9/2/2020 10:28am
Anyone that's moved to the Honda axle set up or a set of Works Connection blocks on the newer KTMs, was there a difference at all? On hard pack the rear shock feels a little harsh on acceleration bumps or harsh off square edges in harescrambles I run, seems like the seperate axle blocks allow a little the rear end to be free'd up, before I drop the coin, can anyone tell me what they think of this mod?
Free shipping: VITALMX
Regarding the "floating" axle vs the stock style axle, it doesn't make any difference. There's nothing floating about it; the rear axle is basically just a big bolt and nut. The KTM style is analogous to a flange bolt while the Honda style is analogous to a standard bolt with a washer under the head. They're both torqued down tight enough so there should be no relative movement and they'll both do the same job (if there is movement, you've got problems!).
https://www.keeferinctesting.com/offroad-testing/2020/6/1/rep-knuckle-f…
Here is a photo of the factory KTM from Pit Bits this week, that rear axle is from a CRF, so even the factory guys are doing this.
I did it to mine, and while I can't feel a difference, I can sure get a more precise axle adjustment with the Ride blocks as opposed to the stock POS adjusters...
I bought a Yamaha and have the whole setup for sale at a very good price.
Post a reply to: KTM axle blocks
