Breaking tire bead
weland28
Eagle Grove, IA, USA
Just wondering if anybody had any good tips for breaking an old stuck tire bead on an mx wheel. I do not have a tire changing stand and I’ve done plenty of wheels on the ground I usually just struggle around with the stubborn ones till I get it. Just wonderin if anybody has some good techniques they do
kb228
Mansfield, OH, USA
3/2/2019 4:35pm
Take a tire spoon and pry down on the tire. Should break it. I havent had any that stuck but maybe heat or some kind of lube would do the trick too.
BR8ES
Bennett, CO, USA
3/2/2019 4:53pm
large C-Clamp if you have one of those around.
CarlinoJoeVideo
Portland/Los Angeles, CA, USA
3/3/2019 4:33am
Lay the new tire on the ground, then the old wheel and tire on that. You can stand on the old tire and pop the bead.
3/3/2019 7:28am
If it’s really stuck on there, lay it on the ground and run the tire part only over with a car.
BR8ES
Bennett, CO, USA
3/3/2019 8:16am
a vise will do the trick as well if you have one big enough.
3/3/2019 8:20am
Get an old school bumper jack. Place the wheel /tire under the foot of the jack, hook the other end to a stationary point, and crank the jack up.
Jbulz
Ithaca, NY, USA
3/3/2019 9:02am
Those are some extreme bead breaking methods!
Just stick the "hook end" of a tire spoon in the bead, and it will push the bead right down with no drama.
Falcon
Menifee, CA, USA
3/6/2019 1:56pm
I don't have any suggestion for you, but I want to let you know I feel your pain. And I'm here to talk, if you need it.
Victims of tire changing trauma unite!
mwssquad827
Twin Falls, ID, USA
3/6/2019 7:30pm Edited Date/Time 3/6/2019 7:32pm
Sound like a awesome way to break a rim/hub/spokes/sprocket/rotor anything! Please don’t do this on a Moto tire... if you have a ATV tire this method works great not on a Moto tire...SMH
Get a good tire iron and some get some, also I have seen the c clamp trick work as well never have done it myself tho..
3/7/2019 3:32am
Sound like a awesome way to break a rim/hub/spokes/sprocket/rotor anything! Please don’t do this on a Moto tire... if you have a ATV tire this method...
I agree it’s not the safest! It works though
3/7/2019 10:21am
Take it for a lap around the track, break both beads at the same time ?
Moto88
3/19/2019 1:47am
Not a technique but if your changing tires on the ground, do yourself a favor, get an empty 35 gallon oil drum. Holds wheel perfect, saves your back, and serves as a good shop trash can.
Post a reply to: Breaking tire bead
