Swindon, GB
1/26/2012 5:09am
To help reduce cost and give a much more equal engine performance does it make sense to look at these type of engine regulations?
Maximum RPM (mandatory limiter, this would increase engine life and minimize engine development costs)
Maximum compression ratio limit (say 13: to 1)
Maximum Valve lift (say 12mm)
Maximum Throttle size (restrictor)
Minimum piston,crank & con-rod weight
Would this be a good or bad thing for MX?
Just let them run in the 250cc class and your problem is solved...........
Free shipping: VITALMX
Supply the motors an hour before practice?
2010 FIM MX Rules
FIM Announces 125cc 2-stroke class and 250's
Cool that there'll be a 125cc smoker class and they'll let 250 2T's run against the 250 4's.
why do we need regs?
cut out an entire cottage industry of engine builders?
You think that HP is what gets riders hurt?
You think engines are the largest exspense?
Get rid of the FIM and the AMA,try that
but it could also stop development altogether.
but 99.5% of all who have ever rode a dirty bike
can not run it at more than 90% or so of what it
is able to do. straight line drags do not count.
tracks with only left hand turns?
Wonder how it turned out?
Unfortunately that solution is too expensive, it seems it's much cheaper to keep the 250f's and build 350's with EFI , maybe add traction control next and some fancy ignitions.
In moto, it really is all about the rider. Mostly.
If you have a 250F that makes 43HP at 10,000 rpm verses a stocker making 36-38HP at 12,000 rpm, the reliability of the stock engine is greatly reduced. The mod engine is working less to produce more.
Maybe they've changed drastically during the couple years since he said this but KW compared it to running a showroom car at Daytona.
HP = Torque x rpm / 5252
That means with engines of equal displacement the only way to build more horsepower is to increase the volumetric efficiency, through cam/porting/compression/exhaust/carb mods, and spin it faster.
The only way to make more hp at a lower rpm is to increase the displacement.
Ain't two-strokes great?
Post a reply to: Engine regulations
