SOLVED: Mikuni TMX Clogged Pilot Passage
sdhuskyrider
San Diego, CA, USA
Edited Date/Time 12/4/2019 4:42am
Does anyone know where this angled passage drilled into the venturi goes? I'm trying to clean this carb out and I don't how to test for a blockage becuase I don't know what circuit it feeds.
sdhuskyrider
San Diego, CA, USA
11/29/2019 7:53am
Pilot jet
Thats what I figured and was afraid of. There must be a pinhole there that I can't see becuase of the varnish.
digger
Upstate, NY, USA
11/29/2019 8:11am
Pilot jet
Agree, Pilot circuit
Paul_Pitzonka
Grand Terrace, CA, USA
11/29/2019 10:07am
Pilot jet
Depends how plugged it is but ultrasonic cleaners work great for clearing out passages
camstop22
Easton, PA, USA
11/29/2019 1:19pm
Use a single strand from a wire brush and try to clear it .remove pilot jet and put the straw from a can of carb cleaner in its hole, it should spray out that hole in front of the slide.
sdhuskyrider
San Diego, CA, USA
11/29/2019 2:47pm Edited Date/Time 11/29/2019 5:55pm
camstop22 wrote:
Use a single strand from a wire brush and try to clear it .remove pilot jet and put the straw from a can of carb cleaner...
I ended up having to dip the carb in Berryman Chem Dip and clearing the passage with a welding tip cleaner. The Chem Dip softened it up and the tip cleaner was just barely strong enough to clear the blockage.
sandman768
Saratoga Springs, NY, USA
12/2/2019 3:50pm
I ended up having to dip the carb in Berryman Chem Dip and clearing the passage with a welding tip cleaner. The Chem Dip softened it...
I chem dip all my carbs on my old bike builds...
H4L
12/4/2019 4:42am
Yes, good stuff. Been using it since the 80’s with excellent results.
Post a reply to: SOLVED: Mikuni TMX Clogged Pilot Passage
