are junk and do not last any time.
I suspect that the battery voltage drops off under load ( like cold starting), but still has enough juice to start a warmed up engine. Also if the battery has a loose plate in it, it will cause the engine to stall.
NeedMoto
Penn Valley, CA, USA
8/18/2018 5:47pm
Dang... sorry to hear about the issues. 60 hrs on mine, not a single glitch. Some good, some bad I guess Unsure
foreman52
8/22/2018 9:43am
Any updates?
Ended up being that the fuel connector clip was broke. This was making it move in and out which is what we believe caused the bog. We thought we figured out the problem and I went out riding and the connector complete came lose (almost throwing me over the bars...was very lucky). Pushed the bike back to the truck and tried starting it and it began pissing gas...that's when we realized that the connector had let go. We put a few zap straps on it and it has been working fine since (knock on wood).
How this happened I have no idea. Whether it was when the new motor was swapped, or if the fuel tank was moved the wrong way when we did the valves. Either way this bike has been very frustrating.
fourfourone
86oh, CT, USA
8/22/2018 10:18am
Any updates?
foreman52 wrote:
Ended up being that the fuel connector clip was broke. This was making it move in and out which is what we believe caused the bog...
nothing worse then not trusting a bike when you ride it. Maybe sell this one and hop on a 19?
8/22/2018 2:26pm
Id replace that line ASAP. Also, valves out of spec at 12 hrs? Dayum! I have a '18 CRF450RX with 30 race hours (including a race where I lost 50% of my coolant) and 9 trail hours...my valves have not moved at all
rollin64caddy
San Diego, CA, USA
8/22/2018 7:49pm
hopefully problem solved and now you can enjoy the bike. good luck man.
foreman52
8/23/2018 8:17am
Any updates?
Looking into a new Honda for 2019!
foreman52
8/23/2018 8:20am
Id replace that line ASAP. Also, valves out of spec at 12 hrs? Dayum! I have a '18 CRF450RX with 30 race hours (including a race...
I had a 16 YZ250F both intake valves went at 21 hours and again at 48. Thought it was a lemon since I had not heard or seen anyone around having valve problems with their Yamaha's so I purchased a 17 YZ250F. Valves went in that at 37...which isn't that bad...but still no one around the track on any brand was having that kind of trouble. I have learned my lesson this third time around with my 18. The next one will certainly be a different colour!
foreman52
8/23/2018 8:21am
Appreciate it my man! Thank you
AndyH
11/14/2018 9:58am Edited Date/Time 11/14/2018 9:59am
Bought a new 2019 YZ450F 6 weeks ago, after 8 hours it wouldn't start, checked the inlets valves and they were totally tight so took it into my local dealers for setting. Loads of sand in the inlet manifold and throttle body so I put it down to my bad maintenance and over enthusiastic use of the power wash.
Needed a new barrel,piston, 4 valves, any how £1400 later and its back together again.
Ran it today for one hour at a sand track, air filter edges greased, sock over the filter, total care when washing it down.
Just got it back and very carefully stripped the filter and housing off and the there is sand in the inlet manifold and throttle body, what are you supposed to do? This thing is going to be broken again after a few more hours running.
Starter clutch also went at 8 hours although Yamaha did fix this under warranty, seriously considering getting shut.
Lynch
SE
11/14/2018 10:29am
AndyH wrote:
Bought a new 2019 YZ450F 6 weeks ago, after 8 hours it wouldn't start, checked the inlets valves and they were totally tight so took it...
What filter oil are you using? Checked for cracks in the airbox/manifold i assume?
mx317
11/14/2018 11:32am
Get the Twin Air setup with the new cage and more rounded filter.
AndyH
11/14/2018 11:42am
Putoline filter oil and plenty of it. Just had a better look at it and found a couple of things.
Firstly the filter has two holes in the middle of it where the spike goes through, interesting! Maybe I did it but I think that might be unlikely, irrespective though the filter had a sock over the top of it so I wouldn't have thought that would have let any sand through.
I had also greased the seat that the filter sits on. On the bottom edge the grease was full of sand which would suggest that the filter wasn't seating properly on that edge. Why that should be I have no idea and need to have a better look at it.
Having read this forum and others what does seem apparent is that a lot of YZ450 owners are suffering from tight inlet valves that are out of adjustment and hence bad starting. The most logical explanation for this is the wear caused by sand which is somehow getting into the manifold.
I would be interested to hear from any other YZ450 owners to know if they remove the metal filter gauze below the air filter is there any sand in the inlet manifold? It also seems to accumulate on the edge of the throttle butterfly valve which is visible down the manifold.
AndyH
11/14/2018 11:48am
Cheers I'll check that out
Lynch
SE
11/14/2018 11:59am
AndyH wrote:
Putoline filter oil and plenty of it. Just had a better look at it and found a couple of things. Firstly the filter has two holes...
Stock filter? If so throw it in the trash, you need one with the rubber grommet. Twin Air for example.
I'll check with a few people I know that ride the 18-19 450 Yamahas and see if they have had any problems. Probably 500hours between three people, two of them rides heavy sand 90% of the time.
AndyH
11/14/2018 12:12pm
Yes stock filter, bikes only done 8 hours but already had a barrel/piston and valves, appreciate any help or advice, can't afford to break it again.
snape99
Picnic Point, NSW, AU
11/14/2018 3:14pm
My 19 250f has to have starter clutch replaced at 4 hours too
Wolfey
Marquette Heights, IL, USA
11/14/2018 7:06pm Edited Date/Time 11/14/2018 7:11pm
I just recently found a little sand in the air boot area on my sons 19 250f.We have 4 hours on it and I’ve been paranoid about that filter/cage since the day I saw it. I also had the filter well oiled,greased and had a filter skin on it. I said that’s it and bit the bullet for the twin air cage and filter set up at $250 ! Hated spending that much but this set up seems way safer. The twin air set up goes back to the cage under the filter. The filter has the rubber grommet with the bolt instead of that stupid cage on the outside with the tabs sliding over to hold the cage down. Unfortunately winter came a little early so we haven’t got to try this system out to see if it’s keeping the sand out. Also I checked the valves and they are exactly the same as the day I brought it home so hopefully our worries are over. Other than that,this bike is amazing.
AndyH
11/15/2018 3:29am
Ordered a Twin Air filter and cage, so ill check the manifold for sand again after I've fitted it and post the results here
Wolfey
11/15/2018 4:21am
Also another cool thing about the twin air is that the base has a lip on it. So the filter sits down over the base. You’ll see what I mean when you get it. Much better design to keep dirt out.
like2ride
Fayetteville, GA, USA
11/28/2018 5:00pm Edited Date/Time 11/28/2018 6:43pm
I have a 2016 450FX and I bought some foam filter material from McMaster-Carr, Part no. 9803K305 for $15. Its dark gray 12in X 12in X 2in thick. I cut it to fit in the intakes and stick out about 1/2in. There are couple drain areas on the inside of the air box where I also I installed it. You can run them dry or apply some light oil. They keep out the course sand leaving the filter inside to deal with the finer dust. This filter material is not really tight, so I haven't noticed any power loss but it does help keep the filter cleaner. I use twin air filters, Bel Ray oil and change the filter every ride. For the last two years its been working well for me. It will be interesting to hear how the twin air system works for you. If you're having problems with your engine getting dusted, anything is worth a try.
AndyH
11/29/2018 3:48am
like2ride wrote:
I have a 2016 450FX and I bought some foam filter material from McMaster-Carr, Part no. 9803K305 for $15. Its dark gray 12in X 12in X...
Well after a bit of searching I have managed to aquire a Twin Air Pro filter kit for £200 that not only replaces the filter but the plastic cage and adapter plate onto the inlet manifold. It is a very well made piece of kit with an alloy frame and a lip that secures the filter onto the housing. Filter now screws down with a central alloy bolt through a rubber sleeve.
Will be giving it a go this weekend, fingers crossed it solves the problem. 'll let you know.
Lynch
SE
11/29/2018 4:34am Edited Date/Time 11/29/2018 5:16am
I asked around, 5 people, none of them have had any problems with the bikes letting sand/dirt bye. All used Twin Air filters, different oils: No Toil, Bel-Ray, Putoline.
I was worried at first but no problems so far.
Motofinne
FI
11/29/2018 4:45am
Like Lynch mentions.
I use No-toil filteroil and Twin airs normal filters (not the aluminium powerflow kit) and i haven't had any issues with dirt getting in. I was a bit worried about it when i have read quite a lot about this issue but i haven't experienced it at all.
Post a reply to: 2018 YZ450F Problems Round 2
