My 14 rmz450 says to have 1.7 to 2 inches of freeplay at the midpoint of the swingarm between the end of the slider and the rear sprocket, measured on the bottom side of the swingarm. Ive also heard to use the old "3 fingers under the chain at the top rear of the slider". Since I cannot get an accurate measurement using the service manual method, is the 3 finger method adequate?
If you have the bike on a center stand with the shock loose from the lower link, you can raise the swing arm until the countershaft. swing arm pivot and rear axle are in a straight line with each other. You can the adjust the chain to where it is just snug with just a bit of movement up and down.
Then lower the swing arm and replace the shock on the lower link. At this point remove the bike from the stand and
have someone hold it up right and the measure the chain movement up from the swing arm at the rear of the top chain slider. Record that measurement. Then at any time in the future you can adjust the chain to that measurement to have it adjusted perfectly.
Or you can just use the 3 finger method you described.
It will take some extra time the first few times you do it, but once you see how accurate it is you will never want to go back to the finger method.
Post a reply to: Rookie chain adjustment question.
