DeSoto, MO, USA
5/3/2025 8:23am
Can anyone with a 2019-2023 KX450 tell me what their static sag is with OEM linkage and the bike on the stand?
Just trying to figure out exactly how much the pro circuit Link lowered my bike? I measured from the axles straight up to the crease in the rear fender (not the very bottom of the fender).. using a small tape measure hooked inside the axle!.
I have exactly 25 inches with the pro circuit link, but I need to know what that same measurement is with the stock linkage!
Thanks in advañce
Guess Not
Probably dropped it about 6mm.
Do you mean topped out? Static sag means how much a bike settles under it's own weight.
I always thought static sag was the SAG you get when you measure your sag with the bike on the stand wheels off the ground maybe it's topped out sag maybe I'm wrong but yeah I'm trying to find the top out sag with the bike on the stand wheels off the ground.. measured with a tape measure inside the rear axle straight up to the crease in the rear fender not the bottom part of the fender but about 1 inch up to the crease.,
Free shipping: VITALMX
I meant to say unladen sag is the correct term you're right static sag is the SAG the bike has sitting on the ground under its own weight sorry my bad
You can calculate that if you know the ratio.
1mm longer linkage lowered the ktm 5mm for example.
Post a reply to: 2023 KX450 Static sag?
