Shelby, NC, USA
It seems like one of my forks isn’t rebounding all the way back out. I can pull it up and then put very little pressure on it and it falls like half an inch or so. My other fork can’t be pulled up any farther. It seems to work good and rebounds all the way. Anybody had this issue before?
I assume you mean forks off the bike and one is "topped out" and one will sag down about 1/2", is that correct?
You can have no valving or oil in the damper and it will still come all the way back because of the installed length of the spring w/preload. If you don't have a broken main spring then I would measure the length of the springs(YZ250 should be 454mm) and check the preload(should be around 6mm +/- with 454mm spring) to verify.
It's about 3/8 of an inch (by eye) on a stock fork. I haven't measured them, but I would guess it's meant to be 8mm.
Did you try bleeding the air out of the forks before disassembly?
Did you measure the free length of your main springs?
Did you inspect the spring seats and spring-seat clips on the outside of the cartridges?
If your fork leg burped some air or oil out of the seal or bleeder, it could have had a vacuum inside which was fighting to hold it down shorter. (hence bleeding before disassembly)
Your issue sounded like a cartridge oil volume or free piston issue as others have said, but just offering a couple other things to check.
Can anyone tell me if the 2015 uz450 rear shock will fit on my 2007 yz250f
Post a reply to: YZ250 suspension question
