Issues with PWK on KX125
Hi
I Have a KX125 2004 with a pwk airstiker 38, have som jetting issues...
Engine specs
Bud Racing top
Boyesen intake
Mildly ported
Pro circuit
Aspen R 102
I cant get the bike to run good on low throttle.
Went from 38/160 #7slide step by step to 65/190 #7 slide, the bike runs ok but not good.
No airleaks and newly built engine.
digger
Upstate, NY, USA
4/24/2020 12:26pm
Wangstedt wrote:
Hi I Have a KX125 2004 with a pwk airstiker 38, have som jetting issues... Engine specs Bud Racing top Boyesen intake Mildly ported Pro circuit...
Hi
Engine specs
Bud Racing top
Boyesen intake
Mildly ported
Pro circuit
Aspen R 102
What needle are you using ?
4/24/2020 12:34pm
Im not sure.. :/
digger
Upstate, NY, USA
4/24/2020 12:52pm
Wangstedt wrote:
Im not sure.. :/
Before I can offer any meaningful advise I would need to know what it is. It's the most important jet in a PWK. Everything else gets tuned around it.
Bruce372
4/25/2020 11:35am
I think your slide is way too big
4/26/2020 3:18am
What slide do you think I need?
Bruce372
4/26/2020 9:37am
I ran a 4 slide on a rm125 using a screw top pwk back in the day.
Not sure you should go that rich though, but it does look like you've gone mega rich on the jettinf to compensate for a lean slide.
digger
Upstate, NY, USA
4/27/2020 5:54am
It really depends on which needle you are using. There are needles that will allow you to use a #7 slide, but more realistically I would recommend something closer to a #6. A #4 slide is very, very rich when used in a pwk.
4/27/2020 5:55am
digger wrote:
It really depends on which needle you are using. There are needles that will allow you to use a #7 slide, but more realistically I would...
Its a PWK Airstriker 38mm QAS new. Do you know wich needle i could use without changing the slide?
digger
Upstate, NY, USA
4/27/2020 2:38pm
I would try using a single taper CCL needle. Start out in the #3 clip position with a 45 pilot and a 165 main jet, and the air screw at 1.5 turns out to start with. Also make sure the float height is set correctly. I'm not sure which version of PWK you have.
jaguar57
Miami, FL, USA
5/1/2020 11:14am
You can keep busting your head trying different needles and slides, spending a fortune, or you can spend $15 on a jetting calculator and let it show you what slide and needle work best.
www.dragonfly75.com/moto/carbjetting.html
Kidkawie
ქუთაისი, GE
5/6/2020 4:17am
I used a 97 KX250 carb with 38/158 jetting.
6/2/2020 11:06pm
So i got some more info now.
The throttle is marked 65, is it the slidenumber?
The needle is marked DGN.
/ Wangstedt
jaguar57
Miami, FL, USA
6/2/2020 11:35pm
normally you arrive at the right slide cutaway (in millimeters) by dividing the carb size by 10. So yours should be 3.8 or 4mm, but instead it is 7. That will lean out the low range jetting too much.
6/3/2020 12:46am
jaguar57 wrote:
normally you arrive at the right slide cutaway (in millimeters) by dividing the carb size by 10. So yours should be 3.8 or 4mm, but instead...
So even if its marked with 65 its a slide #7?
6/3/2020 11:35am
Hi
Engine specs
Bud Racing top
Boyesen intake
Mildly ported
Pro circuit
Aspen R 102
jaguar57
Miami, FL, USA
6/3/2020 2:57pm
take the needle out of the slide and let it rest on a flat surface and measure how many millimeters high is the highest part of the cutaway. For a 38mm carb it should be close to 4mm. read this guide to jetting: http://www.dragonfly75.com/moto/carbtuning.html
Tracktor
The RTF/Amboy, WA, USA
6/3/2020 3:41pm
No it's a 6.5. pretty common slide size. Ignore what this dude is telling you. Jetting by a calculator is a recipe for disaster. 6.5/7 should run just fine in a 125 with correct brass. I'll look when I get home and see what we were running in CR125 before I threw STIC in it. It might get you close..........
jaguar57
Miami, FL, USA
6/3/2020 4:17pm
What I said was due to what I have noticed with most carbs. There must be a reason for that general rule. I'm not saying perfect jetting is impossible if the cutaway ignores that rule though. I'd have to analyze it on my jetting calculator. It probably has some relation to the clearance between needle and needle jet.
World Championship testimony: Thomas in the Nethlands wrote about the results of using my jetting calculator:
"Just some nice input about the bike (1965 Husqvarna 360 piston port with a Mikuni 32) that I sent you info on earlier and you corrected my input, and sent new corrected one to me, and where red line was rather straight and nice. I was just informed that that bike (driver said jetting was great on the sand track) was one of the bikes in the Swedish team winning world championship in Netherlands yesterday (Sept 21 2019) for vintage bikes before 1965 and driver was over 72 years!"
jaguar57
Miami, FL, USA
6/3/2020 4:18pm
another testimony:
"This software works very well for carb jetting. It gets you into the ballpark and is almost spot on first time. I setup 2 bikes (CR250 and a CR500) with it and afterwards only had to do some minor adjustments with the air screw. Keihin PWK 38mm Airstrikers on both bikes. It helped in the selection of the needle, main, and pilot. You could try different combinations and it would show you if the combo was too lean, rich, or on the money. I took what I learned from the information and put it into the bike and it worked very well."
6/4/2020 3:32am
Tracktor wrote:
No it's a 6.5. pretty common slide size. Ignore what this dude is telling you. Jetting by a calculator is a recipe for disaster. 6.5/7 should...
Thank you ! Smile
9/2/2020 10:56am
Still not getting the bike to run good...
JD jetting red needle taken down 0.1mm or else it wouldnt run at all.
Got the #6.5 slide 45/180 jetting.
Tested the #5 slide aswell but it didnt work, the bike keeps bogging.
Getting kind of tired of this and got no ideas. have like 1 hour on this bike the whole season.
Still no leaks and the exhaustvalve works as it should
digger
Upstate, NY, USA
9/2/2020 11:25am
Wangstedt wrote:
Still not getting the bike to run good... JD jetting red needle taken down 0.1mm or else it wouldnt run at all. Got the #6.5 slide...
Did you try the needle and specs that I suggested, CCL needle, 48 pilot and 178 main ? They should work with the 6.5 slide best.
What JD jetting kit did you get for your bike ? The small bore JD kit should have needles that have scribe lines under the last clip groove, if not you may have the wrong needle kit.
9/2/2020 11:29am
digger wrote:
Did you try the needle and specs that I suggested, CCL needle, 48 pilot and 178 main ? They should work with the 6.5 slide best...
I totally forgot that. Ill order one immediately.
I might have the wrong kit then...
Ill get back to you.
Its the PWK Airstriker 38mm QAS Shortbody
digger
Upstate, NY, USA
9/2/2020 11:33am
That the correct carb for your bike. JD sells a kit for small bore bikes,125/150 and one for 250/300 bikes. The kit for the larger cc bikes will not work in your 125.
9/2/2020 11:37am
digger wrote:
That the correct carb for your bike. JD sells a kit for small bore bikes,125/150 and one for 250/300 bikes. The kit for the larger cc...
It was one for a 500...
So I ordered the CCL now.
Hope this will work Smile
Thank you !
digger
Upstate, NY, USA
9/2/2020 3:01pm
Thank you !
I meant the short body PWK. The internal jetting is easy enough to change.
9/3/2020 12:46am
Yeah, i meant that the needle I got was for a CR500... thats probably why it wont work Smile
9/6/2020 5:49pm
A good starting point for that application would be an NECW needle in the 2nd clip position ( 2007 Suzuki RM250 needle ) 42 pilot jet / 1.5 air screw / 172 or 175 main jet and your # 6.5 slide.
If that is a little rich at low throttle positions ( 1/4 to 3/8 ) then go to the NECJ.
I'd start with the 175 main. It might be a little rich but it's safer to start on the rich side.
9/6/2020 10:17pm
So i got the CCL and the bike runs good, a little bogging but not at all the same issues as before.
Im running 45/180 because 170 & 175 is to lean on the full throttle.
Thank you so much for the help!
Regards
Christopher
jaguar57
Miami, FL, USA
9/7/2020 12:10am
my god man, why would you settle for "a little bogging" when you can have it running super crisp all thru the whole throttle range? Here's an easy to use software program that can make you a jetting expert: www.dragonfly75.com/moto/carbjetting.html and it only costs $20. That's about the cost of one needle and yet people order and try many needles and main and idle jets until they can live with the results. Fuck that, bikes exist to give me pleasure and if it ain't crisp all the way thru it detracts from it being a fully positive experience.
Post a reply to: Issues with PWK on KX125
