Pw50 oil question
oceantrav
Tarpon Springs, FL, USA
What are y’all using in the oil injection tank?
6/12/2018 2:00pm
Yamalube, SuperM Injector from Maxima. Those are the two I've used
oceantrav
6/12/2018 2:24pm
Yamalube is what we used on our 17, seemed to always smoke more than others.
Just picked up a new 18 today, debating switching oil.
6/12/2018 3:43pm
2-S. Seeing a bit of smoke assures you it is oiling.
mikec265
Edinboro, PA, USA
6/12/2018 10:24pm
Amsoil Dominator. Same as my big bikes. Never had a problem caused by oil.
oceantrav
6/13/2018 3:54am
What are y’all using for air filters also? Think I used a pro-x last time and it didn’t even fit right. Going to try twin air I guess
What’s up with the washer in the exhaust? Why do they even put that there? Even on pavement with it the bike goes no where, guessing a liability/ lawsuit deal?
Paw Paw 271
Benton, LA, USA
6/13/2018 6:27am
The exhaust washer reduces the power of the engine. It can be removed.
On the ones I had I drilled the washers out bigger over time to give added power as the little one was learning to ride better. Then finally just pulled them out.
6/13/2018 2:11pm
PW's carbon up the exhaust port so bad, it's like a gradual built in restrictor.
Falcon
Menifee, CA, USA
6/13/2018 3:25pm
I yanked that restrictor out of my kid's PW on day one. Just set the throttle limiter all the way in to mitigate the speed instead.
Yamalube 2S all day long. It's cheap and darn good oil for what it's running in. If you must use a different oil, make sure to use an injector oil - the product has thinners to make sure it gets through the injector.
Post a reply to: Pw50 oil question
