Suspension Spring swap
Craig742
Allison Park, PA, USA
Edited Date/Time 1/12/2018 6:32pm
I have a 04 CR250 and has heavier springs in the forks and rear shock. Can you just swap to lighter springs or will I need to add/remove oil and reset the Sag?
Paw Paw 271
Benton, LA, USA
1/12/2018 6:54am
YOu should replace the fork oil and put in new seals when changing the springs. On the shock, you can just replace the spring and reset the sag as the spring rate will effect both the race and static sag and it will need to be reset.
Remember that both the forks and the shock should be serviced and fluids changed regularly even without spring changes.
Bruce372
1/12/2018 7:56am
What spring rate are you looking for? I have a couple of oem showa springs that will fit your shock
macz400
League City, TX, USA
1/12/2018 8:39am
Craig742 wrote:
I have a 04 CR250 and has heavier springs in the forks and rear shock. Can you just swap to lighter springs or will I need...
I got a Factory Connection 4.6 rear spring if needed.
Bruce372
1/12/2018 11:53am
i have 5.1 and 5.3, OEM showa shock springs...
Craig742
1/12/2018 5:07pm
This is my current setup, I got a 5.4 spring and looking for .44 fork springs. My 180lbs is too light for the current setup. I tried but too much
slipdog
Nor Cal, CA, USA
1/12/2018 5:27pm
At 180 you're going to want to use a .45kg fork spring. That will also balance better with that 5.4kg shock spring.
macz400
1/12/2018 6:32pm Edited Date/Time 1/12/2018 6:32pm
On my 07 CR250, Factory Connection used a .45 fork and 5.1 shock spring. I'm 175lbs
Post a reply to: Suspension Spring swap
