2020 RM144AF conversion
dang472
Kingston, IL US
Edited Date/Time 6/21/2022 12:26pm
I’m almost finished with my AF conversion and thought I’d start sharing photos and knowledge along the way. Bottom line is that the conversion is much more involved than the original SwapMotoLive article stating the engine drops in with minor motor mount relocation. I started with a JGR 250 frame/swingarm, newer 49mm Showa A-kit, and stock hubs cerakoted by me laced up to new yellow Excels.
Next, I borrowed my 04 RM144 engine out of my steel frame for the mock up.
12
dang472
Kingston, IL US
12/21/2021 5:47pm
Here are some initial settings. Headstay was fabbed in the center and new front engine mounts machined.
dang472
Kingston, IL US
12/21/2021 5:53pm
Lower 250f engine mounts cut off and a new set were CNC’d and welded in place
After the mock-ups, the headstay was welded in place
11
dang472
Kingston, IL US
12/21/2021 5:58pm
Plate to block off the fuel pump location and mount a Honda CR petcock
New Scalvini cone pipe had to have the rear mount moved and one of the spring tabs tacked over a bit.
15
dang472
Kingston, IL US
12/21/2021 6:08pm
We were able to use an OEM airboot from an 01-07 RM125 but had to fabricate an adapter plate from flat HDPE/delrin if I remember right. I’ll take more pictures of that when I pull it apart. Also, all of the radiator hose nipples had to be removed and relocated. Hose routing incorporated a CR250 3-way splice above the cylinder head. I’ll grab better pictures of that as well.
dang472
Kingston, IL US
12/21/2021 6:10pm
12/21/2021 6:11pm
Any chance you have a skid plate off that jgr 250f for sale
dang472
Kingston, IL US
12/21/2021 6:22pm
No, I believe this was Jared Keller’s personal bike when he worked for JGR. It was parted out and I just bought the big chassis pieces. The frame is only stamped “JGRMX2020” where the VIN should be.
CDI unit was relocated behind the fuel tank and under the seat
dang472
Kingston, IL US
12/21/2021 6:31pm
Here’s a few “completed” bike pics when it came home from the fab shop. I’m pulling this engine out and putting it back into my steel frame. I have a 2005 RM144 engine that needs to be vapor blasted, rebuilt, and loaded with carbon fiber goodies for this build.
dang472
Kingston, IL US
12/21/2021 6:34pm
23
dang472
Kingston, IL US
12/21/2021 7:04pm
Mike Westbrook, owner of M-Worx Conversions did the fab work. He has done a bunch of CR-CRF conversions and is only 40mins from my house. This was his first Suzuki but he had his CNC guy make up at least one more set of frame brackets. Now he has everything to do this conversion quicker and cheaper.
Another big roadblock is the countershaft sprocket alignment. I believe it is off 3.5mm in stock form. Exactly half the thickness of a new Renthal sprocket. The alignment is too far in so there isn’t enough material to machine a standard sprocket and add a spacer. We’re having custom offset 12T sprockets made and hardened right now. I think it’s going to cost $100-150 because of the small batch.
Another issue is finding a longer shifter. The distance from center of footpeg to center of shift tip is an inch shorter than my steel frame RM250. I wear size 11 boots so I’m playing with different shifters. I wish Hammerhead had a RM125 shifter with a +20mm tip.
quiknic
Santa Clarita, CA US
12/21/2021 9:14pm
Thanks for documenting this conversion, we are also doing the same conversion on a 2020 RMZ250 with a 2006 RM125 motor and have found the same issues that you have been dealing with.
If you are going to have some of the offset countershaft sprockets made I would be interested in buying 3 or 4 of them if that helps with the costs.
What radiators are you using? it would be great if you have additional details & pictures of them and the rest of your build. Are you using an A-Kit shock and was there any clearance issues with the air boot? I had purchased an Suzuki OEM (Y) branch to use for the radiators if you wanted the part number along with an OEM air boot.
Good luck with the project and keep us updated on your progress and first ride.
dang472
Kingston, IL US
12/22/2021 5:38am
We used the oem RMZ radiators but moved all of the hose nipples. I’ll take some more detailed pics soon. I’ve got a few projects to finish up and then this will get my full attention.
I see no rubbing on the shock from the airboot. I used the stock Mikuni TMX for the mock up but I have a new Lectron HV38 that I’ve been debating on using. I’m pretty sure I’ll stick with the TMX because the jetting was spot on for the 144 kit. Bruce372 knows how to jet a 125/144.
I’ll check with my machinist on the progress of the sprockets. I ordered 2 for myself and I think M-Worx will have a few as well. I can tell him to do more if your interested.
quiknic
12/22/2021 7:09am
Sounds good. I will buy a few of the offset sprockets if there are spares made, just let me know.
I still need to find an RMZ250 left hand radiator as I did not have them to start with. I can not find any aftermarket radiators for the RMZ250 but they are available for the RMZ450 and I bought a set of them. The right hand side is the same between the 250 & 450, just the left hand side is different.
Here are a few shots of the starting points for our build:
dang472
Kingston, IL US
12/22/2021 7:33am
Awesome, my fabricator has all the billet frame pieces if you want to skip that work. He has the front mounts, lower billet mounts to weld in, and the center headstay piece to weld. He could tell you which headstay brackets he used as well.
quiknic
12/22/2021 7:49am
dang472 wrote:
Awesome, my fabricator has all the billet frame pieces if you want to skip that work. He has the front mounts, lower billet mounts to weld...
That would be great, you can send me your contact info or your fabricators info if you wanted me to reach out directly. I will send you a PM with my contact information now. Thanks again and pumped to see these machines come together!
Looby321
NY US
12/22/2021 3:07pm
12/23/2021 8:26am
dang472 wrote:
Mike Westbrook, owner of M-Worx Conversions did the fab work. He has done a bunch of CR-CRF conversions and is only 40mins from my house. This...
Mike really knows his stuff and is cool as hell. I bought his 05 cr125 he used for indoor riding. I saw your bike on 10-2 when I was there. I was like Wow what’s that , can I look at it ? He was pretty excited to build your bike. What class do you race ? I will b racing 50+ and 125, maybe 40+. I,m using the 05 engine in a 04 chassis. Might go with a 2 mm stroker crank so you 144,s can’t get away so easy. Haha
12/23/2021 11:37am
There's a guy In Japan that sells a kit to do the conversion I follow on Instagram his page is ttk0112 I'm tempted to convert my 250f to a 144,
dang472
Kingston, IL US
12/23/2021 2:37pm
I’m not on Instagram, so does he have a price for the conversion? I’d like to see how he got around some of the challenges like we had to do.
dang472
Kingston, IL US
12/23/2021 4:34pm
Looks like a bolt on without permanent frame mods which is cool. I’d really like to know what he did about chain alignment because there is no possible way to slide the engine over enough to make it work with a standard sprocket. My exhaust is ridiculously close to touching the frame cradle.
dang472
Kingston, IL US
12/23/2021 5:43pm
Mike really knows his stuff and is cool as hell. I bought his 05 cr125 he used for indoor riding. I saw your bike on 10-2...
Prior to kids and a real career, I raced 125B/250B and 14-24 in northern IL and southern WI. A few seasons of amateur AX, nothing too exciting. I get around decent for a 38yr old who likes cheeseburgers and has to function without a cast on Monday morning. My 3 boys are the reason I’m back at the track so I figured I better have some sweet bikes to play with. My 4 Suzuki 2 strokes account for roughly 40% of the Illinois yellow brigade.
I worked at TUF Racing through high school and after doing parts and wrenching. I followed Andy Stacy around to a few other dealerships until the whole empire collapsed around 2007-2009.
wpark89
Mattawa, WA US
12/24/2021 5:50pm
But does your wife know how much money you’ve spent on this project when you could have been doing Pinterest projects for her or building furniture out of old barn wood?
dang472
Kingston, IL US
12/24/2021 10:46pm
If you keep the motorcycles the same color, it gets confusing for the womenfolk. I just got her a new Bronco so that should keep her quiet for a month or two.
12/25/2021 8:01am
dang472 wrote:
Prior to kids and a real career, I raced 125B/250B and 14-24 in northern IL and southern WI. A few seasons of amateur AX, nothing too...
Oh cool TUF ax bikes r Rad. Tj has custom gripper seats of al colors you can add letters. My cr,s will hv blue and a yellow cover with Tuf on them. Ever race Sugar Camp or Crystal falls in the UP, I Love those tracks. Too bad SC is gone. How about Denmark it’s a off rd riding park now. Step ups r there but the whoops and jumps r gone, pit area has off rd riding.
Bruce372
12/25/2021 12:38pm
My friend owns and operates Xmas motocross up in the UP.
I never made it up there when I lived back in the Midwest, but hoping for a road trip this summer
12/26/2021 9:08am
I never been there but anyone who has says it’s perfectly prepped with a good flow and fun but safe jumps. Dang,s RM build sounds like a lot of work,can’t wait till it’s done.
DerickYZ
Salamanca, NY US
12/26/2021 3:31pm
dang472 wrote:
If you keep the motorcycles the same color, it gets confusing for the womenfolk. I just got her a new Bronco so that should keep her...
This….is the advice I was needing 😂😂
dang472
Kingston, IL US
5/19/2022 11:11am
14
dang472
Kingston, IL US
5/19/2022 11:12am
Finally got it done. Hoping to ride it soon if it stops raining every other day.
Post a reply to: 2020 RM144AF conversion
