TH Racing —>Updated. Now with more scam!
Tracktor
The RTF/Amboy, WA, USA
Edited Date/Time 12/3/2020 2:41pm
So I never have our cylinders done by anyone I like to do minor porting & cleaning on them myself and combined with reworking the powervalve linkages plus tuning our bikes have always ran amazing. I know enough to not grind away without having a dyno or flow bench at my disposal.
So I bought a couple 2017 Husky TC125’s from a friend who was getting out. One was a “Lorettas stock” build and the other a full race port job. Both done by a reputable company. Neither had been ridden when I got them. Both had minor problems in the first few hours like a powervalve retaining bolt coming out. I got such a good deal none of this matters money wise. I have a 150 kit sitting in box.
The full race one didn’t seem to run that well so I decided I better tear it down and see what was actually done. Maybe it doesn’t really matter but the porting looks terrible, grinder grooves everywhere and very non symmetrical. Even the case stuffing looks tacky. Any builders on here have an opinion?
He paid a good amount for it over a year ago. I will say we ran our stock bike with STIC Keihin carb against the full mod running their modded Mikuni and the stocker blew it away. More power for a tenth of the cost...
Tracktor
9/15/2019 10:57am
Bruce372
9/15/2019 2:12pm
You want a rough service so don't over think it.
Port height is very important, take your calipers and measure the heights and see the differences between cylinders.
I am looking for a 150 complete kit, how much was yours?
Bruce372
9/15/2019 2:14pm
Epoxy is important also, quite often, a good port job is about putting material back in and not taking it out
slipdog
Nor Cal, CA, USA
9/15/2019 2:39pm Edited Date/Time 9/15/2019 2:40pm
It looks rough but I would want to see better pictures of the port windows. And like Bruce said, measure the heights for all the ports from the top of the cylinder to the top of each port. KTM cylinder castings don't need much touch up
9/15/2019 3:00pm
slipdog wrote:
It looks rough but I would want to see better pictures of the port windows. And like Bruce said, measure the heights for all the ports...
Looks like you can still see some of the original untouched material in some of those ports. I'd say they have only just been touched and absolute minimum material has been removed.
Tracktor
9/15/2019 3:18pm
Looks like you can still see some of the original untouched material in some of those ports. I'd say they have only just been touched and...
Some places weren’t touched while others were hogged. I know you want a rough finish for flow its more the consistency that concerns me. There are quite a few places where the ports are extremely uneven with ridges & pockets everywhere. Doesn’t seem like that’s going to help flow. The port windows are all pretty close to stock most of the work looks to have been done from bottom of cylinder up. Almost like he didn’t have a 90 degree hand piece. I have a nice CC Specialties one so probably am going to go in and match everything up if nothing else for my own satisfaction.
The fact that both engines had parts fall out within a few hours adds to my concern.
Like said above these 125 cylinders pretty damn good from factory. I spend more time “porting” on the powervalve linkages than anything. Figured out a few tricks so they work smooth as butter..
Bruce, the 150 kit came with bikes so no idea what cost was.
Bruce372
9/16/2019 12:22am Edited Date/Time 9/16/2019 12:23am
Best ive seem so far is $831 for the 150 kit. Imo that's still amazing value, if you think you probably cant get a 125 japanese cylinder and head modded for that along with a new piston.
From what I can gather, there is very little parts required to transfer over from the 125 setup. People say ktm parts are expensive but I dont get that at all.
Fun fact, Eric Gorr is left handed, and had to teach himself to port with his right hand because of the availability of porting tools. The last 144 kit he did for me, I measured the port heights and they were within 0.1mm, probably more accurate than one could actually measure.
Tracktor
9/18/2019 10:48am
As a follow up - Port windows weren't touched. Basically anything that would have needed a 90 degree hand piece was left alone. To the point of having a step from ground to unground areas near windows.
For my own edification I spent some time cleaning up the ridges & craters/gouges throughout the whole thing. May not make a difference but I feel better knowing it all matches side to side and has a uniform rough finish.
Waiting for my updated STIC to get it all back together.
Overall I am pretty unimpressed by the work that was done. Both engines needed a decent amount of reworking to get running to my satisfaction. Maybe that's why this company has mostly gone in a different direction over the last couple of years?...........
9/18/2019 3:50pm
I feel ktm and husky have a good package in general, I agree on its nice to know that ports are fairly symmetrical in the cylinder, it can be pretty easy to make it worst, hopefully it runs good for you.
cwtoyota
Tacoma, WA, USA
9/20/2019 9:25pm
Tracktor wrote:
[img]https://p.vitalmx.com/photos/forums/2019/09/15/373152/s1200_A35FFCA1_1AC0_432F_8E12_68BBB5D55F8A.jpg[/img]
The rough finish and epoxy aren't bad. I question anyone's skill (or caring about their work) who digs in that bad on the inside corners.
I'm a machinist, I own/operate a small CNC shop, so I have an eye for detail. I also think there are people who don't need to operate manual machines like die-grinders and whatnot. After a six pack of my favorite cold ones I can hold a better straight line or smooth arc with a carbide burr than that... I wouldn't hire whatever shop that is to do any actual work.
A related story: A buddy recently had a problem with some KTM suspension from a well known shop. They installed the Race-Tech spring conversion in his Factory Edition AER fork. They cranked his pre-load all the way tight and failed to correctly set the length of the spring-cartridge (which is an inherently bad design from Race-Tech already). The result was two forks of different lengths and overly harsh suspension. There was what I considered clear evidence that they used a pair of channel-lock style pliers to tighten the preload nuts as well as a rebound adjuster hammered in with an impact gun so tight that the threads were galled beyond repair.
My thoughts on both of these situations (your porting and my buddy's forks) is that perhaps the shop hired a new helper without the mechanical and technical experience necessary to do the work unsupervised, or without the integrity to do good work unsupervised. Either of these hypothetical "new helper" explanations reflects on the judgement of the shop owner / management. I'd find another shop for future work and do my best to repair what you have there.
Tracktor
9/20/2019 10:32pm
cwtoyota wrote:
The rough finish and epoxy aren't bad. I question anyone's skill (or caring about their work) who digs in that bad on the inside corners. I'm...
I agree with your line of thinking. Believe me, after seeing this work & the huge bill I wouldn’t hire TH Racing to fix a wheelbarrow. They seem to focus on Harleys now so I am guessing they saw an easy mark with my friend.
I’ve cleaned it all up as best I could. Frankly at this point I would rather have it stock but we will see what we can do. I think i have a pretty good grasp of engines for an amateur. If you were at the Dream Race my youngest holeshot & won supermini on a home built bike & finished 3rd at Top Gun on it. Oldest was 5th at 125 All Stars on another home built bike. KTM’s don’t really need much to rip. It’s more in the tuning, imo....
cwtoyota
Tacoma, WA, USA
9/21/2019 12:16am
Tracktor wrote:
I agree with your line of thinking. Believe me, after seeing this work & the huge bill I wouldn’t hire TH Racing to fix a wheelbarrow...
Yeah, I was at the Dream Race. This year I rode the 250 Master and won the Freedom class.
Man, some of those supermini kids are fast and beating them all is awesome! Fifth in the 125 class is a real accomplishment. I missed Top Gun this year as my wrist has been injured since the end of July and I've done minimal riding since the two stroke weekend and it's getting better slowly.
CarlinoJoeVideo
Portland/Los Angeles, CA, USA
9/24/2019 6:26am
What shops are you guys talking about?
Tracktor
9/25/2019 12:09pm
The work on mine was by TH Racing out of Texas. They have a great reputation in the past so was really surprised when I opened it up (and that we had multiple bolts falling out of both engines plus the "LL Stock engine was running squish of .9mm). Their business is mainly Harleys now it seems so I figure this got done by some shop helper. No I didn't bother calling as all I didn't see what it would gain.
My boy rode the bike yesterday after I cleaned things up and it seems to run better. Not as strong on bottom as the other one with my work but strong on mid-top. Some tuning on PV may help this.
For the money a stock cylinder with STIC in carb is hands down the best set-up, IMO. Truly insane what they do to these bikes...........
Tracktor
11/5/2020 11:46am
So newest update - Just pulled apart one "stock" bottom end as the LH main bearing was making noise. You know one of those fancy "ceramic" bearings? Oh guess what? Not a ceramic bearing in the entire engine. What a surprise. $550 each for two bearing kits so they pocketed $1150. That's a neat scam.........
LKHill
11/5/2020 5:11pm
You boy got spanked. That porting is terrible.
sandman768
Saratoga Springs, NY, USA
11/5/2020 5:16pm
Tracktor wrote:
So newest update - Just pulled apart one "stock" bottom end as the LH main bearing was making noise. You know one of those fancy "ceramic"...
That’s worth a phone call imo...just to let them know you caught them ripping people off...
Moto520
Schaumburg, IL, USA
11/5/2020 7:26pm
I’d be pissed
15tc150
11/7/2020 7:45am Edited Date/Time 11/7/2020 7:45am
I’d be mad, that’s garbage, and the finish is terrible, they didn’t even get into the corners of the transfer ports either, and the bridges in the transfer ports, are not even smoothed out across the surface, and everything is irregular. I do my own port work, and it’s above and beyond what that is, there was no finishing by hand, and you can still see original port surface mixed in with the super fast dremel work, a textured or rough surface is one thing, an uneven surface is something else entirely
Tracktor
11/7/2020 9:48pm
15tc150 wrote:
I’d be mad, that’s garbage, and the finish is terrible, they didn’t even get into the corners of the transfer ports either, and the bridges in...
Same here. I ended up completely reworking it. I have a full set if nice porting tools. It runs solid now. Even if it didn’t effect how it ran take some fucking pride in your work. Put down the chisel & step away from the cylinder...But the blatant rip off of subbing standard bearings for ceramics is over the top. I will probably call them next week just to see what they say. Im sure no responsibility will be taken however...
Tuna
11/8/2020 10:54am
How was the bill paid? File a claim if it was PP or a CC.
11/8/2020 7:23pm
Honestly, I don't know how people have the balls to charge people money for crap like that.
12/3/2020 4:11am Edited Date/Time 12/3/2020 4:12am
The inside of the port ducts and anything else that sees a fresh fuel charge will run better with a rough feel, it makes for a better flow up and through the ports..anything that sees carbon like PV's, exh port, head can be polished for easier clean up and especially for a cleaner running pv system.
The dig marks on the sides of the port ducts is terrible work, as is the side to side marks, although rough, for god's sake make it a cross hatch or something slightly appealing to the eye!
I used to just remove the casting marks inside the ducts and then bead blast all the channels. To avoid all the beads hitting the plating, I would shove towels down in the bore and mask off certain areas. When done, it looked great and performed amazing. Also gasket match the boost port on the cyl base, match up the chordal width of the windows as well as the height and a few other small things.
The KTM 125 did not like a lot of compression, on the dyno it started to take off power on the upper rpm range, I ended up lowering the cyl base by .015" and then cutting the head a little bit to get 1.0mm of squish.
The Bill's Pipe seem to be the only pipe that cured a small dip in the power curve right around 10k that helped transition the engine from pv closed to pv open.
I also made a special cocktail of Renegade 110+93 e-free and a small oxy (about 5%) with some nitromethane and straight castor oil..although gummy, (hence the pv cleaning and polishing), the engine never got hot enough to burn off all the oil so there was always a small film of it all over the bearings and cyl walls, that's why you hear a lot about film strength. It smelled good to :-)
These bikes dont need 120 oct to run but when done in small stages, somewhere around 102 oct is fine to keep detonation away and have a strong runner all day.
Good luck, J
FWYT
San Diego, CA, USA
12/3/2020 9:12am
Hey Tractor- when you say "reworking the powervalve linkages", what exactly does that entail?
Tracktor
12/3/2020 12:36pm
Search around I think Ive posted about it in detail. If not ill write something up when not on phone. Basically polishing up the pieces until everything moves smoothly. ....
FWYT
San Diego, CA, USA
12/3/2020 2:41pm
Tracktor wrote:
Search around I think Ive posted about it in detail. If not ill write something up when not on phone. Basically polishing up the pieces until...
Ah, got it. Thank you; I will look it up!
Post a reply to: TH Racing —>Updated. Now with more scam!
