Port Isabel, TX
11/22/2019 1:58pm
Ive had a few people tell me different.
What is the right order?
Tighten the axle, pinch bolts then axle again.
Tighten pinch bolts then axle.
Tighten axle, left side pinch bolts, axle again then right side pinch bolts.
Tighten rider's right side pinch bolts, so the axle doesn't turn.
Tighten the axle nut to torque.
Remove bike from stand and compress the forks a few times.
Tighten rider's left side pinch bolts.
Check torque on the axle nut.
Also, remember that binding of the suspension action is caused by the axle and its relationship between the two forks. We want a completely stress-free, even geometry between the two fork legs. Imagine an arbitrary line drawn across the bottom of the axle - this line should line up perfectly with two identical points at the bottom of the fork legs. There would be no "twisting" forces applied through the axle and acting on the forks in this condition.
If one side (right) of this equation is rigid initially, it doesn't really matter - as long as the other side (left) is given a chance to conform to the same alignment. And thus, we cycle the suspension as in step 3 before tightening the pinch clamps on the left.
Keeps things loose.
Collapse the forks.
Tighten axle while holding axle with an allen.
Tighten pinch bolts.
Free shipping: VITALMX
Regarding alignment, there are multiple techniques. If you have a good set of triple clamps and the forks aren't bent or anything weird, you can usually just let the axle self align in the lug and torque the bolts (bike on a stand, wheel in the air). That assumes the fit between the lug and axle is loose enough for it to float around some. If not, you'll have to spread it with a screwdriver or something. In general, the fork lug outer surface should be flush with the axle surface. If it's way off, then something is probably wrong.
You can open up the fork caps and compress everything fully then tighten the axle as shown earlier, but if you know everything is straight (forks/clamps), then that's a bit overkill. Or you could do it once, note the relationship between the axle surface and lug, then match that the next time you do it without all the work of compressing everything.
Conceivably, I could fasten the front wheel to the bike without the right-side fork at all.
Even with the axle nut torqued to spec., the left-side fork leg can rotate on the axle with force. This is why we compress the forks several times and then use the pinch bolts. Nate's method would definitely work better for bikes featuring a right-side fork lug interface with the axle, though.
You leave the right side loose when you compress the suspension so right lug centers itself on the axle. Then the pinch bolts keep it from moving or sliding on the axle.
https://m.youtube.com/watch?v=VHJQY5HE2_A
Post a reply to: Front axle sequence
