What’s your premix preference?
Blackjack31
Shelby, NC, USA
Not trying to switch but just curious. I run yamalube and guys at the races we’re saying they run marine stuff from Walmart. And they are fast guys. I’m not an oil expert so I am not gonna say whether it’s good or bad. Def would save a lot of money though.
kb228
Mansfield, OH, USA
4/1/2019 11:58am
Just because theyre fast doesnt mean they know what theyre doing..
Hope the marine oil is an april fools joke..
omalley
Snohomish, WA, USA
4/1/2019 12:11pm
+1. I know some fast guys whose bikes are a POS.
To answer the OP’s question...
VP110/Motul 800 at 48:1. 2002 CR250R with head and cylinder work.
Blackjack31
Shelby, NC, USA
4/1/2019 12:25pm
omalley wrote:
+1. I know some fast guys whose bikes are a POS. To answer the OP’s question... VP110/Motul 800 at 48:1. 2002 CR250R with head and cylinder...
Mine also has a little work. Compression slightly raised and port and polished cylinder. I run either aviation fuel (100 octane) or renegade 110 from a pump. Yamalube 32/1. I like the VP but it’s $$$
Tracktor
The RTF/Amboy, WA, USA
4/1/2019 1:09pm
I ran Yamalube R for many years. Good oil but found it a bit dirty. Switched back to HP2 and couldn't be happier. Powervalves stay cleaner and pistons look even better. That said, most decent full synthetics should be fine............
Evoracer
Anaheim, CA, USA
4/1/2019 2:48pm
Super M, 40:1 for the last 30 years.
soggy
4/1/2019 2:55pm
went from yamalube to motorex and ill echo tracktor's experience, burns cleaner then yamalube
mx510
Gig Harbor, WA, USA
4/1/2019 8:00pm
I have been running Redline synthetic and happy with it so far. 55 hours on a stock 18 TX 300 with no issues. Most of the hours are MX and high speed off road. I am about to do a top end so we will see soon how it looks internally.
Falcon
Menifee, CA, USA
4/2/2019 4:30pm
I moved from Bel-Ray H1R (expensive, hard to find, but best oil EVAR) to Yamalube R (get it anywhere, less expensive, but smokes a lot,) some time ago. I'm about ready to go back to H1R though.
bvm111
Las Vegas, NV, USA
4/3/2019 10:02am
C12, Motul 800, 40:1 in my TMR built 06 KX250
WW444
Decatur, AL, USA
4/3/2019 2:23pm
Run Honda HP2 32:1 in my kx125
4/3/2019 2:32pm
Sunoco 110 at 32:1 Castor 927 in the mod 125.
2.5 gal of 110 and 2.5 gal of 90 no ethanol castor 927 32:1 in the stock 125.
WW444
Decatur, AL, USA
4/3/2019 2:51pm
Rickyisms wrote:
Sunoco 110 at 32:1 Castor 927 in the mod 125. 2.5 gal of 110 and 2.5 gal of 90 no ethanol castor 927 32:1 in the...
My 125 is stock and I run pump 93. Would it be better to run the ethanol free even tho its 90 octane?
4/3/2019 7:15pm
i run 91 octane no ethanol with motorex 2t low smoke at 50:1 on my XC-W
4/3/2019 7:21pm
I mix mine half and half with 110 so after all that's said and done it's around 100 octane. Can't comment on just 90 but your owners manual should have the minimum octane needed for your bike in it.
Blackjack31
Shelby, NC, USA
4/5/2019 8:38pm
I had a stock 2009 yz125 and I ran 93 or 91 ethanol free (I had both near me and just picked which one based on the direction I was going). I put 132 hours on ONE piston before rebuilding it. Ran like a top. People say change them every 20 hours, every 50 or whatever. But I’ve ran stock pistons in a 125 90+ hours on pump gas a lot. 32:1 yamalube. Never had a problem. I think filter maintenance is the most important thing. Not gas. If you’re a pro rider then yeah, you should probably change it often. But I’m a below average (C class top 3) local motocrosser and an A class hare scramble rider. You’re fine to run that.
4/5/2019 9:15pm
100LL and Super M at 32:1 Everything from KTM50's to CR500's. When properly jetted there is no spooge and no PV buildup.
Towards the end of my son's time on 85's I also tried K2 for even more protection, but he was absolutely running the snot out of the little RM and while the Super M was working fine, I just wanted the best oil available.
lumpy790
York, SC, USA
4/6/2019 5:46am
Read the recommendations on the bottles label
Post a reply to: What’s your premix preference?
