Engine oil/Factory HRC Team
carlbaptiste
Boston, MA, USA
Is the AI statement below true??
I have a brand new CRF250R with less than 1hr on it. Still has the original factory oil in it. I'm looking for the best possible race spec oil for the best protection. I'm looking to stick with Pro Honda but would like to hear other suggestions. I used GN4 in my old bikes but never really thought about it. It's the lowest quality oil Honda offers for offroad vehicles. I will be riding my bike at the track 90% of the time. I'm not new to riding and I'll most likely be in the A/B class sessions once I get the feel of the bike.
What I have in mind is the Pro Honda HP4RU 10W-40(New England).
Also, if they run Motul then why don't they have any logos on their bikes? I had no clue they used Motul until I asked Google AI today.
1000010972
Ontario, CA
4/20/2025 2:49pm
Factory HRC Honda in MXGP uses Motul.
Motul makes great products.
Leeham
Rochester, WA, USA
4/21/2025 8:31am
Just change whatever motorcycle spec oil often. That does more than anything. My bikes run the oil only for max 3 hours then I change it. Might be changing it too often and wasting money but hasn't failed me.
carlbaptiste
Boston, MA, USA
4/21/2025 9:00am
Leeham wrote:
Just change whatever motorcycle spec oil often. That does more than anything. My bikes run the oil only for max 3 hours then I change it...
Exactly. My plan was to change oil and filter every 2-3 hours on the clock. The manual says it's good for up to 15 hours which sounds very risky. They also recommended that you use the GN4 mineral oil... They are not even recommending their high end oils for this bike. At least in the service manual...
4/22/2025 12:34pm
I use motul 300v, its ester based which is the highest quality I think, someone will correct me. Do Hondas still have separate oil/trans?
4/22/2025 1:39pm
Use a quality oil ✅
Change it when you feel it’s necessary ✅
4/22/2025 9:10pm
I think the majority or teams use motul, regardless of what brand sponsors them. That’s enough for me to run it
PRM31
Northern, VA, USA
4/24/2025 3:14pm
300v is sure great in an R6 that lives between 10k-16000 rpms. I am still using Motorex in my KTM and if I switch it will be to Motul 300v.
Falcon
Menifee, CA, USA
4/25/2025 12:59pm
"Highest quality" is sort of a misnomer when talking about base oils. Ester based oils usually function in a way that is most preferable to high-performance engines, but there are some oils that are better in other ways. As mentioned above, changing your oil often is the best practice for long-term protection. To facilitate that, using a mineral oil like the GN4 is a great way to go; cost-effective and still very good.
Here is a brief explanation of base oils. They are broken down into 5 groups, based on their composition and characteristics. (Moto Tribology can probably come on here and educate us all further.)
-Group I: Mineral oils (conventional oil). This group is comprised of dead dinosaurs. Refined, cleaned and packaged. These oils may contain additives for multi-viscosity, better wear protection, engine cleaning, seal conditioning, or other functions.
-Group II: Mineral oils, hydro-cracked. This group is also dead dinosaurs, but is processed and refined more thoroughly through a process known as hydro cracking. As I understand, it is boiled or steam-injected or something. The oil manufacturer gets a better separation of heavy and light elements and can produce a much more homogenous product by selecting one of the "layers" of resulting oil. Most "conventional" oils are group I or II, or a mix of both. I believe theat GN4 is one such oil, but don't quote me on that.
-Group III: Mineral oils, extreme hydro-cracked. This is where things get confusing. Group III oils are still dead dinosaurs, but they have been so highly refined that they behave a lot like synthetics. In fact, international law allows blenders to call oils in this group "synthetic," even though the base oil wasn't really man-made. You can legally call a Group III oil a full-synthetic, and actually many, many brands do exactly this. In fact, you only need to have a large percentage of your oil made from Group III and the rest can be Group I - it's still a synthetic oil. Lots of "medium-cost" synthetics are of this configuration. I think HP4 is this kind of product.
-Group IV: PAO. Polyalphaolefins are a group of synthetic molecules that are the base for these oils. The molecules form sort of a ring that attaches to itself. These oils are really good at resisting breakdown and are great for long-interval oil changes. The original Mobil 1 oils were PAOs (may still be.) Bel-Ray uses PAO in a lot of their products.
-Group V: Everything else. Group V is anything that won't fit into the first four categories. Esters are part of this group, but so are vegetable oils like castor. (Ester is synthetic, castor is not.) Esters cling to surfaces very well, so they are great at protecting engine parts from scuffing and wear. Lots of high-performance brands use esters in their high-end formulations. HP4S and HP4RU may be ester synthetics. (Again, don't quote me on that.)
One final thought: Oils these days are all pretty good. As long as you are using a motorcycle-specific (wet clutch) oil and changing it often, you should be fine. Higher performance mostly comes from longer oil change intervals due to less degradation of the oil - a process that is irrelevant if you are changing the oil often. Modern 4-strokes destroy oil, even the good stuff. Change it often.
carlbaptiste
Boston, MA, USA
4/25/2025 1:28pm
Falcon wrote:
"Highest quality" is sort of a misnomer when talking about base oils. Ester based oils usually function in a way that is most preferable to high-performance...
Thank you!!
And yeah when I asked about best quality I was referring to an oils that can last long between oil intervals in extreme conditions. I still plan on doing my oil/filter every 2-3 hours so my engine can wear as it should overtime.
4/26/2025 9:42pm
at a minimum run what the manual says. From there, as long as you're at the same viscosity you can spend as much as your conscious is comfortable with. Honda says run 10w-30 conventional MA2 rated. anything above that is blue sky.
Post a reply to: Engine oil/Factory HRC Team
