Clutch Belleville spring replacement
Moto520
Schaumburg, IL, USA
Guys…..how long do you all go on the Belleville spring before replacement.   I’m at 45 hours so throwing a rekluse Torq-Drive clutch pack into my yz450f.  What’s the advice on this?
Moto520
Schaumburg, IL, USA
2/14/2025 7:16pm
If I don’t get a reply by someone before midnight eastern…….i’m taking this to the Moto-Forum
Zzips
South Side, IL, USA
2/15/2025 4:35am
Ev put a new spring in it for the few bucks, seems senseless not to if you’re doing plates/discs.
willbilly
Corpus Christi, TX, USA
2/16/2025 5:55pm Edited Date/Time 2/16/2025 5:56pm
I leave the spring on until clutch starts slipping. 160 hours and it hasn’t happened yet. I would recommend the stiffer spring from RMATV with the Rekluse. The lock up is more positive.
aees
2/17/2025 9:25am
Couple of things.
The small movement of the washer and that it is actually not torqued that hard I have a hard time believing it will wear out. @Luxon MX should know best.
Second , you can adjust washer using the 3 settings for the washer depending on stack height and wear. Surface of washer with clutch out and fully torqued should be pretty much flat, not convex or concave.
Third, on Yamaha you need to replace the rubbers holding the clutch hub. They wear fast, and will eat up your clutches within 10h if they are not good. Replace those often. They are cheap.
Moto520
Schaumburg, IL, USA
2/17/2025 11:44am
aees wrote:
Couple of things. The small movement of the washer and that it is actually not torqued that hard I have a hard time believing it will wear...
Couple of things.
I was wondering about the rubber dampeners.....i will inspect when i'm in there.  Rekluse says to use the old belleville washer.
Luxon MX
San Diego, CA, USA
2/17/2025 12:35pm
Couple of things.
If the design is well done, a Belleville washer should not wear out at all. But if it goes beyond the material yield point for whatever reason, then it should be replaced. I don't know enough about this clutch design to know whether that may be the case or not. I'd imagine they're fairly cheap, though? If so, just go ahead and replace them.
aees
2/17/2025 12:54pm
Couple of things.
Luxon MX wrote:
If the design is well done, a Belleville washer should not wear out at all. But if it goes beyond the material yield point for whatever...
15-20 usd i think so not expensive
aees
2/17/2025 12:57pm
Couple of things.
I would replace them. They will shrink and it can be hard to see if you have noting to compare with. They break also but I replace them before they break now, but there it still shrinkage and that makes clutch lazy
Post a reply to: Clutch Belleville spring replacement
