IE
2/26/2019 11:43am
Hi all, I ride a 2011 sx 125 and I seem to be constantly setting the chain slack. Every time I rode it seemed to be too loose when I came back, so I replaced the chain, lubed it up and the same things happening? Am I leaving too much slack? Any advice? How much slack should I have behind the chain slide while SITTING on the bike? I currently leave about three while off the bike and I weigh about 60kgs. thanks a lot .
your axle may not be tight enough so the wheel slides back
One other tip I use to make sure my wheel is aligned properly is to look at the sprocket teeth through the chain when seated behind the bike. The sprocket should be in alignment with the chain all the way up to the front sprocket. I'm a fan of the "hook a box-end wrench on a tooth of your rear sprocket and rotate the wheel backward until the chain tension snugs the axle blocks into the chain adjusters" method. Look at the alignment while you have the wrench wedged in there.
After all that, you should be able to put three fingers underneath your chain, just behind the chain slider with no further wiggle room. If you can't get three fingers in, your chain may be too tight.
Here are photos of my adjusters.
Post a reply to: Chain slack constantly changing? Help
