Boiling fuel?
newmann
Edited Date/Time 1/14/2016 11:39pm
Other than in the pits with chunks of dry ice and a can of race gas, educate me please.
Jon_Haynes
Clinton, IN, USA
1/14/2016 11:45am
Don't use a open flame, sorry had to be dumb ass.
Dragoo168
1/14/2016 12:06pm
Gasoline can boil between 100f - 400f,... Unshielded tanks on bikes running too hot/lean? Long-live the air-cooled bikes that never had those issues, Hah!
GrapeApe
Mc Kinney, TX, USA
1/14/2016 12:09pm
This is a Ryan Dungey thread . . .
newmann
1/14/2016 12:30pm
Yeah, no, ummm maybe, not? Heard this term more than once though and it usually ends poorly. I need more info, it's vital.
I once boiled some fuel, but we immediately put it in a bike that pulled a holeshot at a kind of big race. Cool
GrapeApe
Mc Kinney, TX, USA
1/14/2016 12:48pm
newmann wrote:
Yeah, no, ummm maybe, not? Heard this term more than once though and it usually ends poorly. I need more info, it's vital. I once boiled...
Just like Greg Albertyn, Mark Kvamme and the AMA, you've been seeking the truth regarding that fateful day at Freestone for a long time Laughing
newmann
1/14/2016 2:53pm
And it sounds as if you have had your eye on me for a long time. So, do these jeans make my ass look big?Laughing
Man, all these people over the years talking about boiling fuel and no one can give me a good explanation of what it means and how it happens on a dirt bike?
Torco1
Corona, CA, USA
1/14/2016 3:00pm
What you need is a decent sized metal spoon that is somewhat pliable, a penny or something made of copper, a cotton ball, a little lime juice and of course a clean rig. Then you'll......ooops, sorry......wrong thread......
Olson
SE
1/14/2016 3:11pm Edited Date/Time 1/14/2016 3:11pm
Not sure if this is a serious thread. But I think you need to go down deeper to a molecular level and look at what happens to the hydrogen and carbon under heat and pressure. Regular gas is C8H18 and has a high boiling point due to the bonds. Don't know about race gas. I've only come across this term a handful of times, Dungey and Metcalfe comes to mind but not sure if that is what actually happened.
GrapeApe
Mc Kinney, TX, USA
1/14/2016 3:24pm
newmann wrote:
And it sounds as if you have had your eye on me for a long time. So, do these jeans make my ass look big?:laugh: Man...
Your ass is beautiful, I don't care what anyone else says.Kissing #nohomo #wellmaybealittlehomo #notthattheresanythingwrongwiththat
newmann
1/14/2016 3:55pm
Olson wrote:
Not sure if this is a serious thread. But I think you need to go down deeper to a molecular level and look at what happens...
Serious enough, seriously. I don't need a chemical engineer to explain it to me because I wouldn't understand it anyway. Just a real basic explanation of how it happens in a motocross bike.
Dragoo168
1/14/2016 4:32pm
Heat newmann,....HEAT!!!!! It's literally that simple!!! Think about how hot a modified bike runs, and then it will make sense without some pot of fuel over a burner experiment. I doubt that there has been a boiling fuel incident on a cold day, but if anyone doesn't think that a modded engine on a hot day cant raise the temps enough in a plastic or metal fuel tank, then they need to think back to when Yamaha introduced the Yz400f's, and advised tech-line reps to tell freaked out shops to advise their freaked out customers to "ride faster", and that the header pipe glows because the bike was made for racing, not idling, LOL! It's also why the teams run heat shield material on the underside of their tanks.
byke
Auburn, CA, USA
1/14/2016 4:54pm
What does it mean? It's when heat cause molecular separation. Last summer I stopped to check my gas and when I opened the cap, the fuel was dancing as if I were still riding.
hillbilly
Afton, TN, USA
1/14/2016 6:00pm
Alcohol boils at about 165 degrees.
slowgti
Monroe, GA, USA
1/14/2016 6:08pm
Hillbilly is correct, it's mostly the alcohol in pump gas. Oxygenated race gas has a lower boiling point than standard race gas.
hillbilly
Afton, TN, USA
1/14/2016 7:02pm
Fuel today is junk,the ethanol hoax makes reliable or repeatable performance from a pump impossible.
Lots of places here sale straight gas for about a dime more a gallon.
Well worth it.
1/14/2016 7:18pm
It's more of a concern at higher altitudes.
In Colorado we would run heat deflection tape on the tank as an added precaution.
Also, cold fuel is supposed to burn better.
1/14/2016 7:56pm Edited Date/Time 1/14/2016 7:58pm
When you think of "boiling" often you associate to water.
But more accurately put its the conversion of any liquid into a gas... Water into steam..
Gasoline into vapor.
Some of the "components" of gasoline have very low evaporation temperatures... Or "boiling" temp.
Acetone for example is a liquid but if you leave it out un sealed it will evaporate or "boil"
All gasolines are made up of a wide range of hydrocarbons... Race gas is not much different.. Just more aptly choosen ones.
The really high dollar race fuels have a selection of "components" that evaporate at low temperatures relatively speaking. Around 100 degrees and many begin to boil. On a four stroke... In outdoors, this is very low temp and the underside of the tanks sees much above this.
On a hot summer day on a four stroke... Pour in some mr pro6 and after 15-20 minutes stop the bike in the pits turn off and pull the gas cap, put your ear near it. You will hear the unmistakable sound of bubbles as if you had a pot of water on the stove.
As the fuel converts to vapor... It leaves the tank and contributes Fuel loss.
On modern efi bikes... When the pump is working... There are no vapor issues in the fuel line. Fuel boils at a higher temperAture at higher pressures (and why at altitude it boils more easily- less pressure)
slowgti
Monroe, GA, USA
1/14/2016 8:06pm
hillbilly wrote:
Fuel today is junk,the ethanol hoax makes reliable or repeatable performance from a pump impossible. Lots of places here sale straight gas for about a dime...
Well worth it.
It is pure garbage, we have to run way more pump than we need to in the automotive world because of that. E85 in a can is fairly cheap though.
mxfiend
Riverside, CA, USA
1/14/2016 8:21pm
So you are human... i started doubting it for a while... i dont think ive seen you ask a single ? before. You are usually answering everything spot on lol
FreshTopEnd
Sacramento, CA, USA
1/14/2016 9:20pm
I think Hillbilly's familiarity with the boiling point of alcohol is pretty well established among us MD veterans
BobPA
1/14/2016 9:54pm
Closer to 173....but you start seeing some clear coming through the filter in the low 160's......
KMC440
1/14/2016 11:39pm
I couldn't believe it took 15 posts for Hillbilly to put the jug down and start typing.
Post a reply to: Boiling fuel?
