Southern California, CA, USA
I bought a 2002 XR80 for my son. The bike has been sitting for a number of years. I cleaned the carburetor, put fresh gas in, cleaned the air filter and changed the spark plug. If I blip the throttle real hard while bike is idling it bogs down. If I roll the throttle on it is responsive. When I ride it starts to sputter in all gears at about half-throttle. I cleaned the carb a second time and replaced the pilot jet and still does the same thing. And it won't start with the choke on and dies if I turn the choke on while it's idling. Any ideas I appreciate!
Did you do a complete carb soak cleaning?
Good luck Scooter!
Have you checked the coil by doing an ohms test? It could be a bad or dirty plug wire or connection.
Sounds strange that will start with the choke "off" then run rich(sputter) when riding.
Post a reply to: 2002 XR80 problem
