Cone valve set up help
lukemoto
Mukwonago, WI, USA
Edited Date/Time 5/10/2019 3:13pm
I got some used cone valves recently and wanted to see what other people my weight range are running (190-200). The person I got them from was 40-50lbs less than my 200lbs I'm guessing, and his settings were: red cone, 4.6 spring, 400cc, 2clicks preload, and 12 on rebound and compression valves for vet A mx. Will I be able to get in range with the 4.6 springs and adding some compression? Any suggestions would be great
lukemoto
Mukwonago, WI, USA
5/10/2019 3:13pm
Jrewing
5/10/2019 4:36pm
What bike?
T-Fish
Sparta, WI, USA
5/10/2019 5:26pm
lukemoto wrote:
I got some used cone valves recently and wanted to see what other people my weight range are running (190-200). The person I got them from...
Who did his suspension?
T-Fish
Sparta, WI, USA
5/10/2019 5:26pm
Jrewing wrote:
What bike?
Looks like a 2018 250 smoker, from previous posts of his.
lukemoto
Mukwonago, WI, USA
5/10/2019 7:38pm Edited Date/Time 5/10/2019 7:46pm
Yep 18 250sx. The guy I bought them from got them from wp directly. His bike was a sxf450 so that would help with the weight difference
MP818
Grand Prairie, TX, USA
5/10/2019 8:20pm Edited Date/Time 5/11/2019 10:40am
I’d still suggest at your weight going to the .48/.5 fork springs. Maybe going a couple clicks more on preload if you have a pin spanner or a tool to make that adjustment. If you’re also a Vet A, then you should be pretty money after that assuming you’ve got your shock dialed in for you.
AJ565
San Antonio, TX, USA
5/10/2019 10:35pm
I have a set on a 250sx and weigh 170. I’ll check the sticker and see what my settings are this weekend. I know I have a 46 springs though. A 46 spring sounds awful soft for a 450 and a vet A rider.
CarlinoJoeVideo
Portland/Los Angeles, CA, USA
5/11/2019 12:21am
I think I’m on a 4.6 spring with KTM350 and 160lbs
lukemoto
Mukwonago, WI, USA
5/11/2019 3:10am
Sounds good thanks! I guess I'll order some 4.8 springs.
bowser
5/11/2019 5:31am
run a 48 and 46 spring for the 250
aees
5/11/2019 1:03pm
I'm 200, 450 sxf (2018) running 5.0 380ml red cone. 10r, valved slightly softer on comp but 17c. 0 preload. Rear 50nm 105/42 6mm preload Trax, valved a lot slower rebound and comp. 36hsc, 16r, 23c.
Post a reply to: Cone valve set up help
