Fork oil question
27thmx
Naples, FL, USA
How much and what type of fork oil are you all running in your 2019+ kx450s? I know the stock fork oil capacity is a bit low
Factor E
So Cal, CA, USA
9/7/2020 1:42pm
5wt air forks about 350ml
mwssquad827
Twin Falls, ID, USA
9/8/2020 12:08pm
7.5wt and 350ml
DJS721
North Am Erica, OH, USA
9/8/2020 4:22pm Edited Date/Time 9/8/2020 4:22pm
Kawasaki suspension oil A15-00 44091-0023, but the weight is not clearly stated anywhere. It is the same as Honda Showa SS47 - which is stated as a 5wt in the OEM service manual. These oils were developed for the new 49mm Showa forks
The Kawasaki oil is expensive, I found the Honda oil can be bought cheaper. Or choose your best brand
350ML
slipdog
Nor Cal, CA, USA
9/8/2020 9:28pm
01M @350cc
27thmx
Naples, FL, USA
9/9/2020 2:06pm
I typed in the part number on google and one site had it listed as sae 15w. So I guess the aa-15 means that. This correct? I know the stock oil was pretty thick
Benton, LA, USA
9/9/2020 4:05pm
5w 335 cc
Jardo
Visalia, CA, USA
9/14/2020 9:25am
Can you add 5cc of different oil (same weight) to your forks or is that a no no?
Post a reply to: Fork oil question
