- Pick trends
- Create a private league
- And more!
More than you asked for AND a bit of a tangent, but here's what I ended up w/ on a 2006 YZ250 two-stroke that made it a 3-stroke. Hopefully this is helpful and thought provoking.
My primary *unplanned* solution ended up being the Rekluse Core EXP 3.0 clutch system. For some reason that EXP clutch was perfect for me and the way I like to ride a 250 2-stroke. I also changed the gearing to 15/45 - and it was still awesome (did it for desert riding, ending up loving it for nearly everything), no kidding. A steering damper paired with Flexxbars helped me a lot, too. I also installed MotoT VForce reeds and a ZipTy Racing exhaust - which was the Factory Yamaha system (Dubach Racing was making the same exhaust for a while) to produce tractor-like power. Additionally, the following combo was a surprise arm pump reducer, too, that a guy on ThumperTalk pointed me to years ago:
Magura HYMEC clutch with MME clutch lever (the M2C model: https://www.midwestme.com/find-your-lever/midwest-moutain-engineering/f…). And lastly, I also installed a Steahly 9 oz flywheel weight ... figured I better add that part to "sort of" stay on topic and bring things full circle (I was sensitive to anything over 9 oz, didn't like the handling changes).
Oh - 2 last arm-pump reducing "gems":
(1) I discovered that the most low profile grips I could find (Renthal full diamond) resulted in the least tendency to pump up. I equate it to trying to do pull-up on a bar that's larger diameter and you can barely hold on to vs. the perfect diameter that allows you to do the most pull-ups.
(2) I've also been playing with Stegz Pegz lately. I think there's something here for me, but I need more hours to better understand/learn how to use them. Here's a look:
https://www.rockymountainatvmc.com/parts/stegz-steg-pegz-p
The above setup ^^^ resulted in one of the most versatile bike's I've ever owned. And I was an idiot for selling it.
Have fun on that YZ250!
The flywheel weight is good. Even MXA runs one. anything bigger then the GYTR or the Steahly 9oz is a bit much for moto use. Especially when you start getting into deeper soil or sand.
Also, as mentioned above, retarding the timing has a big effect on these things, too. Get a dial indicator and experiment with 1* and 2*. I didn’t like anything more than 2*.
The last thing… I refused and resisted it as long as I could, thinking it was all internet hype… but the Apex head is the single best modification I’ve done to a YZ250. They offer MX, SX and XC domes, and I bought and tried all 3. The MX dome is the best all around setup. It has strong, controllable bottom end, and then pulls hard all the way through the rev range. Best way to describe it, it fills in any of the low points in the power curve, making it more broad and tractable. Bike is also much easier to jet now. I’d start with the head (either buy the complete billet head with dome, or send them yours to get cut) and flywheel weight. It’ll be a completely different motorcycle.
I’ve had serval yz250’s and prefer the smoother yz250x motor traits.
Just my preference.
(engine-timing-change-calculator.xlsx and 2-stroke-cylinder-head-squish-cc-calculator.xlsx)
https://www.luxonmx.com/resources.html
I made these up when I had a YZ250, so all the numbers are relevant to that bike and the changes I made at the time. I honestly don't remember the specifics of the what and why as it was about 6 years ago, but you can see what I did and it might be helpful. I do remember that I settled on 2 degrees of timing retard and the lighter GYTR flywheel weight (still heavier than stock) to smooth out the power.
Funny thing is ( if I remember right ) some of the manuals differ in what they say the stock timing spec should be. I'm thinking some of them spec like .0070" and others are like .011". Anybody else seen this, or am I having a senior moment. Regardless, with my set up I like mine set at .011".
Post a reply to: 2021 YZ250 Flywheel weight
