Asking AI to answer your tech questions
I've been playing around with AI chat bots and figured a good test of accuracy would be to punch in your tech questions and see how good the answers were. Overall, not perfect but quite a bit better than I would expect. Here are some examples:
Prompt: I just picked up a throttle body for my 2021 SX-F 350 and noticed rocking in the throttle cam, is this normal? Has anybody got a parts diagram that shows the throttle assembly inside a KTM throttle body? (The KTM parts diagram does not show this) I took it all apart and there is a brass spacer, a plastic piece that goes over the brass spacer, then the throttle cam and nut. With the nut fully tightened down there is a gap between the nut and throttle cam...am I missing anything such as a shim/washer?
Response:
No, a little rocking in the throttle cam on your 2021 SX-F 350 shouldn't be a major cause for concern. There typically is a slight amount of play designed into the throttle assembly to allow for smooth operation.
Here's how to address your concerns:
Check for Excessive Play: While some play is normal, excessive rocking can indicate wear or a potential problem. Try to quantify the rocking. If it's more than a millimeter or two (less than 1/16th of an inch) then it might be worth investigating further.
Parts Diagram Limitations: You're right, the stock KTM parts diagrams often lack detailed breakdowns of internal assemblies.
Missing Shim/Washer? It's unlikely you're missing a shim or washer based on your description. The brass spacer and plastic piece likely provide the necessary positioning for the throttle cam.
Here are some suggestions to move forward:
Consult a KTM Mechanic: If you're unsure about the amount of play or want professional advice, consult a qualified KTM mechanic familiar with the 2021 SX-F 350.
Aftermarket Parts Diagrams: Some aftermarket parts suppliers might have more detailed exploded diagrams that show the internal components of the throttle assembly. Try searching online for "[year] [model] SX-F 350 throttle assembly diagram" replacing the bracketed information with your specific details.
If the rocking seems minor and doesn't affect throttle operation, it might be perfectly fine. But if you're concerned or the play seems excessive, getting it checked by a mechanic is the best course of action.
Next Prompt: I own a 2022 Yamaha YZ450F. It's at about 50 hours now, just wondering what you guys are doing at this point in terms of engine maintenance. I’ve heard a lot of differing opinions on when to do my top end, so not sure if now is the time or I should wait another 25-50 hrs. Should I check my valves? Should I replace my timing chain? I’d consider myself mid to upper novice after spending several years off the bike and I do wring the throttle more than most vets. Oil and filter are done every 1-2 rides. Air filter every ride.
Response:
Here's what you should consider for your 2022 Yamaha YZ450F at 50 hours:
Valve Check:
Yes, you should definitely check your valves at this point. 50 hours is within the recommended interval for valve inspection according to the Yamaha YZ450F owner's manual. Ignoring valve adjustments can lead to performance problems and engine damage in the long run.
Top End Rebuild:
You can wait a bit on the top end rebuild. While there's no one-size-fits-all answer, 50 hours is generally considered early for a top-end rebuild on a YZ450F, especially for a mid-level rider. Factors like riding style, terrain, and maintenance practices can affect the rebuild interval.
Here's what you can do to determine if a top-end rebuild is necessary:
Check valve clearances: During the valve check, see how far out of spec the valves are. If they're significantly out, it might be a sign of wear requiring a rebuild.
Engine performance: Notice any loss of power or difficulty starting? These could be indicators of wear.
Listen for unusual noises: Any knocking or ticking sounds from the engine could indicate excessive wear.
Consult the owner's manual: The Yamaha YZ450F owner's manual will have the specific maintenance intervals for your bike, including valve inspection and top-end rebuild recommendations.
Timing Chain:
Replacing the timing chain at 50 hours is likely unnecessary. They typically last much longer on these bikes. However, it wouldn't hurt to have a mechanic inspect it during your valve check for any signs of excessive wear or stretch.
General Maintenance:
It sounds like you're on top of your oil changes and air filter cleaning, which is great! This will do a lot to extend the life of your engine.
Here are some additional resources that you might find helpful:
Online forums like Vital MX [vitalmx.com] where you can find discussions on YZ450F maintenance from other riders and mechanics.
Remember, if you're unsure about any aspect of maintenance, it's always best to consult a qualified mechanic.
Next Prompt: My 2020 KX450 has been making a loud tapping sound since I bought it a few months ago. I've done around 5hrs on it and it's run absolutely perfectly. I had a new piston and the valve clearances checked 2hrs ago but it hasn't made any difference to the sound. The valves were in spec and the engine looked perfect inside, the stock piston had done around 35hrs and wasn't that worn at all. Any ideas what this sound can be? Does anyone else have the same sound? I've been told by a few dealers and mechanics that it may be the new finger follower design cams/valves and its quite normal. The bike runs spot on but I've never had this sound before unless the valve clearances were loose or the cam chain was worn out. Both are all good
Response:
The loud tapping sound you're experiencing on your 2020 KX450 might be a common characteristic of the finger follower valve train design used in these engines. Here's what you can gather from others' experiences:
Possible Cause: The finger follower design can be inherently noisier than the older shim-under-bucket design. This seems to be the case with your KX450, and several others have reported the same ticking/tapping sound [1, 2, 3].
Not Necessarily a Problem: While the sound might be concerning at first, it appears to be normal for this engine and doesn't necessarily indicate any underlying issue. People have reported running their bikes with this ticking for hours without problems [2].
Dealer Confirmation: It's good that you consulted with multiple mechanics, and if they confirmed the sound is normal for the finger follower design, you can ride with some peace of mind.
Here are some additional points to consider:
Severity of the Sound: It's difficult to diagnose without hearing the sound in person. If the tapping is very loud and sounds metallic, it might be worth getting a second opinion from a trusted mechanic familiar with KX450s.
Change Oil Regularly: Frequent oil changes are recommended for these bikes anyway, and this can help maintain smooth operation of the valvetrain [2].
If you're still unsure, it wouldn't hurt to visit a Kawasaki dealer specializing in dirt bikes. They can listen to the engine and confirm if the sound is a normal characteristic of the finger follower design in your 2020 KX450.
So there you have it. Overall pretty impressive. Let me know what you guys think.
3strokemx
4/25/2024 8:17am
We should stage a mock tech question with fake answers and see if AI is scraping data from the Vitalmx Forum.
Luxon MX
San Diego, CA, USA
4/25/2024 11:19am
The problem is that you don't know whether or not it's right. It's just scraping data from the internet, which may or not be right in itself.
We had a client (on the engineering side of the business) who had Chat GPT solve some thermodynamics equations to prove out their concept. Problem was that the answers were way wrong, and on simple thing like unit conversions and similar even. But he had no way of knowing that, he just blindly trusted it.
_moto_
Cordoba, Córdoba, AR
4/25/2024 11:38am
Ask AI about the use of Rotella in modern mx bikes Laughing
(I will show myself the way out)
4/25/2024 1:43pm
_moto_ wrote:
Ask AI about the use of Rotella in modern mx bikes  (I will show myself the way out)
Shell Rotella T oils, particularly the ones designed for diesel engines, might not be the ideal choice for your modern four-stroke dirt bike for a couple of reasons:
Additive Package: Rotella T oils are formulated for heavy-duty diesel engines and contain a higher concentration of detergents and dispersants to handle soot and contaminants produced by diesel combustion. This may not be necessary for your dirt bike engine, and some argue these additives might not be optimal for a high-performance engine [1].
Friction Reduction: Motorcycle specific oils often have friction modifiers designed to minimize friction between metal components in the engine and clutch. This can lead to better power delivery and clutch performance. Rotella T oils might not have these friction modifiers optimized for motorcycles [1].
However, some riders use Rotella T in their dirt bikes with seemingly no problems [2, 3]. Here's a breakdown of the two sides:
Pros of Rotella T:
Affordable
Readily available
Cons of Rotella T:
Might not be optimized for high-performance engines
May not have the best friction modifiers for motorcycle clutches
If you decide to use Rotella T, it's best to:
Choose the Right Viscosity: Ensure the chosen Rotella T oil meets the viscosity recommendation in your owner's manual.
Change Oil More Frequently: Due to the potential lack of optimal additives, consider shorter oil change intervals compared to motorcycle-specific oil.
Recommendation:
For your modern four-stroke dirt bike, it's generally recommended to use a good quality motorcycle-specific oil that meets JASO MA or MA2 specifications [4]. These oils are formulated for the specific needs of motorcycle engines, including wet clutches, and will provide better performance and protection.
Here are some additional tips:
Consult your owner's manual for the recommended oil type and viscosity for your specific KX450 model year.
Look for motorcycle-specific oil brands like Motul, Yamalube, or Kawasaki genuine oil.
Ultimately, the decision is yours. If you're on a tight budget and comfortable with potentially more frequent oil changes, Rotella T might be an option. But for optimal performance and protection of your modern dirt bike engine, a motorcycle-specific oil is the recommended choice.
-END
And Mr. Luxon (Billy, I think?), yes, this shouldn't be trusted and we're just playing around with it. It's effectively like an enhanced search engine that will answer the question by blending information in the top results and then summarizing it with links. One of the questions I asked about YZ setup provided a link to Keefertested.com.
4/25/2024 1:46pm
We should make a fake thread for Triumph TF 250-X tech help since there's probably none of that out there.
_moto_
4/25/2024 2:24pm
Shell Rotella T oils, particularly the ones designed for diesel engines, might not be the ideal choice for your modern four-stroke dirt bike for a couple...
Pros of Rotella T:
Affordable
Readily available
Cons of Rotella T:
Recommendation:
-END
Thanks for doing that, man!
I don't have the knowledge or hardware to do it.
It was funny and insightful. Because it mostly confirmed yours and Luxon ideas.TBH, I think the same too, we will see how it evolves in the future.
4/25/2024 6:03pm
We could start by commenting how easy it is to get parts!
Post a reply to: Asking AI to answer your tech questions
