KYB Springs
h4ck.b0x7
Dearborn, MI, USA
Edited Date/Time 7/1/2019 3:01pm
Where can you buy KYB springs online?? I need a 5.0-5.1 kg/mm spring.
Also, is there a certain direction the spring goes on? On the stock spring I noted the paint mark was on the side of the shock that mounts to the linkage.
I ordered what I thought was a KYB spring from Suspension Direct as it was advertised as that. There was also mention of RCU but Googling that didn’t get me very far.
In the picture you can see the spring I got at the top along with the part number and the stock KYB spring below it. I’m pretty sure what I received is not KYB. You’ll notice the advertised spring is silver like my stock spring as well...
DB97
Orlando, FL, USA
6/29/2019 5:04pm
h4ck.b0x7 wrote:
Where can you buy KYB springs online?? I need a 5.0-5.1 kg/mm spring. Also, is there a certain direction the spring goes on? On the stock...
I just ordered from them as well and it came black too. The spring is slightly bigger on the top side.
h4ck.b0x7
Dearborn, MI, USA
6/29/2019 5:11pm
Is it a KYB spring?
mx317
6/29/2019 5:36pm
ENZO has KYB parts.
DB97
Orlando, FL, USA
6/29/2019 5:41pm
h4ck.b0x7 wrote:
Is it a KYB spring?
Yeah that part # is kyb
m21racing
Reno, NV, USA
6/29/2019 6:40pm
Technical Touch USA
scgmoto
Ojai, CA, USA
6/30/2019 6:56am
Any motorcycle shop can order genuine KYB springs and parts thru Tucker Rocky or Parts Unlimited
Kartwheel
Sydney, AU
6/30/2019 7:25pm Edited Date/Time 6/30/2019 7:27pm
Thats a for a KYB 46mm shock that will fit YZ125/250 if you have a YZF you need a spring for 50mm shock.
The top is bigger diameter than the bottom on both type of springs
I'm pretty sure SDI are genuine KYB springs
h4ck.b0x7
Dearborn, MI, USA
6/30/2019 7:30pm
Kartwheel wrote:
Thats a for a KYB 46mm shock that will fit YZ125/250 if you have a YZF you need a spring for 50mm shock. The top is...
Was that supposed to say, “That’s a part # for a KayB spring”?
It’s a YZ125 which is a 46mm.
h4ck.b0x7
Dearborn, MI, USA
7/1/2019 2:48pm
I spoke with SDI today and they are NOT genuine KYB springs. Why they list them on their site the way they do is beyond me.
I called Technical Touch and ordered a genuine KYB spring.
DB97
Orlando, FL, USA
7/1/2019 3:01pm
h4ck.b0x7 wrote:
I spoke with SDI today and they are [b]NOT[/b] genuine KYB springs. Why they list them on their site the way they do is beyond me...
I guess we miss understood you. Yes they fit but no it's not a kyb made spring.
Post a reply to: KYB Springs
