Virginia Beach, VA, USA
2/19/2013 8:29am
Anybody ever cut their sub frame so it's shorter? My bike sits a little high, and I hate the look of cut down seats. I will get a shorter seat if it ends up being the only way though. I have access to world-class welders, but I am a little scared of things lining up again after its done.
Or if it's even worth the effort.
Anybody got any advise?
What do you gain in loss of seat height? Is it worth the trouble?
You should also cut the the seat down as that is more noticeable in the front area where you sit and the 2 mods go well together. I had Josh at MXSeatPro lower a seat for me. He does excellent work. It looks professional when he is done and most people would not even suspect the seat was lowered without looking twice.
http://www.mxseatpro.com/
Did you try any of these mods? I have a new RMZ250 coming and it will be high for me (5'6"). I am giving consideration to cutting the subframe down 5mm. That is only about .20 of inch but, I hear it makes a big difference. The other option is a link like the one from Devol.
Take care and ride safe,
Brian
I have the Pro Circuit link on my KX450F and it dropped the bike 10mm but I still feel it is too tall. I was hoping to hear from others who have done it, but I think this is a rarely done mod outside of the race teams.
It's just easier and safer to cut down the seat - but I was hoping to avoid it.
If you want to get into suspension limiters, they can be made for next to nothing, and you can lower the bike however much you want. However, to keep the same chassis geometry you need to lower both the front and rear equally.
I wouldn't lower the subframe too much or your back wheel may bust through your fender. There's not much, if any room there. Any bike I've had I've seen black tire marks on the inside of my rear fender.
Post a reply to: Sub-Frame Shortening/Cutting
