rmz 450 2008 problem
Edited Date/Time 12/30/2013 12:46pm
hello, i have a 2008 rmz 450 and i am having a problem with it,
bike starts up but only runs for 6 seconds and turns itself off, i have fitted a new stator and htc lead and coil i was told by a mechanic that this was the problem, but after i had fitted these new parts the problem still existed, thinking it could this be a wiring problem or senor, i have checked the roll over sensor just and it is fine any suggestion, thanks for your time
i would be happy enough to buy a wiring harness for this model if anyone has one on this site as there is none anywhere for 2008-2013 fuel injected bike i hope use can help many thanks.
MxKing809
Big Sand Whoops, MI, USA
12/14/2013 7:05am
Not entirely confident on what your issue is, but check all of the connectors in the air box and the back of the cylinder for corrosion. Get some dialectic grease and just clean all your connections and lube them up. It may be shorting and tripping your EFI system. Also check the head of the sensors as well, they may be a build up of dirt and filter oil on your air sensor (in the air box) that is choking the bike out
12/14/2013 9:25am
Are sure it is electrical? You might check to see if the fuel pump filter is blocked/clogged. What has happened from when it ran with no problems to now with problems? Has it been sitting long? You might try to disconnecting the kill button.
Paw Paw 271
Benton, LA, USA
12/14/2013 11:05am
I agree it seem to be a fuel low issue. Can be caused by dirty vent tubes too.
Rmzrider183
West Grove, PA, USA
12/14/2013 1:39pm
my rmz450 had the same issue, ended up being a ripped wire coming out of the fuel pump, i fixed it and havent had an issue since
pete24
Marlborough, MA, USA
12/14/2013 4:08pm
suzuki sell a diagnostic light that plugs into the wiring under the front plate you run , or kick the bike over and it flashes the codes that are listed in the back of your manuel, i bought one i think it was 35 dollars you should start with that seems like you been throwing parts at it
12/15/2013 1:40pm
thanks for all the replies, i will answer all your questions in this reply, after a days riding this accrued the next day when i went to start my bike, i have checked the fuel filter and is not blocked, i assume if it was a low fuel problem the bike would start to die out but this dosent happen. it starts perfectly and runs for 6 second and it is a sudden stop as if a break in a wire or sensor i think this because normally bikes with ignition switch u turn once and the cdi checks for problems before starting, my rmz hasnt got this and im thinking when the bike starts the cdi does a check but if there is a problem the cdi will turn of the bike, i will check the wires below the tanks tomorrow, my loom has a lot of insulting tape around it and looks like someone was woring on the harness, it would just be easier if anyone on this site new of any loom from 2008-2013 are forsale, i appreciate all the reply thanks
12/16/2013 1:13pm
pete24 wrote:
suzuki sell a diagnostic light that plugs into the wiring under the front plate you run , or kick the bike over and it flashes the...
can u send a link on where to buy them thanks
downard254
Bremen, OH, USA
12/18/2013 3:24am
Call Goose, I think Dungey had the same problem once in 2011. Whistling
Just kidding, hope you get it figured out. I hate intermittent electrical issues.
lumpy790
York, SC, USA
12/18/2013 7:30am
Sounds like fuel supply to me. loosen the gas cap and test. Check the fuel pump
12/18/2013 12:02pm
lump i think its a fuel problem myself but i cant figure out how to check the injector, what do you mean loosen the cap and test what should i be looking out for, could it be the cdi thanks for the replys, fuel pump seems to be ok i think cause if its able to make the pressure to open the injector it shouldnt have a problem then once the bike starts maybe im wrong
lumpy790
York, SC, USA
12/19/2013 9:44pm
loosening the gas cap takes the possibility of a clogged cap and hose out of the equation.
12/23/2013 10:13am
I done that and the problem still exist, any other options
12/23/2013 8:36pm
1st thing you need to do is buy a service manual.
jsmx97
12/24/2013 6:18am
if you want to check to see if the injector is spraying pull the airbox off, open the throttle butterfly and have someone kick the bike over for you. You will see if it is or not.
12/29/2013 5:45pm
i have a service manual and it doesn't seem to tell me the problem, would throttle position sensor cause this, i need option anyone at all help thanks really frustrated.
Top End
NOR-CAL, CA, USA
12/29/2013 6:20pm
I had the same problem on mine I was running a Yoshimura pim2. I took it off and went back to the stock system and it fired right up. Upon looking at some of the connecters I noticed some of the pins backing out of the plastic holders.
12/30/2013 12:46pm
Top End wrote:
I had the same problem on mine I was running a Yoshimura pim2. I took it off and went back to the stock system and it...
im running standard system, ill check tomorrow on the connectors, now bike wont start
12/9/2016 11:20pm
I know the thread is old but I didn't see the solution posted. Here is the answer: Suzuki has a TO sensor either on the bottom of the tank in the rubber boot or mounted on the frame in front of the valve cover (depending on year). TO stands for Tip Over. The bike is designed to stall if on its side in a crash. The reason 20 seconds is so you can Corner. Some models have a ball inside that moves and if you bend it they need to be bent back. Others have s sensor and need to be mounted in the right orientation.
Post a reply to: rmz 450 2008 problem
