WP Shock help?!
Halaburda120
Windber, PA, USA
Edited Date/Time 5/13/2020 7:41am
Okay so I have a 2018 Ktm 125SX. The rear shock is leaking and needs rebuilt. To save some money for now. I will be rebuilding it myself. I’ve done shock rebuilds on other bikes before. I’m having trouble coming up with a solution to charge the shock. I don’t want to do a bladder conversion. So I’ve come down to 2 options. The rubber race tech bolt or drill out and tap the hole for a schrader valve. I like the idea of drilling and tapping it out but say in the future if I want to get my stock valving changed will suspension company’s turn their nose because it’s drilled?
4/30/2020 1:47am
If a suspension company turns up their nose at it, move on to the next company.
rjg
4/30/2020 10:13pm Edited Date/Time 4/30/2020 10:14pm
Get your self a Schrader valve to install and a mountain bike pump. Nitrogen is not mandatory. Only a bar suspension service would turn to away for drilling and tapping that
mx317
5/1/2020 7:52am
I have a Factory Connection bladder kit for sale for $75. Some bozo on eBay bought it and didn't know how to install it and returned it and didn't send the clip back at the bottom. You would need to get that clip.
TC125
5/8/2020 3:21pm
The Schrader valve sounds like a good plan, I made a tool up for charging with the original bolt which works ok. Have been reading about vacuum bleeding but after taking my Wp shock apart there isn't any sign of air
rjg
5/8/2020 8:03pm
Can you post a picture of that fitting/tool
5/8/2020 8:42pm
Does anyone know if it’s worth buying the shock bleeder system with all of the fittings just to service yours and your friends shocks? Or is there a cheaper/smarter solution? Looks like it would cost around $800 for everything
TC125
5/9/2020 4:32am
I think the vacuum bleeder is mainly needed on pds (?) shocks that have two pistons because it's harder to get the air out from between them. I have also found that when assembling the shock the seal head displaces the floating piston to the proper setting when it's inserted
TC125
5/9/2020 4:34am
A couple pics of my setup:
erik_94COBRA
Houston-ish, TX, USA
5/9/2020 5:08am
I’ve used the RT bolt and it worked fine. I have also installed a bladder kit to not have to fiddle with the bolt or drilling/tapping for a schrader valve.
Have also done hand bleeds and used air instead of nitrogen. Both were fine for me.
5/9/2020 7:53am
TC125 wrote:
A couple pics of my setup: [img]https://p.vitalmx.com/photos/forums/2020/05/09/426072/s1200_IMG_20200317_181252.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2020/05/09/426073/s1200_IMG_20200408_084915.jpg[/img]
That’s pretty cool looking, I’m going to have to read more into it
Bruce372
5/9/2020 8:26am
Drilled, tapped and added a Schrader. $15 job and works perfectly
rjg
5/13/2020 7:41am
Nice tool fella! Thank you for posting
Post a reply to: WP Shock help?!
