Virginia Beach, VA
12/21/2020 11:59am
So it’s starting to get too cold to work in my shop without a heat. I’m concerned however that if I warm it up in there and then let it get cold again or take a bike outside that everything will sweat and get water in places it shouldn’t be I.e. cylinders,suspension, steel fuel pales etc. Am I worried for nothing?
my two cents. -Я
My experience with propane is that it adds humidity, not enough to bother you, but it does, and it’s pricey.
My garage is 24 x 30 (720 square ft). I reckon this heater could keep 1000 sq ft comfortable and still be economical.
If your shop is big and uninsulated...I'd recommend a pellet stove. I'd also suggest spending the extra for one that will burn wheat/corn/rice. Wood pellets are getting pricey. A wood burning stove is cheaper up front but honestly...unless you have time to cut, split, stoke, and constantly clean out the ash...a wood stove is a pita. I ran a pellet stove on wheat in my old 60x40 uninsulated shop and it had no trouble holding 60 degrees all winter. And it was cheap as hell to run.
If your shop has power you can set up a mini split. Theyre not that expensive and will heat/cool the shop all year long.
We do have a pellet stove for the main house... so familiar with them... and would be interested to investigate putting one into the shop for those colder months (gets into the 20s in the mountains of San Diego)
You happen to have a picture of your old setup?
It was a huge selling point on the old farm. Damn place sold day one and over our asking price.
I do remember the multi fuel unit cost quite a bit more than a straight wood pellet version. Part of that extra cost was because it was thermostatically controlled.
Caveat, I do all my work-from-home stuff out here also, which was why I went all-in on the split unit.
I just built a 26x34 pole building and am currently insulating with R23 in the walls, R30 in the ceiling and will finish with tin. I’m gonna use a 45k BTU radiant tube heater.
Heater $660. Gas pipe, thermostat, vent pipe probably had for another $400. Yes, depending on the tank location and ventilation difficulties it may be more, but 4K or really even 3K is high.
Post a reply to: Work shop heater question.
