Vital MX fantasy is free to play, but Premium users receive great benefits. Premium benefits include:
- Pick trends
- Create a private league
- And more!
Only $10 for all 2026 SX, MX, and SMX series.
Thanks!
Free shipping: VITALMX
When I do a fork swap I always measure from the top of the top edge of the frame steering head tube to the axle with the wheel and fender off, right down the center line. That's the more important measurement in getting a fork swap set up correctly. That throws out any variations in overall fork length, or bearing, seal and clamp thickness.
If I remember right I think mine measures approx. 895mm from the top of the frame head tube to the top of the axle tube. That's with the tubes set up in the clamps about 8mm from the top of the clamp to the top of the outer tube edge.
If you set that length to about 900mm it's going to have you in the ball park and then you can adjust as necessary to get the desired handling characteristics you're looking for.
Hope that helps.
Post a reply to: YZ250 fork length info needed
